RE: Blackhorse P-36A Hawk....join here!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Blackhorse P-36A Hawk....join here!
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Blackhorse P-36A Hawk....join here! - 3/31/2010 3:54 PM
Kostas1
Score: 330
Last Login: 5/24/2013
Status: offline
What i did to reinforce the flap area (..was really too shaky and light )
was to glue these balsa sticks.
It did make a big difference ...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
(in reply to paladin)
       Post #: 26
RE: Blackhorse P-36A Hawk....join here! - 3/31/2010 10:26 PM
paladin
Score: 250
Last Login: 5/23/2013
Status: offline
Kostas, are you going to use the EZ hinges or a Robart hinge point type? The hinge point would move the hinge knuckle out to the surface of the wing from the 1/8 inch below the surface with the CA hinges. The hinge point should work in the amount of wood needed for the CA hinge?
Joe
If it don't fly it wont ketch my eye.
Hide Signatures
(in reply to Kostas1)
       Post #: 27
RE: Blackhorse P-36A Hawk....join here! - 4/2/2010 10:02 AM
Kostas1
Score: 330
Status: offline
quote:
ORIGINAL: paladin
Joe
Joe i think i am going to stay with the supplied CA+ hinges /arrangement.
Although i really really hate the hinging-job they did.
I will stay for a while with this setup and if it fails on me (...hope it fales on the ground :P )
i will strip all the d@mn hinges and use my beloved and never failed on me Greatplanes hinges!
Hide Signatures
       Post #: 28
RE: Blackhorse P-36A Hawk....join here! - 4/9/2010 10:32 AM
Kostas1
Score: 330
Status: offline
The servos on the wing are now installed...
x2 Futaba S3004 for ailerons
x2 Futaba S3003 for flaps
Next
will be installed the retract servo (...low profile )
and the control rods/horns.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 29
RE: Blackhorse P-36A Hawk....join here! - 4/9/2010 8:41 PM
Kostas1
Score: 330
Status: offline
Now the ailerons & flaps are installed with each servos/horns/rods.
I have voted first for my all time favourite hinge ,
the Dubro Nylon T-style horn, No.237.
BUT the screw that is provided by Dubro was too small for reaching the backplate of the horn so as to be secured tightly.
So i tried the Black Horse setup ...... at first it looked really weird but in the end it was very very nicely thought and worked great!
Here are some pictures ,as always!
Hide Signatures
       Post #: 30
RE: Blackhorse P-36A Hawk....join here! - 4/11/2010 3:58 PM
Kostas1
Score: 330
Status: offline
Today i did some reinforcing ....
Mainly on the area behind the firewall .... and also on the wing.
Where the retracts will bolt on....
I used thinned epoxy (30'+alcohol) and fiberglass cloth!
I have also done the install of the control horns on the elevators and rudder.
Now the jobs that have to be done,
are :
1) retracts
2) servos on the fuselage for the elevators+rudder+throttle
3)installation of my Saito 120S (...waiting to come)
4)batteries/Rx/fuel tank & miscelaneous hardware!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 31
RE: Blackhorse P-36A Hawk....join here! - 4/11/2010 4:00 PM
Kostas1
Score: 330
Status: offline
Some others!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 32
RE: Blackhorse P-36A Hawk....join here! - 4/11/2010 6:30 PM
Kostas1
Score: 330
Status: offline
BTW Black Horse now has a website with online manuals etc...
http://www.blackhorsemodel.com.vn/index.php
Hide Signatures
       Post #: 33
RE: Blackhorse P-36A Hawk....join here! - 4/28/2010 1:41 PM
Kostas1
Score: 330
Status: offline
Guysss,
here's my new Saito 120S that i bought for my BlackHorse P-36A hawk ARF .......
09
09
Hide Signatures
       Post #: 34
RE: Blackhorse P-36A Hawk....join here! - 4/28/2010 6:32 PM
Neo gold
Score: 100
Last Login: 2/10/2013
Status: offline
Superb reliable power house there Kostas!!...swop ya for my fg20!!..
Hide Signatures
       Post #: 35
RE: Blackhorse P-36A Hawk....join here! - 4/28/2010 6:40 PM
Kostas1
Score: 330
Status: offline
quote:
ORIGINAL: Neo gold
What's an fg20 ?
Hide Signatures
(in reply to Neo gold)
       Post #: 36
RE: Blackhorse P-36A Hawk....join here! - 4/28/2010 9:33 PM
Kostas1
Score: 330
Status: offline
OK now start the problems!
Firstly,
the P-36A doesn't come with pre-installed blind nuts behind the firewall for bolting your engine...so you must use your own gear.
I always vote for Dubro stuff that had never failed on me or let me down!
I "tried" to install x4 10-32 blind nuts with 10-32x1-1/4' SHCS....
I drilled the firewall with a small drill bit,then enlarged the holes with a #8 drill bit.
Then tried to install the bolts/blind nuts BUT when you try to draw the blind nuts into place,
the wood is so soft that you end up with no sight of the blind nuts !
And i am really hesitant if this will hold up to the torque of the Saito 120S....anyone with some advice here ?
Then i drilled the engine mount with a small drill bit and then used an #8 tap to make some nice threads!
That worked awsome...then i installed the x4 8-32x1-1/4' SCHS along with the #8 washers and #8 safety lock nuts.
All Dubro.
Here are some pictures.
Please give me some advice for the blind nuts.
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
Hide Signatures
       Post #: 37
RE: Blackhorse P-36A Hawk....join here! - 4/29/2010 1:00 AM
Neo gold
Score: 100
Status: offline
A quick & effective way out of that one is by using 4 large steel washers & Locknuts...i'm suprised the wood is as soft as you say!?.
Or you can reinforce the back of the bulkead/firewall with a 6mm ply piece & use longer bolts.
I would not trust to leave it like that..Saito 120's have bags of torque...it may work loose & pull out over time...a bad accident that would be!..
Hide Signatures
       Post #: 38
RE: Blackhorse P-36A Hawk....join here! - 4/29/2010 10:17 AM
Kostas1
Score: 330
Status: offline
quote:
ORIGINAL: Neo gold
Neo Gold sorry for my misunderstanding but i didn't get it.....about the " 4 large steel washers & Locknuts. "
Could you draw a sketch on MS paint or something ?
Oh and the wood is unexpectedly soft and i mean SOFT.....
Hide Signatures
       Post #: 39
RE: Blackhorse P-36A Hawk....join here! - 4/29/2010 3:58 PM
Kostas1
Score: 330
Status: offline
Some more progress.....
Tail wheel assembly and x3 servos in the fuselage...
i used x1 S3152 digital from Futaba and x2 Hitec HS-485 BB.
I have also captured
x2 videos ....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 40
RE: Blackhorse P-36A Hawk....join here! - 4/30/2010 12:07 PM
Kostas1
Score: 330
Status: offline
............up for a little update!
I have already installed the fuel tank and set up on the fuselage.
The little opening on the wood,
just behind the firewall gives you good sight of the place and makes the f.tank installation a breeze....
Enjoy..
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 41
RE: Blackhorse P-36A Hawk....join here! - 5/2/2010 11:09 AM
Kostas1
Score: 330
Status: offline
.......here are my little friends.....we all need some friends :P
0
0
Hide Signatures
       Post #: 42
RE: Blackhorse P-36A Hawk....join here! - 5/3/2010 8:35 PM
Kostas1
Score: 330
Status: offline
Guys...today was the day for the retracts...i'd say i am more than please with the outcome
although
it was a b#tch to install the retract horn with the retract pushrods hooked up....
Anyway
it seems a good install so far,
the one leg needs some more cutting though!
There still is a little bit of play when the retracts are down but not too much!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 43
RE: Blackhorse P-36A Hawk....join here! - 5/3/2010 8:38 PM
Kostas1
Score: 330
Status: offline
...more pics
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 44
RE: Blackhorse P-36A Hawk....join here! - 5/5/2010 9:38 PM
Kostas1
Score: 330
Status: offline
........i'd say now we are ready for the maiden....or at least after a short test run for the engine ...we'll be ready!!!!
Today the day was really difficult....setting the throttle linkage had some mental requirements
and also with all the servos/batteries/extensions d@mnmnmnmnmnmnmnnnn
-A- -B-I-G- -M-E-S-S-
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 45
RE: Blackhorse P-36A Hawk....join here! - 5/9/2010 2:20 AM
Neo gold
Score: 100
Status: offline
Spiro- Wrap!!!....
Hide Signatures
       Post #: 46
RE: Blackhorse P-36A Hawk....join here! - 5/9/2010 12:05 PM
Kostas1
Score: 330
Status: offline
Hahhaaa you're right...
at least i had some spare stickers,
the ones that come in pairs and are marked as "elev." or "ail." or "aux-1" etc.......they did help a lil'bit......
TEST RUN OF THE ENGINE PROB. THIS WEEK
Hide Signatures
       Post #: 47
RE: Blackhorse P-36A Hawk....join here! - 5/16/2010 9:11 AM
Kostas1
Score: 330
Status: offline
..........test run didn't go very well at all..........
and that's because i didn't charge my 12V battery for my sullivan starter...
So,
starting such a big engine was like waiting for
a dream to come true
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 48
RE: Blackhorse P-36A Hawk....join here! - 5/16/2010 2:55 PM
Kostas1
Score: 330
Status: offline
SUCCESS
tHE FINAL and best run...
Hide Signatures
       Post #: 49
RE: Blackhorse P-36A Hawk....join here! - 5/16/2010 7:16 PM
jaav
Score: 106
Status: offline
Just finished my BH P-47 today (well allmost) axles are missing. Are your retracts loose in lock down position? mine have about 15mm play at the end of the shaft. on both. The retract servo is going to be a pain as well..Mine has 5 servos as well in the wing..
Right after a spectacular crash, the pilot yelled out ''Channel 35 clear!
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
