Quest Flat Cat Booster Balance Point    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Model Rockets & Rocketry >> Quest Flat Cat Booster Balance Point
Page: [1]
Login
Quest Flat Cat Booster Balance Point - 3/19/2010 8:52 PM
KitBuilder
Score: 131
Last Login: 6/16/2013
Status: offline
I'm building a few Quest Flat Cats for some demo flights. Instructions say to balance for glider only as well as booster flight.
For glider flight... you balance the glider itself... all good there.
For booster flight you attach glider to the power pod and balance both together. With a B4-2 motor in place, instructions say should balance at the wing root leading edge and you correct by adding wieght to to the pod during this phase, not the glider which makes perfect sense. They only talk of adding weight to the front of the pod which would indicate a tail heavy setup. Mine hang almost at 5 o'clock.. quite nose heavy.
Based on the design..with the majority of weight (w/motor installed) being ahead of the leading edge (I assume the CG in boost mode) i don't see how it could possibly balance.
Anyone have this rocket and experience this or fly it in this nose heavy condition?
Links shows pic where you can see the model and most of weight ahead of CG in boost mode. Adding weight to the tail of the boost pod is still ahdead of the suggested CG..
https://www.discountrocketry.com/level-3-model-rocket-kits/quest-flat-glider-p-444.html
Thanks.
< Message edited by KitBuilder -- 3/19/2010 9:19 PM >
_____________________________
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
       Post #: 1
RE: Quest Flat Cat Booster Balance Point - 3/21/2010 6:37 PM
KitBuilder
Score: 131
Status: offline
FYI... I got some good info from the Yahoo RocketBoostGliders group. iIf anyone is interested in this topic specifically, I reccomend you join.
Rain stopped this morning for a bit and though windy I had to give it a try.
With Balance of the glider at 60% (between 50 and 70 from LE suggested by the thread) ascent was perfectly vertical with a B6-4. Kit calls for a B6-2, but it was nice looking in coast mode with the couple extra seconds at as i arc'd at apogee still connected, then pop. Approx 100' ' diameter circles that lasted about 30 seconds. I know the other two will fly the same way. The other rockets for the school demo this week are tumble, parachute and streamer type recovery so no isuses there.
Next year I need to add this to the mix
http://www.randrmodelaircraft.com/Delta%20Star.htm
Mike -
Hide Signatures
(in reply to KitBuilder)
       Post #: 2
RE: Quest Flat Cat Booster Balance Point - 12/9/2010 9:38 AM
carappliancebilin
Score: 100
Last Login: 12/9/2010
Status: offline
Free Map Card-5" HD Touch Screen GPS Navigator-Bluetooth-Multimedia-Ebook-Photos-Flash-Games-FM-Edog(SZC6005)
Hide Signatures
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.293RCU1
