FantzyPantz
TX, USA Status: offline
Quote-Anyone ever try contact cement? I use Contact cement to join wing pannels and ailerons to coroplast. I first prep the coroplast using the falme/flash method followed by wiping it down with Windex, or Formula 409 window cleaner. So far this method has worked well for me. (Knocks on Balsa) I use Elmers Pro-bond for gluing the wing spars, this creates a strong solid joint. Another thing, that All-purpose Welder Cement is great! I found it all Wally World for under $3, it seems to be the same type of stuff as Goop and Shoe Goo. As far as using CA for gluing coro to coro? I don't know... some guys must have the formula down, because I have had problems with even medium CA peeling away, witch means no sticky. By the way, I'm in the process of finishing a Avistar Trainer Clone, inspired by the Spadet 40. Pics to follow if anyone is interested. I am thinking of calling it Corro-star or Spadistar if the name hasn't been used already. I have been building and flying Spad since last summer. mostly electrics (Mugi and Zagi Clones). I finally converted to to Glow engines and purchased the Avistar ARFwith th OS 46FX to power the thing. My first thought was "ok this is going to turn into a pile of kindling unless I perform a SPAD clone, and practice on it first." V "There are 2 rules for success in life... 1- Never tell anyone everything you know."
