twin engine
Tower Hobbies
Logged in as Guest
  Printable Version
Hangar 9 Piper J-3 Cub 40 - RTF
Seller:  DAVIS300
Details:   $375.00   |  11/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> twin engine
Page: [1]
Login
twin engine - 7/15/2003 8:42:30 PM
flaflyr
Status: offline
i am interested in a twin and am trying to decide between the hobbico twinstar and the twin air 45 from ne aero. the awarf feature of the twinstar is appealing. all comments appreciated. tx
       Post #: 1
Twinstar still available? - 7/15/2003 9:57:07 PM
Scar
Status: offline
If you find a couple TwinStars, make sure to post the location here. I've heard they're out of production. I have one, and I'm not selling it!
The NE Aero twin looks good.
Good luck,
Dave Olson
(in reply to flaflyr)
       Post #: 2
twin engine - 7/15/2003 10:56:15 PM
William Robison
Status: offline
flaflyr:
The TwinStar is indeed out of production. If you find one you will pay a lot for it.
The Twin-Air 45 is an excellent choice for both a first kit and a first twin.
I've never seen the first bad, or even neutral comment about the Twin-Air or about Northeast Aerodynamics, the company that makes it. All comments about both have been positive.
Well, allow me to modify that a little bit. The instruction booklet for the Twin-Air is a little vague in places, but if you read through it a couple times it becomes clear.
[url]www.ne-aero.com[/url]
The kit is $154.95, including postage, to your door.
Bill.
_____________________________
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
       Post #: 3
twin engine - 7/15/2003 11:08:50 PM
tiggerinmk
Status: offline
I can vouch for the Twinstar situation, if you happen to be in the right place at the right time you just might be lucky and find one..
The Twin Air looks like a nice kit, but I came across another option. Morris Hobbies do a couple of twins, one of which is a twin trainer. It might be worth a look, you'll have to ask around to see what people say about it...
[URL=http://morrishobbies.com/product_info.php?cPath=22_150&products_id=442&osCsid=5eb1768bad2dbd51a253e7a97dad3bca]Morris Twin Trainer[/URL]
If you can remain calm, while all around you is chaos...
then you probably haven't completely understood the seriousnes
       Post #: 4
twin engine - 7/15/2003 11:32:21 PM
William Robison
Status: offline
Tigger:
I don't recommed the Morris twin for several reasons.
First, I can't stand profiles.
Second, with the engines so close in and the extreme out thrust, when an engine quits all you notice is a loss of power. You don't learn anything that way.
Third, profiles are ugly.
Fourth, it's not a beginner's airplane. It is small and close coupled, not an easy plane to fly even with both engines running,
Fifth. Did I mention that profiles just look bad?
Bill.
       Post #: 5
twin engine - 7/15/2003 11:51:29 PM
tiggerinmk
Status: offline
Bill,
1. I recently learned of the Morris twins existence and thought I'd present it as an option.
2. Notice that I gave no opinion, just the option.
3. Now I know that you knew about it too but chose not to mention it.
4. I also know that you probably chose not to mention it as you don't like profiles (along with some other aircraft types perhaps?)
5. I don't particularly like profiles either
6. As a profile it would be quick and cheap to build
7. I thought it worth a mention as twin kits/ARF's are a bit thin on the ground
8. I probably won't build one either as I (hopefully) have a Twinstar on the way...
9. I just thought it was an interesting option (did I mention that I'm not that keen on profiles?)
10. Then there's the GP P-38 but that also has two things not going for it: 1. It s a profile & 2. it's not a trainer.....
       Post #: 6
twin engine - 7/16/2003 12:38:03 AM
William Robison
Status: offline
Tigger:
Didn't intend to imply a flame at all, apologies if you got that feeling.
I just don't think the Morris twin "Trainer" is much of a trainer.
And I don't like the looks of a board with wings. Did I mention that?
Haw.
Bill.
       Post #: 7
twin engine - 7/16/2003 1:44:32 AM
tiggerinmk
Status: offline
Looks like I need to offer my apologies for making you think you needed to apoligise for thinking that I thought that you had flamed me? confused yet?
I merely made my own list in the spirit of the list that you compiled...
I think that sorted that out
What about plywood boxes with sticky plastic covering?
       Post #: 8
twin engine - 7/16/2003 2:36:39 AM
William Robison
Status: offline
Tigger:
A plywood box with sticky plastic sounds like a TwinStar to me. Bt that's not why I never got one.
I just didn't like the ABS nose and nacelle covers. To me it just looked chintzy.
Bill.
       Post #: 9
Chintzy ! - 7/16/2003 4:26:09 AM
Robby
Status: offline
William....
Bill
It does not look chintzy...
It IS chintzy, cheezy, cheap, discustin', and flat out ,oppps,
family channel.. Well, you get the idea..
However, currently, I am working on JUST that very thing,, a Twin
Star with NO plastic nose or nacelle covers.. Right now am doing fuse... I am also going to extend out the nose gear as I like the
'long nose' look...
And no, those are not lightening holes you see in the pic
... it was termites,, Thats my story and I'm
gonna stick to it !
Click to see fullsize image.
Click for fullsize
You won't find Nirvanna if you don't have any nerve ...
       Post #: 10
twin engine - 7/16/2003 4:45:26 AM
William Robison
Status: offline
Robby:
Your last post would tend to make one think you're knocking off your own copy of a TwinStar. And going to that much trouble, why not round the corners?
If you made drawings of it many people would probably like copies.
And so far it looks good, square corners and termites notwithstanding.
Bill.
       Post #: 11
twin engine - 7/16/2003 8:36:39 AM
Robby
Status: offline
wellllppp.. It really is a TwinStar.. I am just making a
couple minor changes but wanted to keep most of the 'TwinStar' look so that people will know what it is..
The obvious change will be coloring.. Green,green, and white..
The nose will be longer with extended nose wheel..
The nacelles will be a tad larger for bigger fuel tanks as I will be
using motors that are .40 or larger..
Oh, and because I like playing with rudders I am moving rudder hinge line forward just a 'tad' ...
I do have a TwinStar here that I did round the top and the
bottom, as well as minor extention to nose to be rid of the plastic
and make it look more like a real plane..
If there is an interest I can cronicle my doing with the TwinStar.
Can't say what I am doing is right or wrong, its just what *I* am
doing..
       Post #: 12
twin engine - 7/17/2003 11:00:53 PM
tiggerinmk
Status: offline
Well, my Twinstar arrived yesterday. Brand spanking new in the box. I see what you mean about those chintzy plastic parts now....
       Post #: 13
twin engine - 7/18/2003 8:25:05 PM
Sawyer692-RCU
Status: offline
[QUOTE]Originally posted by tiggerinva
I see what you mean about those chintzy plastic parts now.... [/QUOTE]
The nacelle covers will break on you. I had one break and fly up in flight and created an "airbreak" situation. I then layed some fiberglass cloth on the inside and epoxied them. No more problems.
BTW, my roomate has a RTF Twinstar he is looking to get rid of. If anyone is interested I can get a price from him......
Mike
       Post #: 14
twin engine - 7/19/2003 12:29:43 AM
tiggerinmk
Status: offline
[QUOTE]Originally posted by Sawyer692
BTW, my roomate has a RTF Twinstar he is looking to get rid of. If anyone is interested I can get a price from him...... [/QUOTE]
Get a picture of it and plonk it in the classified section here for a hugely inflated price, It'll be sold in minutes...
Thanks, for the nacelle info...
       Post #: 15
twin engine - 7/20/2003 3:39:05 PM
bkf1970
Status: offline
Going back to the Northeast Aero. Twin -Air .45. How would it fly with O.S. .40 fps? I have two of them and am looking for something to do with them.
