RCS Support = Great
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-50cc Gas Engine by Southeast R/C Engines, LLC.
Seller:  XYZUSA
Details:   $259.95   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> ZDZ & RCS Support >> RCS Support = Great
Page: [1]
Login
RCS Support = Great - 7/16/2003 12:10:40 AM
rthorne
Status: offline
A quick kudos to RCS.
The choke plate on my ZDZ80 fell off. It appears that the threads in the shaft gave a bit, maybe due to vibration? and the screw came loose.
At any rate a quick email to RCS and Andrea replies quickly stating that there are new parts in the mail today so I can repair the motor and get it flying again.
So not only did I get a quick response, I also have parts on the way so I can repair the engine without sending it back.
Thanks RCS!!
_____________________________
Rich Thorne
Amarillo, TX
ARS: N5ZC
AMA: N5ZC
       Post #: 1
RCS Support = Great - 7/16/2003 7:42:36 AM
Big_Bird
Status: offline
Rich, of all the parts on an engine, those two little screws (choke, and throttle plate) scare the begeebers out of me. I severely lunched out a G-62 when one went flying through the engine.
I assume that it did no damage to yours when you lost it. Right?
Ken
Ken
WACO Brotherhood #70
(in reply to rthorne)
       Post #: 2
RCS Support = Great - 7/16/2003 7:58:05 AM
rthorne
Status: offline
Hi Ken:
No, I don't think I have a problem. I carefully turned the engine over and no problem that I could see. I was in the middle of an upline when the engine started burping then quit. I can only assume gravity did its job and the screw fell away from the carb. I ought to check the inside of the fuse, there is a chance the screw is inside the fuse some where.
I was flying just a tad down wind. When I heard the engine problem I pulled up to get some altitude and made a left down wind turn. When the engine quit I was set up perfectly for my up wind turn and approach.
Are you going to mount the motor on your Corsair? Your going to like it. It takes my 23.5 lb 330 vertical as far as the eye can see.
Rich Thorne
Amarillo, TX
ARS: N5ZC
AMA: N5ZC
       Post #: 3
RCS Support = Great - 7/16/2003 8:28:12 AM
Big_Bird
Status: offline
Thank goodness that your engine didn't ingest it.
I have a Brison 5.8 in the Corsair. It really hauls it with a 24x12 prop. My new ZDZ 80 (two gallons of fuel through it so far on the test stand) is going in the Hostetler 33% Super Decathlon that I'm in the painting stages on.
Ken
Ken
       Post #: 4
RCS Support = Great - 7/16/2003 11:46:09 PM
454
Status: offline
for god sake dont take the engine apart to look and check, as I did because mike will send it back to you and void your warrenty for you
If your not crashing do it lower
       Post #: 5
RCS Support = Great - 7/17/2003 12:03:37 AM
Mike Dooley/RCS
Status: offline
454,
Not entirely true. Yes, If the engine has been dissasembled and a repair attempted by the customer, we simply cannot honor the warranty if a problem occurs.
Mike Dooley
RC Showcase
       Post #: 6
RCS Support = Great - 7/17/2003 4:39:37 AM
kevin mcgrath
Status: offline
I dont think there is an engine manufacturer in the business who is going to honor a warranty where disassembly and repair has been attempted,and the results then sent in to the seller.
If I was in any doubt Id contact the seller before attempting anything ,and as a matter of fact thats exactly what I did with RCS a couple of weeks ago,and the results were entirely to my satisfaction.
There may very well be other distributors who stand behind their engines,but I have never personally found one as good as RCS.
Kevin
MAAC 6401L,CD.
       Post #: 7
RCS Support = Great - 7/17/2003 4:44:57 AM
rthorne
Status: offline
I agree Kevin:
I sent my email to RCS with a few options, one of which was to drill and retapp the choke shaft. They opted to send me new parts which I prefered. But I would not do anything to the engine without prior approval.
Anyways this thread is getting off subject.
For any future buyers of ZDZ or RCS engines don't hesitate. There is excellent support if needed.
Rich Thorne
Amarillo, TX
ARS: N5ZC
AMA: N5ZC
       Post #: 8
RCS Support = Great - 7/19/2003 9:53:53 PM
454
Status: offline
the engine was disassembled because of a hard dead stick landing which resulted in the engine getting rocks and dirt in it so to continue running the engine i took it apart to clean it I didn't know that was against warranty
       Post #: 9
RCS Support = Great - 7/20/2003 4:29:12 PM
kevin mcgrath
Status: offline
Considering the engine is a rear intake it must have been more like a crash than a dead stick landing
Kevin
MAAC 6401L,CD.
       Post #: 10
RCS Support = Great - 7/20/2003 8:53:51 PM
454
Status: offline
with the piston down the cylinder is open the dirt interred through the exhaust
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.688RCU5
