Tomy Model MT35 gasser    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Tachometer Readings >> Tomy Model MT35 gasser
Page: [1]
Login
Tomy Model MT35 gasser - 3/25/2010 12:02 AM
PlaneKrazee
Score: 205
Last Login: 6/21/2012
Status: offline
Weather: 100% humidity, temp 46 degrees. Stock exhaust. The engine has about 3/4 gallon thru it now.
APC18X6W 8300
APC 19x8W 7250
Bolly Carbon 18x10 8000
Bolly 16.5x10 3 blade 7700
Mejzlik 19x8 7400
Mejzlik 20x6 8000
Mejzlik 20x8 7000
Vess 19A 7630
Based on the rpm of the APC 18x6W this engine is not a revver but a puller.
_____________________________
a never-ending battle for truth, justice and the American way
Hide Signatures
       Post #: 1
RE: Tomy Model MT35 gasser - 3/25/2010 3:43 PM
nitrometan
Score: 100
Last Login: 4/13/2012
Status: offline
Good values.I thought that MT 35 turns a little faster.Actually I am surprised that my Super Tigre ST 3250 converted to gas performs better with Menz S 18x10 at 8200,Menz S 19x8 at 7800 rpm,Menz S 20X9 7000 rpm.200cc volume canister muffler.Menz S are hi-load propellers.The engine is also a torquer,does not like revving over 8000 rpm.
I am curious after 2-3 gallons what numbers would you have.
Two questions id you mesured the temperature?
How looks like vibration level?
Hide Signatures
(in reply to PlaneKrazee)
       Post #: 2
RE: Tomy Model MT35 gasser - 3/25/2010 4:09 PM
PlaneKrazee
Score: 205
Status: offline
The vibration seems low. The rpm may increase if I change oil. I added one oz of castor to a gallon of mix and got more rpm out of the DLE30.
I need to remount the MT35 and DLE30 to compare vibration levels more accurately.
Hide Signatures
(in reply to nitrometan)
       Post #: 3
RE: Tomy Model MT35 gasser - 3/25/2010 6:43 PM
nitrometan
Score: 100
Status: offline
After 1 hour running time,try Motul 800 35:1 mix and keep this ratio.You will have a very long-lasting engine doing so.
What about Temperature?(Celsius...)
My converted stays around 125 celsius WOT 2 minutes with 20X9,12:1 mix (because of bronze bushing)
Vibrates a little stronger on gas,but not so strong.
Hide Signatures
       Post #: 4
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Tachometer Readings >> Tomy Model MT35 gasser
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.219RCU1
