Bajaskunkworks 2-Speed for baja 5b / 5t    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> Bajaskunkworks 2-Speed for baja 5b / 5t
Page: [1] 2   next >   >>
Login
Bajaskunkworks 2-Speed for baja 5b / 5t - 3/26/2010 5:36 AM
TGNman
Score: 100
Last Login: 6/12/2012
Status: offline
Hello RCU
I dont get much of a chance to get into this forum but as a paid sponsor we do have plans to try to participate more. I thought it would be a good time to let everyone know that the Baja Skunkworks HPI baja 5b/5t 2-speed if almost here. The years of testing and improving if over and production has started. The majority of parts are in stock and every couple days we get another piece of the puzzle in stock. We will post details and images below but you can get all the up to date info by checking out this link: http://www.teamgonads.com/18116.html
Make sure to read about all the trick features of this 2-speed below:
That's right baja lovers, the wait is almost over. TGN is working closely with BajaSkunkWorks to bring you the long awaited for hpi baja 2-speed transmission within weeks of now.
BajaSkunkWorks is known for making some of the coolest custom built cars and trucks with features like, electic start, reverse and even twin gas engines. You can trust this 2-speed was designed and built by someone you can trust. See the just some of the major details below.
- Over three years of development, several revisions, hundreds of man hours, broken relationships, blood sweat, and tears invested into this product; yes it really is rocket science.
- Bombproof for those 50lb billet bajas.
- Dual bearing supported second gear.
- Dual engagement pawls for solid positive shifting.
- Quad strike pins for maximum redundancy and solid shifting.
- Captured and supported strike pins, these pin will never fall off or out.
- All steel parts are heat treated for maximum wear and reliability.
- Manufactured from Nine different materials carefully selected for their qualities and matched to the components to achieve the ultimate performance and reliability.
- Includes second gear 51:23 for initial gearing. More option will be available at a later date. - Gears are made by world renowned RC gear specialist Robinson Racing. They are case hardened for maximum strength, wear, and reliability.
- The shift point is externally adjustable. With out the gear cover the shift point can be adjusted in a mater of seconds.
- The shift point is designed to be set and never loose adjustment. Other designs do not have this feature. As a result the shift point has to constantly be reset.
- First gear is designed around the OEM HPI Baja spur gears. You can use any gear combination that is compatible with the HPI gear carrier and clutch system.
- Includes a vacuum formed ABS gear cover and stand-offs.
- Designed to work exclusively with the Turtle Racing HD Clutch System. We are working on a model for the standard clutch systems.
http://www.youtube.com/watch?v=ATziWQEs14w
http://vimeo.com/4624192
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/ATziWQEs14w&hl=en_US&fs=1&">
<object width="400" height="220"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=4624192&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=4624192&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="220">Baja Skunkworks Two Speed Rev 02 Testing from Brice Arnold on Vimeo.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Owner of TGN
Hide Signatures
       Post #: 1
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/26/2010 7:22 AM
BKNate
Score: 100
Last Login: 1/10/2012
Status: offline
How come you guys didn'y offer a higher gear ratio other than 51/23? I think alot of guys who ran off-road and short distance would rather a closer gear ratio than a 57/17-51/23, I think thats a real big jump in gears if the average Baja owner is going to be doing some off-roading and short distance high speed runs.
Representing Representing BadBoyHobby
Hide Signatures
(in reply to TGNman)
       Post #: 2
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/26/2010 7:54 AM
brice_arnold
Score: 120
Last Login: 12/30/2012
Status: offline
quote:
ORIGINAL: Mr.5thScale
We will eventually offer several gearing options. Because we are working with Robinson Racing to manufacture the gears we basically have to do gear runs of 250 sets at a time. Obviously it would be very cost prohibitive for us to run several gear sizes right out the door. We felt that there are more people interested in hitting top speeds and drag racing then dirt. I have already talked to some dirt racers about lower gearing for second. The next gear set that we will offer will probably be a 19:55 or 20:54 combination.
< Message edited by brice_arnold -- 3/26/2010 8:16 AM >
Owner and Operator of Baja Skunkworks
Hide Signatures
(in reply to BKNate)
       Post #: 3
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/26/2010 8:08 AM
csp1971
Score: 100
Last Login: 3/18/2013
Status: offline
Great job on the 2 speed brice, can't wait to get one!
Hide Signatures
(in reply to brice_arnold)
       Post #: 4
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/26/2010 8:25 AM
brice_arnold
Score: 120
Status: offline
As TGN has posted on the essential release of this product, I will go ahead and elaborate on the production status of this product to keep you guys up to date. We have been working very closely with TGN to get this out to you guys. In fact TGN is credited for having the first functional two-speed prototype for the HPI baja. This was 3 RCX's ago. I came in a little after that first one and started from the ground up with my own version.
Here is where we are with production:
The final Two speed design consists of roughly 16 machined parts and 30 bits of hardware. To this date we have about 6 of 16 machined parts and all of the hardware ready to kit and ship to TGN. Over the next couple of weeks we should receive all of our parts from the various shops that we have commissioned and get kits into TGN hands within the first week of April. As the parts roll in I will go ahead and keep you guys updated.
Here is what we have so far.
Here are the pinion and spur, case hardened gears that will last for ever. This is the 23:51 combo.
Here is the first gear carrier. This resembles a stock HPI gear carrier. In doing this you can now use what ever gear combination you have in your toolbox. On our test rig we have been running the stock 57T plastic spur gear without any problems.
Here is the second pinion adaptor. This is designed to bolt up to the turtle racing pinions
Here is the outer clutch cover.
Thats it for now we should have some more parts to show in a couple of days.
Hide Signatures
       Post #: 5
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/26/2010 8:31 AM
brice_arnold
Score: 120
Status: offline
Also wanted to let you guys know that we will be posting some more video this weekend. We are going to get some footage on an essentially bone stock 5T with only a pipe, turtle racing clutch, and two-speed upgrade. We would like to give you guys an idea what what to expect from this product with the minimal requirements for your vehicle. We are also going to get some off-road footage which has yet to be shown with the two-speed. On top of that we will get some footage showing just how easy it is to adjust the shift point of the clutch. The clutch is externally adjustable with nothing to take apart.
Hide Signatures
       Post #: 6
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/26/2010 8:58 AM
BKNate
Score: 100
Status: offline
It looks heavy, will you be offering it in alloy gear options for the true road racers? The lighter the better at least that is what they say.
Hide Signatures
       Post #: 7
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/26/2010 9:11 AM
brice_arnold
Score: 120
Status: offline
Technically the gears are alloy. Alloy simple means a mixture of two or more materials. I assume you are referring to aluminum though. In the past I have worked with and used several aluminum gears. In general, aluminum gears do not hold up and wear out very quickly. I will be honest with you, this product was designed for the basher in mind with redundant systems to support the assembly. It was designed to hold up to the bashers running 50lb cars. As a result it is not light weight.
However, on our prototypes we were actually running plastic gears which held up OK. Because of the huge jump from a 17:57 to a 24:50 (this is what we had for awhile) we were shearing teeth from the gears. Other than that they were fine. In fact I still have one that I was running before switching to a steel gear. We have looked at molding the second gear from a composite plastic for the larger spur gears. This would significantly help out with the weight and should hold up for the racers.
At least with this current design, you can select plastic gears for the first gear.
< Message edited by brice_arnold -- 3/26/2010 6:04 PM >
Hide Signatures
       Post #: 8
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/26/2010 12:42 PM
On2_n_On4
Score: 131
Last Login: 5/15/2013
Status: offline
I will keep this-1 short
Inferno GT2 - RS4 2 - Baja 5T - Revo 3.POS - Tmaxx 3.POS
Hide Signatures
       Post #: 9
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/30/2010 8:01 AM
brice_arnold
Score: 120
Status: offline
OK got another piece of the puzzle in today. This is the clutch housing.
I went ahead and did a mock-up of the assembly. We are still waiting on the layshaft, and a couple of clutch parts. I will also get some photos up this weekend of the gear-cover.
Gear carrier with bearing pressed in.
First gear with a stock HPI 57T gear.
Second gear bolted up to the clutch housing
Everything assembled up to a mock layshaft
Hide Signatures
(in reply to On2_n_On4)
       Post #: 10
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/30/2010 6:40 PM
savagecommander
Score: 171
Last Login: 5/12/2013
Status: offline
looks like the fight has begun..... lets hope nobody gets banned....
Hide Signatures
       Post #: 11
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 3/30/2010 7:47 PM
roccos_van
Score: 100
Last Login: 7/11/2011
Status: offline
Nice work. I wish you nothing but the best in getting this product to market.
Savage XL
Hide Signatures
(in reply to savagecommander)
       Post #: 12
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/1/2010 8:55 AM
badboy2
Score: 104
Last Login: 5/24/2013
Status: online
Any vids yet ??lookin at the pix theres only 1 pinion,so does that mean you will be using the pinion from tr clutch?with all these 2 speeds coming out,we prolly need a cover too for offroad use.
2 BAJA 5T ,1 BAJA 5B,NUTECH MMT
Hide Signatures
(in reply to roccos_van)
       Post #: 13
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/1/2010 9:26 AM
JCBaja
Score: 100
Last Login: 4/7/2010
Status: offline
I'm curious about how much it weighs. Seems like there will be a lot of rotating mass.
Can you tell us how much this setup weighs compared to the stock setup with a TR pinion?
I like the gear ratios you have chosen and think it will work well, at least for my application and engine/pipe combo.
Hide Signatures
(in reply to badboy2)
       Post #: 14
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/1/2010 11:10 AM
brice_arnold
Score: 120
Status: offline
quote:
ORIGINAL: badboy2
Really dude? You have now lost all credibility. You shouldn't act so ignorant it just makes you out to be a troll a lier or a *fill in the blank*. There are several videos out there of our two speed. We were the first to post videos. If you read the first post and any of my countless posts on this product you would know that it uses the stock tr gears for first. You also know that we are including a cover because, again, it's in the first post and you have even commented on our cover in the other forum.
Here is your post from two days ago in case you have already forgotten
quote:
ORIGINAL: badboy2
lookin good!!the cover would be important pthe piece too..for the bashers like me.
According to your posts you pre-ordered your BRCP two-speed two or three weeks ago. How's that going for you. Why don't you stop digging around our two-speed threads and keep to your self.
Hide Signatures
       Post #: 15
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/1/2010 11:20 AM
brice_arnold
Score: 120
Status: offline
quote:
ORIGINAL: JCBaja
I guess it depends on what gears you use. Our second gears where made thinner to help save weight. And you can use a plastic spur gear for first. I admit that it's not the lightest that it could be. However you are not forced to use two sets of steel gears, though this is an option should you choose.
We designed this for the bashers. As a result it is beefy with redundancy and over-engineered parts. This is more of a bashing product than a racing product. There are fundamental differences between the two. I have had several inquires though from racers and we will be looking at different gear sets as well as seeing what we can do to lighten things up. With each production run we can offer more options and design tweaks to improve based on the consumers needs. Fort the first run the we decided to be prudent and make something that wasn't going to break-down.
Hide Signatures
(in reply to JCBaja)
       Post #: 16
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/1/2010 11:32 AM
badboy2
Score: 104
Status: online
oh well i guess i wasnt really reading hehhehe...yea i preordered the brcp 2speed im just waiting...with all the hype about these 2 speeds u cant help yourself but look all the threads about them..about the cover ,its good yours comes wiht it ,,i hope it fits with the other one or i hope i can buy it separate.ive seen an old video of bsw 2 speed ..i just want to see the vid that u said u were gonna do last weekend..so if theres one then a link would be nice..cant i make a comment in any forum about this?i dont have anything againts your product,i dont even know u for u to make this personal as it seems like it.and im tellin u im nothin in this rc world.u wont gain or lose anything from me..i still ask people help about problems i encounter on my rc. and about trolling arent u doin the same thing ?post the same thing in the other forums?if thats whats it meant?
Hide Signatures
       Post #: 17
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/1/2010 11:41 AM
brice_arnold
Score: 120
Status: offline
quote:
ORIGINAL: badboy2
Actually what I am doing is not trolling. I am being up front and honest. I can let all the passive aggressive crap slide but when you start spreading lies about my product I will call you on it where ever I can. All of you guys involved in this are about as sneaky as an elephant in a china shop. Many people have noticed it and a getting fed-up.
As far as the new footage we have video but haven't posted it. We are trying to get some more footage on different terrains before posting anything.
Hide Signatures
       Post #: 18
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/1/2010 12:07 PM
badboy2
Score: 104
Status: online
why would i even lie about your product when im not even gonna gain anything on this?idk call it a lie i dont care,im not gaining or losing anything..like i said im not gonna post in your thread anymore..goodluck hope u get it done before 2012 !!!
Hide Signatures
       Post #: 19
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/1/2010 1:58 PM
Mudgy
Score: 100
Last Login: 5/26/2013
Status: offline
Hey Brice, that's a wicked bit of kit you made there mate. Hats off to you for getting into the jump seat before the manufacturer ( and the other fellas, too)
If it's a go'er, would you sell the concept to HPI?
Or is there an intellectual property can of worms there?
either way, it looks killer, mate.
Hide Signatures
       Post #: 20
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/1/2010 5:02 PM
JariV
Score: 110
Last Login: 4/25/2013
Status: offline
When do we get the possibility to buy one? Latest estimation?
Hide Signatures
(in reply to Mudgy)
       Post #: 21
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/1/2010 10:01 PM
savagecommander
Score: 171
Status: offline
quote:
ORIGINAL: Mudgy
looks just like a supersized version of HPI's to me anyway....
Hide Signatures
(in reply to Mudgy)
       Post #: 22
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/2/2010 2:33 AM
BKNate
Score: 100
Status: offline
Why is there so much anger going between the 2 (2) speed companys???? I was always told when you speak to highly of your yourself/product  you/it will fail. All I"m saying is it doesn't matter who put out the 2 speed first or who made it first, whats going to count is the company that has the most versatile product, and I'll leave it like that. Why Can't We All Just Get Along
Hide Signatures
       Post #: 23
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/2/2010 2:50 AM
clubin
Score: 110
Last Login: 7/1/2012
Status: offline
Great looking product, and design. I will look forward to adding it to my HPI T it will look good on there with the rest of your products.
Nutech Mega Monster - Aluminum FG MB - HPI 5T - HPI 5b - I own two Redcat''''s too, but don''''t ask.
Hide Signatures
       Post #: 24
RE: Bajaskunkworks 2-Speed for baja 5b / 5t - 4/2/2010 4:18 AM
brice_arnold
Score: 120
Status: offline
Why is there so much anger going between the 2 (2) speed companys???? I was always told when you speak to highly of your yourself/product  you/it will fail. All I''m saying is it doesn't matter who put out the 2 speed first or who made it first, whats going to count is the company that has the most versatile product, and I'll leave it like that. Why Can't We All Just Get Along
I would suggest in the nicest way possible that you re-read the threads. I have no issue with the other companies two-speed. I welcome the competition. I take issue with people that start spreading mis-information about my product. All I care about is my product I could care less what the other guy is doing. I will defend my product to the teeth. As of yet I have not said anything about the other companies two-speed. I have only posted to correct other peoples false statements about my product.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.328RCU1
