revo 3.3 slipper clutch keeps coming loose    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> revo 3.3 slipper clutch keeps coming loose
Page: [1]
Login
revo 3.3 slipper clutch keeps coming loose - 3/30/2010 8:13 AM
Mustang08
Score: 100
Last Login: 8/17/2011
Status: offline
 Hey all, I just replaced a spur gear on my revo 3.3 and tighten it to where i can push it barley with my finger as i have a allen wrench on the other end. I took it out for a drive and for some reason the lock nut on the end kept coming loose causing me to have no drive. I have replaced this lock nut with a new nut but still it comes loose again. Any ideas on what it could be?
Hide Signatures
       Post #: 1
RE: revo 3.3 slipper clutch keeps coming loose - 3/30/2010 8:15 AM
MPevine11
Score: 101
Last Login: 3/12/2013
Status: offline
try replacing it again. i had the same problem, how long since you replaced it?
_____________________________
Revo 5309: OS .21 TM, tekno, Spektrum, Buku*
Jato 5507: Work in Progress
Hide Signatures
(in reply to Mustang08)
       Post #: 2
RE: revo 3.3 slipper clutch keeps coming loose - 3/30/2010 3:47 PM
Mustang08
Score: 100
Status: offline
Ok ill try another lock nut and see what happens and it was just replaced about 10 days ago
Hide Signatures
(in reply to MPevine11)
       Post #: 3
RE: revo 3.3 slipper clutch keeps coming loose - 3/30/2010 4:39 PM
Snook Man
Score: 115
Last Login: 12/25/2012
Status: offline
Make sure the 2 washers behind the nut are installed in this () position and that they are not flattened out from being torqued down too tight.
The washers are what help keep the nut from backing off and if they are flattend out, it will.
Rub some dirt on it, it''ll quit bleedin.
Hide Signatures
       Post #: 4
RE: revo 3.3 slipper clutch keeps coming loose - 3/30/2010 6:46 PM
MPevine11
Score: 101
Status: offline
good call forgot about the washers guess i should of mentioned that
Hide Signatures
(in reply to Snook Man)
       Post #: 5
RE: revo 3.3 slipper clutch keeps coming loose - 3/30/2010 9:18 PM
Mustang08
Score: 100
Status: offline
def will check that out to
Hide Signatures
       Post #: 6
RE: revo 3.3 slipper clutch keeps coming loose - 3/31/2010 4:04 AM
nitro_79
Score: 100
Last Login: 6/12/2010
Status: offline
its only a temp fix but if you do not have any more nuts, you can heat the old ones up a little and melt down the nylon and they work just like new.
Hide Signatures
       Post #: 7
RE: revo 3.3 slipper clutch keeps coming loose - 3/31/2010 4:20 AM
Mustang08
Score: 100
Status: offline
Thats a good idea too but i have a couple nuts since i have ten of traxxas trucks just cant figure out y a new nut did it also but gonna check the washers an such when i get out of work tonight
Hide Signatures
(in reply to nitro_79)
       Post #: 8
RE: revo 3.3 slipper clutch keeps coming loose - 3/31/2010 5:05 AM
crispyspa
Score: 137
Last Login: 5/23/2013
Status: offline
Blue locktite FTW. It locks the threads without being a bear to remove.
After all is said and done, more is said than done.
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
