RE: Viper Jet 2M Pointers/ tips.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Viper Jet 2M Pointers/ tips.
Page: <<   < prev  11 12 13 14 15 16 17 18 19 [20]
Login
RE: Viper Jet 2M Pointers/ tips. - 12/4/2012 6:09 PM
RCISFUN
Score: 105
Last Login: 6/20/2013
Status: offline
No posts since September, time to kick start this thread again
_____________________________
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
(in reply to Ali)
       Post #: 476
RE: Viper Jet 2M Pointers/ tips. - 12/4/2012 6:16 PM
k_sonn
Score: 123
Status: offline
I have one on order that should be here in a couple of weeks.  Plan to start a build thread once I've finished the CARF Mustang I'm working on.
Kirk
Schubeler USA Demo Team
"Schubeler - The Future Of Electric Jets"
Hide Signatures
(in reply to RCISFUN)
       Post #: 477
RE: Viper Jet 2M Pointers/ tips. - 12/4/2012 6:41 PM
furycham
Score: 100
Last Login: 5/4/2013
Status: offline
Eight months ago I had a minor crash with my Viper because for some reason the carbon tube of the elevator broke in flight causing flutter. Now she is flying better than before . Take a look at this video of the 2nd maiden flight.
http://youtu.be/E5hLXaI5KRQ
Vic
SM Viper 2M with JC Cheetah/SM F-86 with JC Rabbit 100
Hide Signatures
(in reply to k_sonn)
       Post #: 478
RE: Viper Jet 2M Pointers/ tips. - 12/5/2012 8:57 PM
sharam
Score: 105
Status: offline
I am planning on buying one of these 2M Viper Skymaster Jets!  I have read the entire thread - lots of good info in here, thanks to all of you.  This will be my first jet.  I have a quite a bit of experience flying helicopters and large scale prop planes.  My 80" span WWII Zero does ~ 130mph, so I am used to flying fast and flying "the silhouette."
What color schemes do you guys recommend?  I like the paint in the mold red and white.  I understand paint post-mold can add more weight.
I am planning to install a 100 class turbine.
Any thoughts ore ideas will be appreciated!  Thanks in advance.
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
(in reply to furycham)
       Post #: 479
RE: Viper Jet 2M Pointers/ tips. - 12/6/2012 1:47 AM
RCISFUN
Score: 105
Status: offline
Hey Sharam
A 100 class turbine will be fine...
The paint out of the mold looks much better (i.e. no seam lines etc) and I can't see much weight difference.
Rich
Hide Signatures
(in reply to sharam)
       Post #: 480
RE: Viper Jet 2M Pointers/ tips. - 12/7/2012 7:34 AM
sharam
Score: 105
Status: offline
Rich,
Thanks for the reply.  Tell me about the Jet Central Rabbit please.  I am curious as to how it compares with the JetCat 100RX.
I would appreciate your input.
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
       Post #: 481
RE: Viper Jet 2M Pointers/ tips. - 12/7/2012 3:06 PM
RCISFUN
Score: 105
Status: offline
http://www.jetcentral.com.mx/rabbit.html
22 Lbs Kero Start, you won't be sorry
Click to see fullsize image.
Click for fullsize
Click to see the file in new window.Attachment.pdf
Rich
Hide Signatures
       Post #: 482
RE: Viper Jet 2M Pointers/ tips. - 12/8/2012 8:58 PM
sharam
Score: 105
Status: offline
 Thanks, anyone else have any comments about the Rabbit?
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
       Post #: 483
RE: Viper Jet 2M Pointers/ tips. - 4/19/2013 4:43 PM
luckyflyer
Score: 105
Status: offline
Has anyone replaced their Viper's aluminum (12 oz) wing tube with a lighter carbon fiber tube? graph tech rc has one with a .040 wall thickness that weighs 5.2 oz
Hide Signatures
       Post #: 484
RE: Viper Jet 2M Pointers/ tips. - 4/20/2013 7:13 AM
luckyflyer
Score: 105
Status: offline
No one has even thought about doing this to their Viper?
Hide Signatures
(in reply to luckyflyer)
       Post #: 485
RE: Viper Jet 2M Pointers/ tips. - 4/20/2013 12:21 PM
RCISFUN
Score: 105
Status: offline
Is there an issue with the Alum spar?
Rich
Hide Signatures
       Post #: 486
RE: Viper Jet 2M Pointers/ tips. - 4/20/2013 4:07 PM
luckyflyer
Score: 105
Status: offline
Nothing other than its weight.
Hide Signatures
       Post #: 487
RE: Viper Jet 2M Pointers/ tips. - 4/21/2013 11:27 AM
richard.pursall@btinternet.com
Score: 100
Last Login: 6/4/2013
Status: offline
Guys I need to warn you all about the clearance between the flaps/ailerons and the wing when they close.- Last July (the hottest day of the year) I had my viper set up at our club in the blazing sunshine, - turned on the rx and did the usual checks. Only to find when lowering the flaps the left one would not go back up! - it was catching on the wing!- the heat of the sun was doing its work.- I spent ages sanding down these issues on the build but obviously not enough. I then noticed the right aileron was doing exactly the same thing! - out with a scuff board and some grease and problem solved ( I thought!!) - I had a flight and it was probably my best to date - half hour later and flight No 2, - took off as normal, plenty of power then went into a right bank - as soon as I went to tuck the flaps up I knew something was wrong - there was a slight hesitation, the nose dropped and she spiralled to the ground!!! - huge explosion I lost everything! ( my worst nightmare come true!.....gutted!)
So when I went to put the flaps back home I can only assume the left one stayed stuck down which caused an aileron effect etc (Ali has confirmed this ) so be warned guys - make sure those gaps are well sanded down!
So here I am now with out a jet, ( yes its taken me all this time to recover!)- ive been in touch with Ali and im very interested in the Futura 1.9m. My only gripe with the viper was it took plenty long enough to get off the ground (p80se) - it seems the futura by all accounts might rotate a little quicker ( I would use a p100rx) but I was wondering if any of you guys out there have any experience with the futura and particularly any one with experience in flying the viper2m and the futura1.9m to give a good comparison?
Just want to get as much info as poss from everyone before I make the next big spend!
Best regards
Rich P
Hide Signatures
       Post #: 488
RE: Viper Jet 2M Pointers/ tips. - 5/3/2013 3:41 PM
luckyflyer
Score: 105
Status: offline
To the folks that have built the Viper, do you epoxy the keying slots on the rails that the turbine mounts to or is the turbine its self used to hold the rails in their keying slots?
Hide Signatures
       Post #: 489
RE: Viper Jet 2M Pointers/ tips. - 5/3/2013 5:02 PM
BluFox
Score: 100
Last Login: 6/19/2013
Status: offline
Mark:
With the three 2m Vipers built by Bill Hatcher and myself, (make that 4) we trial fit the turbine mount rails then Hysol in place. We put aside for 24 hours. This completes the rigid bond/assembly between the two formers/bulkheads.
BTW, when installing your Cheetah, place the turbine on the rails with the name Cheetah toward the top of the fuselage. Therefore, from the bottom through the hatch, you will see the turbine but not the turbine name. Nozzle should be no more than 1" from the entrance to the metal pipe. . .no less than 3/4." This will give you optimum performance and proper cooling for the pipe.
Regards,
Eric
Managing Director
Jet Central Turbines
Hide Signatures
       Post #: 490
RE: Viper Jet 2M Pointers/ tips. - 5/4/2013 12:10 AM
furycham
Score: 100
Status: offline
This is what I did.
Click for fullsize
Click for fullsize
Vic
Hide Signatures
(in reply to BluFox)
       Post #: 491
RE: Viper Jet 2M Pointers/ tips. - 5/4/2013 2:10 AM
luckyflyer
Score: 105
Status: offline
It seems that the bell mouth supplied by SM on my Viper is noticeably different than the other SM supplied bell mouths . The large end opening is a whopping 5.5 inches across and 2.5 inches long. I'm thinking of cutting it back some because its so wide it interferes with the mounting rails.[image]
Click for fullsize
Hide Signatures
       Post #: 492
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.375RCU1
