marquisvns -> RE: KingTech K-80 (1/24/2011 7:36 AM)
Kevin, sounds like you have way too much propane pumped into the chamber, K-80 and many other turbines don't need a whole lot to be light up. The ratio between propane and oxygen has to be proportional. The slightest will be able to get the chamber lit and it is then that you want to introduce a bit more to get it up to over 100C and then the fuel ramp will take over. Are you using on board or external? I find external really is the way to go, nice and simple, plus you could really increase the propane when it is most needed, and that's after the initial ignition. Barry
