RE: Another 'HOTS' only bigger !    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Another 'HOTS' only bigger !
Page: <<   < prev  1 [2] 3 4 5 6   next >   >>
Login
RE: Another 'HOTS' only bigger ! - 4/7/2010 4:32 AM
john josey
Score: 110
Last Login: 5/19/2013
Status: offline
I decided to add fusalage doublers to give the wing a better seat, a good anchor point for the wing mounting plate and just to help stiffen the fusalage in general.
The wing mounting plate is epoxied in place with 1/2" triangular stock on the underside.
Hide Signatures
(in reply to john josey)
       Post #: 26
RE: Another 'HOTS' only bigger ! - 4/7/2010 4:41 AM
john josey
Score: 110
Status: offline
I just used a piece of scrap 1/4" balsa for a better join at the tail end.
Hide Signatures
       Post #: 27
RE: Another 'HOTS' only bigger ! - 4/7/2010 4:43 AM
TimT2000
Score: 103
Last Login: 2/27/2013
Status: offline
This is my favorit project going on right now,, just killer.  I will give you $500
for an ARC one.  Why the heck did they stop making these anyway?
Tim
_____________________________
You know your landing gear was up when it takes full power to taxi to the ramp.
Hide Signatures
       Post #: 28
RE: Another 'HOTS' only bigger ! - 4/7/2010 4:49 AM
john josey
Score: 110
Status: offline
I added some stringers to help with the bottom sheeting, tailplane mount and a couple of vertical ones to help with the mounting of the snakes.
< Message edited by john josey -- 4/7/2010 6:31 AM >
Hide Signatures
       Post #: 29
RE: Another 'HOTS' only bigger ! - 4/7/2010 4:53 AM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: TimT2000
Tim
Hi Tim,
Thats a question i`ve been asking myself for a while now. If someone was to aquire the rights and produce kits or even ARTF`s, surely they would have  a winner ?
Hide Signatures
(in reply to TimT2000)
       Post #: 30
RE: Another 'HOTS' only bigger ! - 4/7/2010 5:03 AM
john josey
Score: 110
Status: offline
This is the first 'fitting' of the wing, i only shaped the very centre of the leading edge, just enough to allow me to fit it.
For once the wing is a pretty good fit on the fusalage sides and all sizes check out good.
< Message edited by john josey -- 4/7/2010 5:30 AM >
Hide Signatures
       Post #: 31
RE: Another 'HOTS' only bigger ! - 4/7/2010 5:11 AM
john josey
Score: 110
Status: offline
Spent a fair amount of time trying to make my mind up where to put the 'split'. I thought of just making it vertical from the trailing edge of the wing to come into line with the 'cockpit window', but thought this way would make it easier to get the wing on and off.
Thats all i managed today, next thing will be shaping that former (i hope)
Hide Signatures
       Post #: 32
RE: Another 'HOTS' only bigger ! - 4/8/2010 2:05 AM
john josey
Score: 110
Status: offline
The part that i hate doing, marking and drilling the holes for the dowels on the leading edge. I sat the wing in place and just pushed a couple of lenths of scrap dowel through the former to make a defined mark in the exact place on the leading edge.
Hide Signatures
       Post #: 33
RE: Another 'HOTS' only bigger ! - 4/8/2010 3:27 AM
john josey
Score: 110
Status: offline
The last job i managed to get done was the plywood plate for the wing bolt. You can see in the picture the scrap light ply and the balsa spacers i used to get the position of the back of the plate.
Hide Signatures
       Post #: 34
RE: Another 'HOTS' only bigger ! - 4/9/2010 1:45 AM
john josey
Score: 110
Status: offline
Made a start on the tailplane today just a simple construction with a piece of 1/4" square hardwood for a stiffener.
You can see the outline of the scaled up one drawn out on the bench with the 40 size one in the middle.
Hide Signatures
       Post #: 35
RE: Another 'HOTS' only bigger ! - 4/9/2010 1:51 AM
john josey
Score: 110
Status: offline
Hide Signatures
       Post #: 36
RE: Another 'HOTS' only bigger ! - 4/9/2010 3:27 AM
john josey
Score: 110
Status: offline
I considered doing a built up tailplane, but truth be told i just couldn`t be bothered. I would be really miffed if i had went to the bother and then had to add weight to the tail ! i`ll take my chances.
< Message edited by john josey -- 4/9/2010 4:25 AM >
Hide Signatures
       Post #: 37
RE: Another 'HOTS' only bigger ! - 4/9/2010 3:38 AM
john josey
Score: 110
Status: offline
This pile of wood aint going down much.
Hide Signatures
       Post #: 38
RE: Another 'HOTS' only bigger ! - 4/9/2010 3:47 AM
john josey
Score: 110
Status: offline
I ran out of balsa sheet to do the other elevater half, but i have photographed it with the 40 size one for comparison.
Hide Signatures
       Post #: 39
RE: Another 'HOTS' only bigger ! - 4/9/2010 4:08 AM
john josey
Score: 110
Status: offline
The last jobs i managed to get done today were finish off the end ribs ready for the wing tips, shave and sand leading edge to near enough final shape and tidy up centre section sheeting around where the fuel tank sits.
Thats a 12 oz tank in there, it makes you realise just how big an aeroplane it is !
Hide Signatures
       Post #: 40
RE: Another 'HOTS' only bigger ! - 4/9/2010 4:23 AM
john josey
Score: 110
Status: offline
It`s a wonder i get anything done with all the mess i make !
Hide Signatures
       Post #: 41
RE: Another 'HOTS' only bigger ! - 4/10/2010 3:58 AM
john josey
Score: 110
Status: offline
Not much done today, just lined up the wing and drilled the hole for the wing bolt. I did the front and rear formers for the cockpit centre section on the top of the wing which just needs sheeting now, but i forgot to take a picture. oops !
Hide Signatures
       Post #: 42
RE: Another 'HOTS' only bigger ! - 4/10/2010 6:31 PM
Pelle Gris
Score: 100
Last Login: 5/21/2013
Status: offline
How will you get to the wing bolt once you build up the fuse section on the wing? I´m going with two 6mm wing bolts mounted from the underside though glued in "guidetubes".
Best Regards
Tinus Nielsen
Hide Signatures
       Post #: 43
RE: Another 'HOTS' only bigger ! - 4/10/2010 10:15 PM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: Pelle Gris
My plan was just to have a hole on the top. I`ve used this method before on a club 20 racer and it worked really well. The only down side is if the bolt for some reason falls inside but a small piece of fuel tubing over the bolt should stop this.
It`s not too late to change it to the other way round so i`ll speak to the owner and see which way he prefers
Just as a matter of interest do you know how it`s meant to bo done, what does it show on the plan ?
Hide Signatures
(in reply to Pelle Gris)
       Post #: 44
RE: Another 'HOTS' only bigger ! - 4/11/2010 1:24 AM
Pelle Gris
Score: 100
Status: offline
I´m building from the original "The Hots" plans which is a one-piece airplane. I believe Midwests Hots II did have a removable wing, along with it´s bigger cousins.
Best Regards
Tinus Nielsen
Hide Signatures
       Post #: 45
RE: Another 'HOTS' only bigger ! - 4/11/2010 2:36 AM
john josey
Score: 110
Status: offline
Again not much done today but every little helps i suppose.
I added a couple of 1/4" triangular stock just to give a better joint to the leading edge for the former while i get round to sheeting it.
Both formers on at the correct angle ready for the sheeting
Hide Signatures
       Post #: 46
RE: Another 'HOTS' only bigger ! - 4/11/2010 2:48 AM
john josey
Score: 110
Status: offline
One last check to see the wings are square to the fusalage, and i`m pleased to say they are.
Hide Signatures
       Post #: 47
RE: Another 'HOTS' only bigger ! - 4/14/2010 6:30 AM
john josey
Score: 110
Status: offline
Finally managed to get the centre section sheeting done over the weekend in between work, kids and flying. You can see in the first picture the 1/4 sq hardwood i had to add to keep the top edges straight and not curve into the centre which would look terrible when lined up with the front and back of the fusalage.
I spoke to the owner about the single bolt from the top and he still wants to go with it. As he says, trying to fit what is effectively a top wing model from the bottom will be a pain in the backside, much easier to sit the model on it`s wheels, sit the wing in place and one bolt from the top.
This picture just shows the top sheeting on with the screw hole cut out. I`m hoping to get stuck into it this week.
Starting to take that unmistakable HOTS outline ?
Hide Signatures
       Post #: 48
RE: Another 'HOTS' only bigger ! - 4/15/2010 4:11 AM
john josey
Score: 110
Status: offline
Managed to get a few hours today although not much to show for it. Started off by drawing the fin and rudder onto the bench the same as the tailplane.
Fin, rudder, tailplane and elevators hinged,nearly complete, just the control surfaces to be tapered and the leading edges to be rounded off.
Hide Signatures
       Post #: 49
RE: Another 'HOTS' only bigger ! - 4/15/2010 4:36 AM
davidgeorge212
Score: 129
Last Login: 5/22/2013
Status: offline
ive been following your progress, You do some really good looking work.
David
WACO Brotherhood #166/ Cub Brotherhood #16
1/2 Scale Stits Sky Baby Brotherhood #1
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
