Another 'HOTS' only bigger !    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Another 'HOTS' only bigger !
Page: [1] 2 3 4 5 6   next >   >>
Login
Another 'HOTS' only bigger ! - 3/31/2010 5:17 AM
john josey
Score: 110
Last Login: 5/19/2013
Status: offline
I managed to build a 48" hots from an old crashed airframe at the end of last year, so a friend of mine has asked if i could build him a bigger one.
After a short chat we decided to increase it by 50% which will take it to around 72" (maybe a bit bigger when you add the wingtips)
I started off by cutting the scaled up size from thin card.
When i built the small one i made a kit of parts for two, so all i`m doing here is scaling up from the second kit of parts of the small one, if that makes sense ?
Hide Signatures
       Post #: 1
RE: Another 'HOTS' only bigger ! - 3/31/2010 5:23 AM
john josey
Score: 110
Status: offline
Used the card templates to mark out the front bulkhead and undercarriage plate. These are the only parts that are cut from 6mm birch ply, the others are from 3mm light ply.
I was extra carefull with the front bulkhead being square as this is used as a template for the width of the rest of the formers including the undercarrige plate.
Formers 2 and 3 roughly cut to shape using the card templates.
Hide Signatures
(in reply to john josey)
       Post #: 2
RE: Another 'HOTS' only bigger ! - 3/31/2010 5:37 AM
john josey
Score: 110
Status: offline
Decided to make a start on the wings simply because they are gonna take up the whole bench and the sooner their done the better !
Started by making the ribs. Made one 'master' rib from 3mm ply and used the disc sander to get them to their final shape using the ply rib as a template.
Hide Signatures
       Post #: 3
RE: Another 'HOTS' only bigger ! - 3/31/2010 5:47 AM
john josey
Score: 110
Status: offline
The two inboard ribs on each side have the spar cut-outs twice the depth as the spars are doubled up in the centre saction.
Hide Signatures
       Post #: 4
RE: Another 'HOTS' only bigger ! - 3/31/2010 5:56 AM
john josey
Score: 110
Status: offline
Obviously because of what i`m doing here there is no plan to work from, so a full lenth straight pencil line on the bench will have to do.
Fortunately the wing is symmetrical in section, parallel cord with no dihedriel, so is quite straight forward.
Hide Signatures
       Post #: 5
RE: Another 'HOTS' only bigger ! - 3/31/2010 6:08 AM
john josey
Score: 110
Status: offline
I use panel pins in-between every second rib, the difference being that i cut the heads off with 'side cutters' and hammer them flush with the spars. This means you can finnish the whole top of the wing including spar webbing, front, rear and centre sheeting and even the cap strips. once completed you simply 'prize' the whole wing off the board. The wing is fairly stiff at this point and much reduses the chance of being warped.
Just one word of caution with this method is dont run your hands over the board to see if you have got all the pins out  (cause that really will sting a bit !)
Hide Signatures
       Post #: 6
RE: Another 'HOTS' only bigger ! - 3/31/2010 6:14 AM
john josey
Score: 110
Status: offline
This is a square on shot of the centre section spars.
Hide Signatures
       Post #: 7
RE: Another 'HOTS' only bigger ! - 3/31/2010 6:23 AM
john josey
Score: 110
Status: offline
The leading edge was made from a single sheet of 1/2" x 36" balsa cut in half along it`s lenth.
The trailing edge was just 1/2 x 1/2 balsa joined together in the centre with a piece of hardwood and held at the correct height (22mm) with scrap balsa blocks tack glued to the bench.
The spar webbing was also added from hard 3/32 balsa sheet. You can see in this picture where the centre ribs are cut deeper for the spars and where the spar doublers end.
Unlike the small one, this wing will have to be removable so i added three 1/2 sheet balsa pieces between the two centre ribs to help spread the load of the ply plate for the wing bolt (s) when the sheeting is on. I also added a piece of 3mm birch ply between the centre ribs, mainly for a better fixing for the dowels, but also as a brace on the LE join.
Hide Signatures
       Post #: 8
RE: Another 'HOTS' only bigger ! - 3/31/2010 6:31 AM
john josey
Score: 110
Status: offline
Front, rear, centre section sheeting and cap strips added. Tomorrow i can prize it off the bench and complete the sheeting.
Hide Signatures
       Post #: 9
RE: Another 'HOTS' only bigger ! - 3/31/2010 6:37 AM
john josey
Score: 110
Status: offline
Thats the bottom sheeting and cap strips all complete. The next thing i wanted to do was the aileron servo mounts and this has turned out to take just as much time as the wing it`s self.
Hide Signatures
       Post #: 10
RE: Another 'HOTS' only bigger ! - 3/31/2010 6:41 AM
john josey
Score: 110
Status: offline
The basic frame to mount the aileron servo.
Hide Signatures
       Post #: 11
RE: Another 'HOTS' only bigger ! - 3/31/2010 6:43 AM
john josey
Score: 110
Status: offline
'Framed' out the 2mm balsa sheet with 3mm sq just to give the sheeting something to sit on. I could have sat the sheeting on the 2mm frame and just sat the ply servo mount on the hardwood blocks, but i thought this was the better way as it helps to keep the curve of the wing.
Another way would have been to use 5 or 6mm sheet.
Hide Signatures
       Post #: 12
RE: Another 'HOTS' only bigger ! - 3/31/2010 6:47 AM
john josey
Score: 110
Status: offline
All sheeted and cut out for the mount.
The other side should be quicker to do.
Hide Signatures
       Post #: 13
RE: Another 'HOTS' only bigger ! - 3/31/2010 6:55 AM
john josey
Score: 110
Status: offline
Obviously i dont build this quick  but thats it up to date now and should be normal speed.
                                                               john
Hide Signatures
       Post #: 14
RE: Another 'HOTS' only bigger ! - 3/31/2010 10:59 PM
john josey
Score: 110
Status: offline
Only managed a couple of hours today but managed to cut out the fusalage sides. Thats the sides of the '40' size one beside them.
Hide Signatures
       Post #: 15
RE: Another 'HOTS' only bigger ! - 4/1/2010 2:03 AM
SKYHI1
Score: 100
Last Login: 9/2/2012
Status: offline
Very cool. Thank you for sharing.
Frank
_____________________________
www.grundyaeromodelers.com
Morris, IL
Hide Signatures
       Post #: 16
RE: Another 'HOTS' only bigger ! - 4/1/2010 2:06 AM
Pelle Gris
Score: 100
Last Login: 5/21/2013
Status: offline
Hi John.
I´m also about to start building a Hots scaled up by 60%. Well, as soon as I get the parts from a friend that has promised to lasercut them for me...:-)
A 60% enlargement would mean a span of 76,8in, but I have decided to dump the curved wingtips and clip the wing at 70,9in instead. Power will be an old 35cc Webra Bully running gas.
What do you plan on using for power, and what do you estimate the final weight to be?
Best Regards
Tinus Nielsen
Hide Signatures
       Post #: 17
RE: Another 'HOTS' only bigger ! - 4/1/2010 2:13 AM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: SKYHI1
Frank
Hi Frank,
Thanks for the kind words. I know how much i enjoy the various build threads on here and i`m always facinated be the way different modelers do different aspects of the build.
This is a very simple straightforward aeroplane to build. I realised from another thread on here that the 'HOTS' has a strong following so it may be of interest to some.
        cheers
        john
Hide Signatures
(in reply to SKYHI1)
       Post #: 18
RE: Another 'HOTS' only bigger ! - 4/1/2010 2:15 AM
Pelle Gris
Score: 100
Status: offline
Pics of my modified plans and planned paint skeme in pose #2 here: http://www.rcuniverse.com/forum/m_9237798/anchors_9243384/mpage_1/key_/anchor/tm.htm#9243384
Best Regards
Tinus Nielsen
Hide Signatures
(in reply to Pelle Gris)
       Post #: 19
RE: Another 'HOTS' only bigger ! - 4/1/2010 2:29 AM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: Pelle Gris
Hi John.
For power my plan is to use a 'piped' OS91, as for the all up weight, i`m not sure, if it comes in at around the 12lb mark i`ll be very happy. All i can say at the moment is that the wing is very, very light at the moment.
Hide Signatures
       Post #: 20
RE: Another 'HOTS' only bigger ! - 4/1/2010 4:35 AM
john josey
Score: 110
Status: offline
Hi Tinus,
Thanks for posting the link, very interesting indeed.
What width is the front bulkhead when scaled up to 60% if your planning to use the big petrol engine ?
        cheers
        john
Hide Signatures
       Post #: 21
RE: Another 'HOTS' only bigger ! - 4/4/2010 3:11 AM
Pelle Gris
Score: 100
Status: offline
The maximum width of the front bulkhead is 110mm at the bottom which doesn´t leave much room for the engine, but it looks like it will fit... just. :-)
I was planning on using a tuned pipe too but a friend had a spare DA 50 canister which should work out nicely, and be quite a bit cheaper than buying a pipe.
Click to see fullsize image.
Click for fullsize
Best Regards
Tinus Nielsen
Hide Signatures
       Post #: 22
RE: Another 'HOTS' only bigger ! - 4/4/2010 3:28 AM
Pelle Gris
Score: 100
Status: offline
Granted, it IS quite a lot of engine to cram into the cowl.
Click for fullsize
Best Regards
Tinus Nielsen
Hide Signatures
       Post #: 23
RE: Another 'HOTS' only bigger ! - 4/4/2010 3:53 AM
john josey
Score: 110
Status: offline
Yeah, but it should be great though
I`m pleased you`ve posted this, feel free to add pictures of your own at any time.
                                                          john
Hide Signatures
       Post #: 24
RE: Another 'HOTS' only bigger ! - 4/7/2010 4:23 AM
john josey
Score: 110
Status: offline
I glued formers 1 and 3 in permanently, but 2 i left untill i had the dowel and tank holes cut.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
