Will polyurethane glues cure in a vacum?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Will polyurethane glues cure in a vacum?
Page: [1]
Login
Will polyurethane glues cure in a vacum? - 4/5/2002 9:16:07 AM
RossiRay
Status: offline
I will be sheeting my first set of wings with vacum this weekend. I have used polyurethane glues for this in the past with great success. Will these adhesives cure in a vacum?
Ray
       Post #: 1
Will polyurethane glues cure in a vacum? - 4/8/2002 11:17:26 PM
747drvr
Status: offline
Yes they will but of course they won't foam up like under ambient conditions. I'm no expert, but I think it's water that starts a chemical cure as opposed to air drying. Not just blowing my horn, I vacuum bagged some skins to test out my theory and it worked out great.
_____________________________
Marc Thomson
Dundas, Ontario, Canada
(in reply to RossiRay)
       Post #: 2
Will polyurethane glues cure in a vacum? - 4/9/2002 2:16:51 AM
majortom-RCU
Status: online
Normal atmospheric humidity is enough to cure polyu glue. If you happen to have a low humidity shop or live in a dry climate, a very little moisture added to your balsa or whatever will help the cure. Just wipe the balsa lightly with a damp (not wet) sponge is enough. When I'm building in the winter (dry indoors) I usually just huff some warm breath on the balsa, and the moisture from your breath is all it takes.
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.204RCU5
