RE: Scale flaps
Tower Hobbies
Logged in as Guest
Users viewing this topic: michael60
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  11/18/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Scale flaps
Page: <<   < prev  11 12 [13] 14 15 16 17 18 19 20   next >   >>
Login
RE: Scale flaps - 4/9/2004 12:22:58 PM
Rocketman612
Status: offline
quote:
ORIGINAL: Arvid
Allright, then lets do so!.......
Slight positive incidence (1 1/4 degree?), doesn't it mean that it will stear the plane down? The more you are giving it a positive incidence, the more the plane tends to go down, right. So the you have to compensate to give it up rudder? Or am I wrong here?
Arvid,
good to see others trying to do this. Check out this thread I ran last year.
http://www.rcuniverse.com/forum/m_791263/mpage_1/key_corsair%252Cincidence/anchor/tm.htm#791263
The final result looks great. I'm at the primer/paint stage so I can't say how well she fly,s but in simulation all was well. You MUST change BOTH wing and stab incidence to get a flyable plane or forget it.
Pete
_____________________________
"Remember, all im offering is the truth, nothing more..."
Morpheus
(in reply to Arvid)
       Post #: 301
RE: Scale flaps - 4/9/2004 1:50:49 PM
CorsairJock
Status: offline
Top Flite also missed the mark on the wing incidence, it should be 2 degrees I think, and Top Flite plans have 0. If the wing is set right, then the stab should be set right also. Even without setting the wing to a positive incidence, mine seems to need a slight amount of down elevator for level flight, and yes, full scales do fly in what appears to be a slightly nose down attitude. These (scale) incidences create a slight engine downthrust effect (since the wings and stab are positive in relation to the engine, which is at 0 degrees), which in turn means less trim changes are required at different power settings.
Avatar: Electric Powered, Highly Modified Hangar 9 Corsair
(in reply to Arvid)
       Post #: 302
RE: Scale flaps - 4/10/2004 8:06:58 AM
Arvid
Status: offline
Ok, that's pretty clear. I'll give it a try. Especially when it makes slow flight (landing.....) and overall flying characteristics better. It should be done....
In the mean while I am building the fuselage with the mod as Hoonnz showed it in another thread. Must say that I had to think hard before I started cutting in the fuselage (don't repair if it isn't broken?....) but I am convinced it is going to work out alright. Here is the thread:
http://www.rcuniverse.com/forum/m_964836/mpage_8/key_/anchor/tm.htm#1548365
(in reply to CorsairJock)
       Post #: 303
RE: Scale flaps - 4/10/2004 8:59:26 AM
torp
Status: offline
A couple of pics i snapped for you guru's !!!!!!!
torp
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
A good friend will come bail you out of jail...........but a true friend will be sitting next to you saying
&q
       Post #: 304
RE: Scale flaps - 4/10/2004 12:10:26 PM
Arvid
Status: offline
Cool, nice pictures!
(in reply to torp)
       Post #: 305
corsair pics - 4/10/2004 8:57:14 PM
torp
Status: offline
Here's a link to some detailed pic's some of you might not know about !!!!!
http://www.kiwiaircraftimages.com/corsair.html
torp
If you dudes get a bit of time research kiwi's in corsairs during war , big effort by us .............
&q
(in reply to Arvid)
       Post #: 306
RE: Scale flaps - 4/11/2004 6:26:18 AM
hoonnz
Status: offline
Hey Torp
Is that Wanaka? I wasn't fussed about going as the NZ Corsair was sold - now they've bought a better one and I missed out. The shot of the cooling flaps is the best view I've seen of the operating mechanism - its just a drawstring. I've decided to use that method on mine, don't think I'll make little scale pulleys though.
Cheers
Brian
(in reply to torp)
       Post #: 307
RE: Scale flaps - 4/11/2004 7:27:49 AM
torp
Status: offline
Hi Hooonz , same corsair ,they brought it over from duxford for the show !!!!!!
torp.
........yes ,wanaka on saturday.........
p.s might not be same corsair ,i know one went to Brazil ,think its this one ??????
< Message edited by torp -- 4/12/2004 4:06:03 AM >
&q
(in reply to hoonnz)
       Post #: 308
RE: Finished Empenage Mods - 4/16/2004 12:12:35 AM
bob_in_lv
Status: offline
Hello Gents,
I just finished my first attempt at building an RC model, a Top Flight 60 Gold. The engine i used is a Saito 150 4 Stroke. the porblem I am having is fibration cracking the plastic cowl. Does anyone make a fiberglass cowl for this model? I think fiberglass would be stronger and more flexible.
Bob_in_lv
(in reply to Rocketman612)
       Post #: 309
RE: Scale flaps - 4/16/2004 10:45:48 AM
hoonnz
Status: offline
Arvid
I've just come from your thread on the sliding canopy - you really scored there!
Here is what I am doing in my wings. I don't like non-scale external control linkages and horns, so this is my solution to actuating the ailerons. The cranks are to avoid excessive tight curves in the snakes and the double bellcranks are to avoid twisting under load.
The crank could just be pivoted in the centre, but the ball link on the swingee reaches the limit of its swivel so the offset I have built in allows a greater range of movement without sideways stress.
Hopefully the pics are self explanatory.
Click for fullsize
Click for fullsize
(in reply to Arvid)
       Post #: 310
RE: Scale flaps - 4/16/2004 3:32:15 PM
Arvid
Status: offline
Hoonnz, you rule. This way I can just cut away the existing bar and replace it with a new one an copy this linkage you just showed. I will go back to the store and get some of those swingbees. What size do you use?
The sliding cockpit is a feature which is extremely nice. So if posible I would like to make it as well.
       Post #: 311
RE: Scale flaps - 4/16/2004 3:44:22 PM
Mel Francis
Status: offline
I lightened up your second picture a bit.
Shows a lot more detail now.....
Click for fullsize
< Message edited by Mel Francis -- 4/16/2004 9:47:04 AM >
(in reply to torp)
       Post #: 312
RE: Scale flaps - 4/16/2004 10:25:23 PM
hoonnz
Status: offline
Arvid
Don't jump in too quick, there are some differences from the normal positions. The ply mount is one rib-bay inboard to where the plan shows, and is shifted back (about 3cm) and down a little. Also the inboard rib it is fitted into normally has a hole popped out so you have to glue its missing balsa back in. The hinging is going to have to be measured very carefully to get the hinge line lined up with the swingee.
I bought my swingees about 5 years ago mail order from England, they are 30mm wide. I wasn't aware there were other sizes.
(in reply to Arvid)
       Post #: 313
RE: Scale flaps - 4/17/2004 12:02:01 AM
WarpdSpazm
Status: offline
Try this for hidden linkage
http://www.irfmachineworks.com/rds/
I bought some stuff from them including pre-made pockets. I am very happy with the work... Putting it into my H-9 Corsair.
Ray
       Post #: 314
RE: Scale flaps - 4/17/2004 7:21:22 AM
Arvid
Status: offline
Brian, everything you said I sort of figured it out but it is good to hear the confirmation
I prefer the swingbee rather than the solution presented by WarpdSpazm as then you will have a servo in your wing which can go malfunction. I rather go for static pieces. Still a nice alternative as well, that should be said.
(in reply to WarpdSpazm)
