CorsairJock
MI, USA Status: offline
quote:
ORIGINAL: loulou I am told that the belly pan on the TF design is not true to scale. Has anyone done any work in that area? OK, the belly pan: I don't think 'true to scale' is the correct phrase here, as it's outline and general shape appear to be true to me. It DOES lack details, and Top Flite maunauls don't provide any detailed info. Also, the wing incidence is wrong (as mentioned in early posts), which natually translates to the belly pan not being right either. For one, there is a retractable air duct/ chute, which is no biggy because the kit can be build as per plans and it would appear that the duct is fully closed. Only lines would need to added, to simualte it. Probably the biggest area tho, would be the way the pan is faired into the wings. You simply can't see this from drawings, and very difficult to see with pictures. The best way is to see a full scale, up and close. 2nd best is to purchase a Tamiya plastic kit (around $20 ~ $30, your choice of scales: 1/72 or 1/48). These little plastic models are extremely well detailed and accurate, and reveal many details which cannot be seen in 2 dimentional drawings. You can also build the kit and use it in scale contests as documentation for your RC version. Anyway, in a genral statement: the wing is faired into the belleypan from the leading edge to about half way back. From half way back to the triling edge, it is not faired. By faired, I am refering to the gradual/ rounded fillet wher the wing and belly pan meet. Like I said tho, best way to see what I mean is to either visit a full scale OR buy the plastic model. Any other input on this from others is welcome. Also, concerning a post a little earlier concerning possible electric power conversion: I am currently working on a Hanger 9 Corsair, which I intend to have ready to fly using electric power by Jan. 1, 2005.
< Message edited by CorsairJock -- 11/23/2004 2:07:26 PM >
_____________________________
Avatar: Electric Powered, Highly Modified Hangar 9 Corsair
