CorsairJock -> RE: 1/8 scale TopFlite Corsair Mods (10/12/2008 12:26:24 PM)
quote:
ORIGINAL: rs_two_five So I've started my build. First step was to address the proper under cowl curve for the model. This is how I did it. I created a new fuselage former with 1 inch spacing between the normal F-2. I doubled the former on the aft side to accommodate final shaping once the fuse is covered with balsa so the leading edge doesn't get too thin. I will be glassing the whole aircraft using Minwax Polycrylic and some light Sig fiberglass cloth.................................. Your setup looks very simular to the method that I used on my highly modified Hangar 9 Corsair. If (WHEN) I do it over, I will add a little more gloth and expopy right where the foam meet the 2nd former, as it is too easy to sand too much down there when it comes time to prepare for finishing. quote:
ORIGINAL: rs_two_five ........So, I'm really thinking I would like to set this aircraft up electric powered. What sized motor should I be looking to get. Keep in mind, it'll be glassed, TF cockpit, Robart retracts w/struts, retract tail wheel, flaps, possibly operating cowl flaps and hopefully running as close to scale sized prop (17-19 in 3 blade). Any ideas?................ I had to do a search, but finally found it: a Top Flite Corsair electric power build thread: http://www.rcuniverse.com/forum/m_4131667/mpage_1/key_electric%2CTop%2CFlite%2CCorsair/tm.htm It could probably use a little 'bump'. As for scale size prop: the AXI 4130/20 could probaly swing a 3 blade Master Airscrew 16 x 8, but I wouldn't push it any farher than that. My AXI 4130/20 powered Hangar 9 Corsair is using a 3 blade M.A. 15 x 7, and it looks pretty darn good. Having exact scale size props might looks nice, but you start to encounter other problems as props size increases, such as: 1) More weight (those bigger props start weighing a lot more) 2) Less ground clearance, which can also lead to 3) greater likelyhood of incurring engine (electric motor) damage, and/ or 4) flip-overs when on the ground My advice would be to use the above mentioned AXI motor with 3 blade 15 x 7, on 7 or 8 (LiPo) cell set-up. quote:
ORIGINAL: andernamen .................... My TF Corsair flies okay, but I checked the distance from the wingtips and the tail on each side only to discover a difference of about 3/4" to 1". When she flies, the ailerons are not centered (i.e. level flight, one is up, the other down). The rudder is straight and true. I can re-drill the blocks to correct the problem with the wings, but before I do, I'd like to get some opinions on what, if anything, this will do. This is not the original wing for the plane and I am the third or fourth owner. Any thoughts? I have flown Corsairs that did not have the wings quite right, and from my experience: they seem to fly OK for the most part, but seem to fly a little less stable when in the landing mode (as in: they tend to tip stall a little quicker). My advice would be to re-drill the holes if necessary to get it straight (or at least: straighter).
