southern_touch9
GA, USA Status: offline
Good deal!! Im glad to hear that you ordered the plane. The guy in the model sport video doesnt do the plane justice . The saito .72 mounts right up on the engine mount provided. No cutting or shaving is needed. The kit goes together really fast and every piece is laserlocked. You will find that even the sheeting for the wing is cut to the right width and the gussets for the stick built tail are cut out as well. Though the kit is laser lock my only advice is to take your time on the wing, mine came out a little warped so I spent a day or so straightening it out with a spray bottle, flat surface and weight. Go ahead and do yourself a favor and add a couple of extra gussets on the elevator (around the tabbed region) for strength reasons (especially helps for a "wall" or a "parachute" . Feel free to cut come ligthening holes into the bottom of the fues. I even cut two out on the side behind where the servos mount and two out from the side around where the tank would be sitting. You can also make the model lighter but cutting lightening holes in the wing webbing. I have also heard from a friend that he cut his wing tips off and he can knife edge with less coupling, and harriers are a lot more solid. He did say something about loss in super slow performance however (including landing). My airplane came out tail heavy but I left it this way with the battery pack far forward and it flies great...1/4 throttle inverted, hands off. If you use a computer radio make sure to set that elevator rate on low for landings, but all out for 3D. Have fun, if you have any questions post a msg or email me.
