MJD
ON, CANADA Status: offline
30% nitro is too much, unless the compression has been reduced via head shims. The Manufacturer's recommendation is 10-15% nitomethane Prosynth. If you don't have Prosynth use some other good quality synthetic oil fuel, but don't exceed 15% nitro with the engine as is out of the box. I really don't see any point in the combination of 9-6 prop and 30% nitromethane. It's like trying to go fast in a sports car by adding a turbocharger then driving in 2nd or 3rd gear.. great for climbing hills but not for top speed! The usual recomendations are 9-6 for running in and test flights, then 8-8 to 8-10 for speed. The 8-8 may perform better if the header is cut down a bit, up to 1", leave stock for higher pitch. Mike D.
