Tall Paul
CA, USA Status: offline
Seeing Hal DeBolt here regularly sends me way-back-when to the time when I became active in r/c... started in '55 with a Berkeley Royal Rudder Bug, Fox .19, Citizenship single-channel radio kit... Hal's Live Wire was -the- airplane at the time. Probably got most people of that time into r/c. Note its aerodynamic setup, with the forward c.g. and lots of incidence on the wing, and lots of incidence on the horizontal; typical of a free-flight and a motor without a throttle, it was a one-speed speed airplane. The motor had more than enough power to keep the plane in a climb. Altitude was controlled by turning/diving. MOF, loops and rolls were easily done by turning/diving, and neutralizing the rudder, for a loop, or neutralizing rudder then putting the other direction in to roll. All exploiting the single-speed aerodynamic layout. When the Bonner compound escapement made motor control possible... 2 speeds, full power and something less with an intake restrictor, then more control of the pitch axis was possible. The second speed could be set for level flight or a slight descent. I recall Fremont Davis' son had a Live Wire Kitten (seriously modified) with rudder only proportional and motor, doing touch-and-goes, using the motor and the rocking feature of the Live Wire setup.... a rapid switching between left and right rudder in a descent would raise the nose... touchdown, add power, climb out.. When multiple channel radios became available, the force setup changed. The pilot now provided a major portion of the longitudinal stability, with elevator trim, and/or power. As most sport fliers don't use the motor channel for anything more than a on-off switch, the elevator trimming feature became important.. And the usual free-flight semi-automatic stability and constant climb went away. More modern airplanes now use a horizontal set parallel to the FRL or engine thrust line. Little wing incidence, and that due to setting the "flat" part of the aft bottom parallel to the FRL... Pattern planes use 0-0; no wing or tail incidence. Engine thrust offset to suit the low-powered portion of the flight. Go-fast planes went to 0-0-0 early on. In essence, any fixed aerodynamic setting will be "good"... that is, no trims needed, at a single flight speed. Go faster, the elevator trims down. Go slower, it trims up unless you want to climb/dive. Those fliers that never fly slower are amazed to find this out, and when it makes itself known ask questions like "My plane climbs under power. How can I stop that?"... Um, if the airplane can't climb, it's a car. Go to a different forum
