RE: NEW Top Flight P-40??? 1/5 scale    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: NEW Top Flight P-40??? 1/5 scale
Page: <<   < prev  23 24 [25] 26 27 28 29 30 31 32   next >   >>
Login
RE: NEW Top Flight P-40??? 1/5 scale - 3/17/2011 2:47 PM
MLC
Score: 100
Last Login: 11/16/2011
Status: offline
I ended up creating a small slide for the tailwheel mount to rub against as it retracks in to the opening. Seems to work pretty good but if you hold any rudder the wheel it self wants to hit. I may try the spring idea as well is it should snap the wheel straight when the cable gets slack.
Hide Signatures
(in reply to samparfitt)
       Post #: 601
RE: NEW Top Flight P-40??? 1/5 scale - 3/18/2011 1:16 AM
ROGER RUSSELL
Score: 115
Last Login: 6/17/2013
Status: offline
Thanks Sam, but I just don't see spending more $ when I have a G62 and a B+B Side muffler on hand.
She will look fine at 100mph.......................LOL
quote:
ORIGINAL: samparfitt
Roger,
Dick Bennett (B&B) makes a thin carb extension (replaces the present thick one) that may help along with tilting the engine about 5-10 degrees. Those muffler corners are pretty thick so you may be able to grind them off. I've had success using dremel's metal grinding bits to remove aluminum.
http://bennettbuilt.com/page2.htm
A pitts 'wraparound' may do better:
http://www.chiefaircraft.com/rcmsec/Models/Engines/Zenoah/Zenoah.html#g62
_____________________________
Remember to FLY HARD and LAND SOFT
Hide Signatures
       Post #: 602
RE: NEW Top Flight P-40??? 1/5 scale - 3/18/2011 4:31 AM
propchief
Score: 100
Last Login: 5/21/2013
Status: offline
Roger, I have a friend with a G-62 on a TF Corsair and almost the whole bottom of the cowl cut ... and nobody notices it on a nice low pass. I would have used a G-62 if I didn't have a DLE 55 on hand. That G-62 is a great juggernaut of an engine.
Hide Signatures
(in reply to ROGER RUSSELL)
       Post #: 603
RE: NEW Top Flight P-40??? 1/5 scale - 3/21/2011 2:07 AM
MLC
Score: 100
Status: offline
What are folks using to extend the exhaust tubes on there jtec mufflers when using a DLE 55? Or, how is the cowling holding up without any extensions?
Hide Signatures
(in reply to propchief)
       Post #: 604
RE: NEW Top Flight P-40??? 1/5 scale - 3/21/2011 5:56 PM
dasintex
Score: 126
Last Login: 6/19/2013
Status: online
A new or 2nd version of the J-Tec Wrap around Pitts made for the TF P-40 and DLE55 is made and sold by Jtec that has longer exhaust tubes that clear the cowling, you can buy direct from Jtec and specify this muffler with the longer tubes, Tower Hobbies sells this muffler but it may be the older version with the shorter tubes.
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
(in reply to MLC)
       Post #: 605
RE: NEW Top Flight P-40??? 1/5 scale - 3/21/2011 7:09 PM
Chad Veich
Score: 275
Status: offline
Congrats to Capt G for his first place in "Best Military Flight" category at the OEAF event over the weekend. The airplane looked great in the air and the landings were particularly nice.
Hide Signatures
(in reply to dasintex)
       Post #: 606
RE: NEW Top Flight P-40??? 1/5 scale - 3/22/2011 12:07 AM
MLC
Score: 100
Status: offline
Bummer, I already have the muffler installed and have no desire to buy a second one. Hopefully others have already had some flying time on there planes and not had any issues.
Hide Signatures
       Post #: 607
RE: NEW Top Flight P-40??? 1/5 scale - 3/22/2011 1:39 AM
propchief
Score: 100
Status: offline
I would get a piece of heater hose from the local auto parts store and secure it with a couple small hose clamps to extend those muffler down tubes. There isn't much pressure in the down tube and getting the exhaust out of the plane is a good thing.
Hide Signatures
(in reply to MLC)
       Post #: 608
RE: NEW Top Flight P-40??? 1/5 scale - 3/22/2011 5:57 AM
Hellcat716
Score: 116
Last Login: 6/10/2013
Status: offline
The tubes need to be about 5 1/2" long to clear the cowl on the P-40. The one I have is only 4" long.
Hide Signatures
       Post #: 609
RE: NEW Top Flight P-40??? 1/5 scale - 3/22/2011 5:19 PM
JeffH
Score: 114
Status: offline
get you a piece of Al tube that slips over the muffler pipes, slit the ends 4-5 times and then use a hose clamp and high-temp rtv to attach them to the existing stacks. I have found that old aluminum framed lawn chairs make good extensions.
Hide Signatures
(in reply to Hellcat716)
       Post #: 610
RE: NEW Top Flight P-40??? 1/5 scale - 3/24/2011 10:25 PM
serge760
Score: 100
Last Login: 5/1/2013
Status: offline
my j-tec muffler on my da50 comes loose,what's the problem
serge
Hide Signatures
(in reply to handyman 220)
       Post #: 611
RE: NEW Top Flight P-40??? 1/5 scale - 3/25/2011 1:14 AM
efly726
Score: 100
Last Login: 12/13/2012
Status: offline
My friends new P-40
http://www.youtube.com/watch?v=WXX_n_ToARk
Hide Signatures
(in reply to p-80)
       Post #: 612
RE: NEW Top Flight P-40??? 1/5 scale - 3/25/2011 2:53 AM
propchief
Score: 100
Status: offline
Serge760 - I would take the bolts out and clean the threads and bolt holes thoroughly with some alcohol or other cleaner. Then put a light coat of permatex ultra gasket sealer on them and on the engine exhaust flange (don't use a gasket.) Tighten them down and let cure overnight. That should do it.
John
Hide Signatures
(in reply to efly726)
       Post #: 613
RE: NEW Top Flight P-40??? 1/5 scale - 3/25/2011 4:50 AM
serge760
Score: 100
Status: offline
thanks for the help,why no gasket?
serge
Hide Signatures
       Post #: 614
RE: NEW Top Flight P-40??? 1/5 scale - 3/25/2011 2:49 PM
propchief
Score: 100
Status: offline
The gasket will fail and eventually lead to the muffler becomming loose. The permatex will provide a seal and allow a muffler to flange contact so it doesn't loosen. I checked my permatex and it's Ultra Copper. Gaskets haven't worked for me in glow or gas, but without them I've had little trouble.
BTW - I'm using a JTEC large volume muffler and had to make a small 1/8 moon shaped cut for the muffler side and one bolt hole. I considered the others, but for me it's a matter of noise control and I think the large volume should help so the cutouts are not a problem. The exhaust tubes stick out about 1/4 inch on the bottom.
Hide Signatures
(in reply to serge760)
       Post #: 615
RE: NEW Top Flight P-40??? 1/5 scale - 3/26/2011 3:38 PM
n8622t
Score: 101
Status: offline
Hey Roger, I have the P47 and the tailwheel on it does the same thing. I only widened the doorway for the wheel to retract through and need to maintain a centered rudder before retracting the gear. I have had no in flight problems with it the way it is, but I will be paying attention to that area when I begin the P40 build.
Go low if you wanna make a show
Jimmy
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
       Post #: 616
RE: NEW Top Flight P-40??? 1/5 scale - 3/26/2011 3:45 PM
n8622t
Score: 101
Status: offline
Hey Serge, clean all the threads of the bolts and bolts holes with acetone, you can use a q-tip for the bolt holes and use red thread locker. Get a tube of Permatex Grey gasket maker for autos and apply a thin coat on the muffler, exhaust port, and both sides of the gasket if you use one. Make sure these surfaces are clean before you apply the gasket maker, then bolt her together snuggly. That should do it You can get it at any auto store or walmart.
Jimmy
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 617
RE: NEW Top Flight P-40??? 1/5 scale - 3/26/2011 10:33 PM
serge760
Score: 100
Status: offline
thanks so much for the help
serge
Hide Signatures
(in reply to n8622t)
       Post #: 618
RE: NEW Top Flight P-40??? 1/5 scale - 3/28/2011 2:22 AM
propchief
Score: 100
Status: offline
Getting there. Mounted the satelite rx in the copckpit. It was a good position and also provides a bit of flash.
Click for fullsize
Hide Signatures
       Post #: 619
RE: NEW Top Flight P-40??? 1/5 scale - 3/28/2011 1:09 PM
propchief
Score: 100
Status: offline
Another tip to pass along. I removed the covering on the bottomo of the wing and fuse for the belly pans using the soldering iron method. However, the edges were slightly raised due to the burning of the covering. In order to get the edges feathered smooth before glueing the pans on I took my covering iron and set it on a hot setting. I then went over the edges and got them smoothed out!
John
Hide Signatures
       Post #: 620
RE: NEW Top Flight P-40??? 1/5 scale - 3/28/2011 10:17 PM
MLC
Score: 100
Status: offline
Just finished my p-40 this evening. Just need to re-check the CG a little closer as I just the did the quick finger lift (boy this thing is heavy compared to what I am used to flying). Looks like it might be a little nose heavy. May have to move the ignition battery back some and see if that gets it close to where it needs to be.
Anybody else come out nose heavy with DLE 55?
Hide Signatures
       Post #: 621
RE: NEW Top Flight P-40??? 1/5 scale - 3/28/2011 10:24 PM
Stamper
Score: 100
Last Login: 6/4/2013
Status: offline
quote:
ORIGINAL: MLC
Did you check the CG with the gear up? I like my warbirds a little nose heavy at first and then adjust after a few flights. I am using a ZDZ 50 and it came out just a little nose heavy with gear up. I have not flown it yet but if it is like the P-51 and P-47 I will be happy.
Hide Signatures
(in reply to MLC)
       Post #: 622
RE: NEW Top Flight P-40??? 1/5 scale - 3/28/2011 10:27 PM
MLC
Score: 100
Status: offline
Yeap, checked it with the gear up (retracked). It may be fine once I get it checked correctly. It is just to heavy handle by hand.
Hide Signatures
(in reply to Stamper)
       Post #: 623
RE: NEW Top Flight P-40??? 1/5 scale - 3/28/2011 10:31 PM
ROGER RUSSELL
Score: 115
Status: offline
A friend of mine who has built many a warbird with retracts says he always does his cg check with one wheel up and one wheel down.
With the P40 that retracts to the rear it would be interesting to see how that works.
I am about a week away to CG mine, will try and let you know, unless you guys do it first.
Hide Signatures
(in reply to MLC)
       Post #: 624
RE: NEW Top Flight P-40??? 1/5 scale - 3/29/2011 2:38 AM
Hellcat716
Score: 116
Status: offline
I added 2.25 ounces to the tail with the DLE 55.
Hide Signatures
(in reply to MLC)
       Post #: 625
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.035RCU1
