RE: NEW Top Flight P-40??? 1/5 scale    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: NEW Top Flight P-40??? 1/5 scale
Page: <<   < prev  50 51 [52] 53 54 55 56 57 58 59   next >   >>
Login
RE: NEW Top Flight P-40??? 1/5 scale - 11/27/2012 1:12 AM
SWORDSN
Score: 100
Last Login: 6/18/2013
Status: offline
One bolt is slightly recessed and the bolt heads are not parallel . The instructions that came with the muffler say do that but I not sure that I can. but i must try something.
Hide Signatures
(in reply to Lifer)
       Post #: 1276
RE: NEW Top Flight P-40??? 1/5 scale - 11/27/2012 1:17 AM
Dblex
Score: 105
Last Login: 6/13/2013
Status: offline
I'll take $1500 for mine!
Hide Signatures
(in reply to SWORDSN)
       Post #: 1277
RE: NEW Top Flight P-40??? 1/5 scale - 11/27/2012 11:03 AM
Lifer
Score: 153
Status: offline
One final thought: Do you balance your props?
Hide Signatures
(in reply to Dblex)
       Post #: 1278
RE: NEW Top Flight P-40??? 1/5 scale - 11/27/2012 1:37 PM
SWORDSN
Score: 100
Status: offline
Yes I do balance my props but I will re-balance. Anyone else having this problem with this combination DLE55 and J-tec P40 muffler?
Hide Signatures
(in reply to Lifer)
       Post #: 1279
RE: NEW Top Flight P-40??? 1/5 scale - 11/27/2012 2:09 PM
Lifer
Score: 153
Status: offline
You might try balancing the spinner. I drill holes in the backplate to achieve the balance. Best of luck. Also, you could fashion a support strap on the back of the muffler and attach to the firewall area. Slimline mufflers have this feature.
Hope you can get this sorted out!
Hide Signatures
       Post #: 1280
RE: NEW Top Flight P-40??? 1/5 scale - 11/29/2012 1:12 PM
SWORDSN
Score: 100
Status: offline
Well two more flights and the muffler was loose again and the engine was loose from the firewall. I think that I have some serious vibration. I will try the wire on the muffler bolts as in post 960 and balance my spinner.
Hide Signatures
(in reply to Lifer)
       Post #: 1281
RE: NEW Top Flight P-40??? 1/5 scale - 11/29/2012 2:38 PM
BobH
Score: 116
Status: offline
I think you should get a dial indicator and see if your crank shaft isn't running true. That's the first place to look.
_____________________________
BobH.
Hide Signatures
       Post #: 1282
RE: NEW Top Flight P-40??? 1/5 scale - 11/29/2012 6:33 PM
Lifer
Score: 153
Status: offline
Check your prop and spinner balance first. Pulling the crank is not the first thing to do. Best regards.
Hide Signatures
(in reply to BobH)
       Post #: 1283
RE: NEW Top Flight P-40??? 1/5 scale - 11/29/2012 8:22 PM
BobH
Score: 116
Status: offline
No one said to pull the crank.. you can check its trueness while its still in the crank case. The point being if the spiner and prop are ballanced, I believe he said they already were, whats left?
BobH.
Hide Signatures
(in reply to Lifer)
       Post #: 1284
RE: NEW Top Flight P-40??? 1/5 scale - 11/30/2012 12:21 AM
SWORDSN
Score: 100
Status: offline
I suppose that could be true even on a new engine.
Nelson
Hide Signatures
(in reply to BobH)
       Post #: 1285
RE: NEW Top Flight P-40??? 1/5 scale - 11/30/2012 12:23 AM
SWORDSN
Score: 100
Status: offline
The prop is balanced. I will bal the spinner next. Thanks for the input guys.
Nelson
Hide Signatures
(in reply to Lifer)
       Post #: 1286
RE: NEW Top Flight P-40??? 1/5 scale - 11/30/2012 7:47 PM
BobH
Score: 116
Status: offline
I hope it is the spinner thats out of ballance. That's the easiest thing to fix after the prop. Yes its possible to have a bent shaft even on a new engine. Rare but possible. When you dont know what is causing the vibration you also don't know what isn't causing the vibration.
BobH.
Hide Signatures
       Post #: 1287
RE: NEW Top Flight P-40??? 1/5 scale - 12/1/2012 12:19 AM
RiverLarry
Score: 100
Status: offline
Well X Mass. day   will be  D Day   plan on starting my build !!!!
last box from  Tower Hobby  today !!!!
Have every thing I need to do the Job !!!   I think !!!!
added up all the parts   C R I S T      I am glade I was  one  who got the great diel on the ARF
 The  cost was a little scray !!!
when it went over $ 2.307.00  I quit counting !!!
O Well the maidan  should be intresting in the spring !!!
Mite have a fuew QT as I get in to it
read all 52 pages  Of  the post   and  re read        should help a little      I HOPE         R/L
Hide Signatures
(in reply to Lifer)
       Post #: 1288
RE: NEW Top Flight P-40??? 1/5 scale - 12/1/2012 12:47 AM
SWORDSN
Score: 100
Status: offline
Bob, balancing this big red spinner is not easy. It won't fit my prop balance. Any ideas ?
Hide Signatures
(in reply to BobH)
       Post #: 1289
RE: NEW Top Flight P-40??? 1/5 scale - 12/1/2012 12:49 AM
SWORDSN
Score: 100
Status: offline
It's a fun build. There is a lot of good info in this thread. Good luck.
Hide Signatures
(in reply to RiverLarry)
       Post #: 1290
RE: NEW Top Flight P-40??? 1/5 scale - 12/1/2012 2:19 AM
predman
Score: 100
Last Login: 6/17/2013
Status: offline
I am the biggest p-40 fan at our field for sure! Was happy to get this kit, I am impressed with it, good job topflite! Top notch for surer, easiest arf I've ever put together.
Hide Signatures
       Post #: 1291
RE: NEW Top Flight P-40??? 1/5 scale - 12/1/2012 4:55 AM
BobH
Score: 116
Status: offline
I don't know what to tell you? You really need to mount the spinner somehow to see if its out of balance. If you know that the prop is in in balance can you mount the prop and spinner and balance them both at the same time? Just thinking out loud here.
BobH.
Hide Signatures
       Post #: 1292
RE: NEW Top Flight P-40??? 1/5 scale - 12/1/2012 2:28 PM
SWORDSN
Score: 100
Status: offline
The spinner is to big for my prop balance. I'm going to fly the p40 without the spinner and see what happens. Will advise.
Hide Signatures
(in reply to BobH)
       Post #: 1293
RE: NEW Top Flight P-40??? 1/5 scale - 12/7/2012 3:18 PM
BobH
Score: 116
Status: offline
So. did you ever discover the cause of the vibration? Just wondering.
BobH.
Hide Signatures
       Post #: 1294
RE: NEW Top Flight P-40??? 1/5 scale - 12/7/2012 8:39 PM
SWORDSN
Score: 100
Status: offline
Bob. I drilled and wired the muffler bolt, re-loctited the mounting bolts and removed the spinner. I then ran the engine for about 10 minutes on the ground with and without and with the spinner. I re-mounted the spinner an flew for about 5 minutes. All is tight so far. I will balance the spinner when I find a way.
Nelson
Hide Signatures
(in reply to BobH)
       Post #: 1295
RE: NEW Top Flight P-40??? 1/5 scale - 12/7/2012 9:41 PM
BobH
Score: 116
Status: offline
OK at least you got in a flight.
what ballancer do you have now? maybe a different one would work for you.
BobH.
Hide Signatures
       Post #: 1296
RE: NEW Top Flight P-40??? 1/5 scale - 12/8/2012 8:32 PM
SWORDSN
Score: 100
Status: offline
Great Planes, Its to narrow. I will barrow one from a friend.
Hide Signatures
(in reply to BobH)
       Post #: 1297
RE: NEW Top Flight P-40??? 1/5 scale - 12/8/2012 9:33 PM
mikes68charger
Score: 106
Status: offline
Hey guys I picked one of thes up dureing the tower discount, so now I have
This P40 and a Gaint P47 sitting in the box wateing on me.
My qestion is why is the build threads on this bird so much smaller than the P47. Are there isssues with the P40 that make most peaple afraid to fly them?
Except the cost of the folding reatracts, i cant see why Theres not more P40's out there.
I have been to 2 war birds shows and saw 5 P51's and 3 P47 but no P40's? WhY
Hide Signatures
(in reply to lomcevac540T)
       Post #: 1298
RE: NEW Top Flight P-40??? 1/5 scale - 12/9/2012 1:37 AM
SWORDSN
Score: 100
Status: offline
I have no issues. The build is straight forward and it flies great. My only problem is keeping the muffler tight!!!
Hide Signatures
(in reply to mikes68charger)
       Post #: 1299
RE: NEW Top Flight P-40??? 1/5 scale - 12/9/2012 2:57 AM
BobH
Score: 116
Status: offline
I've seen full scale P-40's fly more than once. But they are a pre-wwII plane and not as popular as the Mustangs and Jugs. They do fly fine though. In the modeling world I suppose it's not as popular for what ever reasons? Lots of famous pilots flew them though..
BobH.
Hide Signatures
       Post #: 1300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.859RCU1
