RE: NEW Top Flight P-40??? 1/5 scale    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: NEW Top Flight P-40??? 1/5 scale
Page: <<   < prev  43 44 [45] 46 47 48 49 50 51 52   next >   >>
Login
RE: NEW Top Flight P-40??? 1/5 scale - 4/13/2012 5:22 PM
warhawk demon
Score: 105
Last Login: 4/25/2013
Status: offline
Yeah .. thats high expansion.. i wouldnt use it .  you need the blue with yellow cap.  its made for windows so it wont bow them when it expands.
Hide Signatures
(in reply to lomcevac540T)
       Post #: 1101
RE: NEW Top Flight P-40??? 1/5 scale - 4/14/2012 2:16 PM
lomcevac540T
Score: 100
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: warhawk demon
I'll pick some up this weekend. Thanks!
_____________________________
P-40 Brotherhood #70
To fly is heavenly, to torque roll is devine!
Hide Signatures
(in reply to warhawk demon)
       Post #: 1102
RE: NEW Top Flight P-40??? 1/5 scale - 4/14/2012 3:32 PM
dasintex
Score: 126
Status: offline
Found the Blue Can stuff at Home Depot, in the Insulation Department
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
       Post #: 1103
RE: NEW Top Flight P-40??? 1/5 scale - 4/14/2012 11:26 PM
n8622t
Score: 101
Last Login: 5/17/2013
Status: offline
WBOTX coming up in June...you guys need to check it out!! Should be a great time this year
www.wyliewarbirds.com to get the details
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
(in reply to dasintex)
       Post #: 1104
RE: NEW Top Flight P-40??? 1/5 scale - 4/19/2012 9:39 PM
warhawk demon
Score: 105
Status: offline
hey if you havent done yours yet. cover the surface around the holes you make with 2inch wide blue painters tape first and let the tape hang down 4 or 5 inches below the holes and your clean up will only take about 30 seconds. did mine last nighrt it worked great.
Hide Signatures
       Post #: 1105
RE: NEW Top Flight P-40??? 1/5 scale - 4/20/2012 8:27 AM
n8622t
Score: 101
Status: offline
Don't get it on your clothes
Hide Signatures
       Post #: 1106
RE: NEW Top Flight P-40??? 1/5 scale - 4/20/2012 2:03 PM
ROGER RUSSELL
Score: 115
Status: offline
quote:
ORIGINAL: n8622t
I said it was messy
Yes I used the blue tape....etc and it does help, even put foam in the smaller belly pan part attached to the fuse.
PS:
Hope to maiden mine this weekend!
Remember to FLY HARD and LAND SOFT
Hide Signatures
(in reply to n8622t)
       Post #: 1107
RE: NEW Top Flight P-40??? 1/5 scale - 4/22/2012 8:12 PM
n8622t
Score: 101
Status: offline
went out for the maiden of my P40 and BF109...P40 didnt go due to a choke servo going snafu 109 went very well
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to ROGER RUSSELL)
       Post #: 1108
RE: NEW Top Flight P-40??? 1/5 scale - 4/25/2012 4:36 PM
CAURIMARE
Score: 100
Last Login: 1/10/2013
Status: offline
Nice looking birds
Hide Signatures
       Post #: 1109
RE: NEW Top Flight P-40??? 1/5 scale - 4/26/2012 8:11 PM
n8622t
Score: 101
Status: offline
thanks caurimare....went through the P-40 and replaced the bad choke servo. It may have been vibration that killed it because it was actually glued solid to the floor beneath it. The new servo is shorter so it wont make the contact....should be a go this weekend, will try to get video for it.
Hide Signatures
(in reply to CAURIMARE)
       Post #: 1110
RE: NEW Top Flight P-40??? 1/5 scale - 5/1/2012 12:23 PM
Dblex
Score: 105
Last Login: 5/18/2013
Status: offline
So the tower hobbies Jtech muffler exhaust tubes are too short????
Has this been corrected or do I need to cancel my order? And order direct?
Hide Signatures
       Post #: 1111
RE: NEW Top Flight P-40??? 1/5 scale - 5/1/2012 2:17 PM
dasintex
Score: 126
Status: offline
Dblex;
It looks like the problem has been corrected, they list separatley a Wrap Around Pitts Muffler for the TF Giant P-51-P-47/DA/DLE/50-55 Towers Item# LXZUKO and TF Giant P-40/DA/DLE/50-55 Towers Item#LXBFMY
First Pictue is the one for the P-40
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZUK0&P=SM
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBFMY&P=SM
Click for fullsize
Click for fullsize
P-40 Brotherhood #3
Hide Signatures
(in reply to Dblex)
       Post #: 1112
RE: NEW Top Flight P-40??? 1/5 scale - 5/1/2012 2:23 PM
Lifer
Score: 148
Status: offline
The one for the big P-40 will protrude about 1 inch beyond the bottom of the cowl.
Hide Signatures
       Post #: 1113
RE: NEW Top Flight P-40??? 1/5 scale - 5/2/2012 4:55 AM
n8622t
Score: 101
Status: offline
Dblex you can just send it to Jtec for free fix if it's too short or just add the extension like I did
Hide Signatures
(in reply to Dblex)
       Post #: 1114
RE: NEW Top Flight P-40??? 1/5 scale - 5/9/2012 8:51 PM
lomcevac540T
Score: 100
Status: offline
OK... so I have five flights on mine and two were dead sticks, two were very rich engine settings, and one was when the retracts didn't go up. I don't have a real good record so far. But anyway, my question in about the DA 60. I went from being so lean that the engine heated up and quit, to being so rich it won't clean out on the top end by turning the HSN 1/4 turn out. I have never had a DA so touchy! Planning to try it again this weekend, but just wondering if anyone else is having this issue?
Hide Signatures
       Post #: 1115
RE: NEW Top Flight P-40??? 1/5 scale - 5/11/2012 7:43 AM
n8622t
Score: 101
Status: offline
Hi lomcevak540t my DA60 ran perfectly with the cowl off but extremely lean with the cowl on...after some discussion with DA I soldered a tube on the diaphragm relief hole and attached fuel tubbing to it and ran it into the fuse area. Then I bored a nickel sized hole thru the firewall behind the carb. This fixed it to run like a dream with the cowl on. Hope this helps
Hide Signatures
       Post #: 1116
RE: NEW Top Flight P-40??? 1/5 scale - 5/11/2012 7:47 AM
n8622t
Score: 101
Status: offline
A hair over factory settings on both needles and 32:1 fuel mix....she runs rich in the air
Hide Signatures
       Post #: 1117
RE: NEW Top Flight P-40??? 1/5 scale - 5/18/2012 9:23 PM
warhawk demon
Score: 105
Status: offline
you guys with the dle 55. what prop are you running.
Hide Signatures
       Post #: 1118
RE: NEW Top Flight P-40??? 1/5 scale - 5/24/2012 4:25 AM
n8622t
Score: 101
Status: offline
warhawk you need to run a 20X12 if you want some real speed ...otherwise a 22x10 is perfect for everyday flying
Hide Signatures
       Post #: 1119
RE: NEW Top Flight P-40??? 1/5 scale - 5/24/2012 11:06 PM
warhawk demon
Score: 105
Status: offline
thanks. been running the 22x10. it is doing fine but the rpm is a little low at 6400. just wondering what every one else was doing. im still running a little rich
though.
Hide Signatures
       Post #: 1120
RE: NEW Top Flight P-40??? 1/5 scale - 6/11/2012 12:08 AM
dasintex
Score: 126
Status: offline
The Manual calls for 85oz/in Torque Servos on all control surfaces; what is everyone using for Flap Servos, are Hitec 5475 Standard Digital with 76oz/in sufficient for Flaps?
P-40 Brotherhood #3
Hide Signatures
       Post #: 1121
RE: NEW Top Flight P-40??? 1/5 scale - 6/11/2012 2:56 AM
Capt G
Score: 100
Status: offline
The flaps need a good servo. I use HS 645s or 5645s if you want digital.
Hide Signatures
       Post #: 1122
RE: NEW Top Flight P-40??? 1/5 scale - 6/18/2012 1:05 PM
dasintex
Score: 126
Status: offline
My P-40 is getting near completion, ran the DLE 55 for the first time this weekend, next task will be the Cowl, I am using the J-Tec Pitts Muffler with the longer exhaust tubes.
My plan is to shorten the exhaust tubes so they just clear the cowl by 1/2", and I would ideally like to just cut two 1" holes for the Exhaust tubes to extend through; is the opening of the Cowl Flaps at the rear of the cowl sufficent opening for proper cooling, I know the rule the exit has to be larger than the inlet, but if I don't have to make a larger hole other than to allow the exhaust tubes to pass through would be ideal.
If you have pictures showing this, great, or if they are posted and know the post number# would be appreciated, thanking anyone who can help me this.
P-40 Brotherhood #3
Hide Signatures
(in reply to Capt G)
       Post #: 1123
RE: NEW Top Flight P-40??? 1/5 scale - 6/18/2012 1:46 PM
warhawk demon
Score: 105
Status: offline
It will cool just fine. I just cut two holes in mine for the tubes. i fly 14 minutes at WOT and have no issues with heat at all. i am running the DLE 55 as well.
Hide Signatures
       Post #: 1124
RE: NEW Top Flight P-40??? 1/5 scale - 6/18/2012 1:48 PM
lomcevac540T
Score: 100
Status: offline
I had to close in the air intake and add some vents to the bottom of the cowl. I can get some pic tonight and post them. My engine wouldn't run right until I done this. The cowl was building too much pressure inside it and would stop the diaphram pump in the carb to stop working. Runs great now! I'll get pics on here tonight.
Hide Signatures
       Post #: 1125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.449RCU1
