RE: *** Ultra Sport Brotherhood ***    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: *** Ultra Sport Brotherhood *** Page: <<   < prev  65 66 [67] 68 69 70 71 72 73 74   next >   >>
Login
RE: *** Ultra Sport Brotherhood *** - 4/17/2012 10:27 PM
scottrc
Score: 104
Last Login: 5/21/2013
Status: offline
That looks to be the perfect size for the US.
_____________________________
If you love your plane, set it free, if it doesn''t return, you should have checked the battery.
Hide Signatures
(in reply to box car)
       Post #: 1651
RE: *** Ultra Sport Brotherhood *** - 4/17/2012 10:38 PM
mechdrew
Score: 100
Last Login: 3/29/2013
Status: offline
I look forward to seeing it as well. What do you plan to use for the canopy?
Andrew
Ultra Sport Brotherhood #85
Hide Signatures
       Post #: 1652
RE: *** Ultra Sport Brotherhood *** - 4/18/2012 2:17 AM
box car
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: mechdrew
The 60 canopy will work, I moved it back about 2"
Ken
Wherever conversion engines are outlawed, only outlaws will have conversion engines.
Hide Signatures
(in reply to mechdrew)
       Post #: 1653
RE: *** Ultra Sport Brotherhood *** - 4/19/2012 12:20 AM
r/coldie
Score: 100
Last Login: 5/19/2013
Status: offline
What number are we up to.... I think 132.
I just picked up a used U.S.60 with a Thundertigre 60 and retracts. I LOVE It !!!!!
check out my video:   http://www.youtube.com/watch?v=Jmq_ppdArH0&context=C424ce70ADvjVQa1PpcFMhWO7vy24fatuhlMUfB4dwvENCGjuUrVA=
" The One Who Dies With The Most Toys, Wins....
Ultra Sport Brotherhood #132
Hide Signatures
       Post #: 1654
RE: *** Ultra Sport Brotherhood *** - 4/19/2012 2:36 AM
kgibson4
Score: 100
Status: online
r/coldie,
Nice plane!  That thing does great with the TT 60.  And with the gear deployed, too!
Ultra Sport Brotherhood #131
Hide Signatures
(in reply to r/coldie)
       Post #: 1655
RE: *** Ultra Sport Brotherhood *** - 4/19/2012 2:58 PM
scottrc
Score: 104
Status: offline
Great deal r/coldie.
Hide Signatures
(in reply to kgibson4)
       Post #: 1656
RE: *** Ultra Sport Brotherhood *** - 4/19/2012 7:40 PM
matadco
Score: 105
Last Login: 2/28/2013
Status: offline
Good looking bird, but if you have retracts why was the whole flight with gear down?
Hide Signatures
       Post #: 1657
RE: *** Ultra Sport Brotherhood *** - 4/19/2012 10:21 PM
r/coldie
Score: 100
Status: offline
The struts on the retracts keep bending and won't retract straight into the wing. I'm keeping them down until I get it fixed.
Hide Signatures
(in reply to matadco)
       Post #: 1658
RE: *** Ultra Sport Brotherhood *** - 4/19/2012 11:33 PM
matadco
Score: 105
Status: offline
Get heavier wires and make softer landings!! (I'm just bugging ye) I have machancal retrats on mine and kept stripping out gears on the cheep serve until I spend extra for a futaba servo. Gears are a little stronger and don't strip as easy.
Hide Signatures
       Post #: 1659
RE: *** Ultra Sport Brotherhood *** - 4/20/2012 1:59 AM
rebranger
Score: 100
Last Login: 4/25/2013
Status: offline
Mine keep bending also! I have tried coils, they help a little, increased size to 3/16, but they still bend. Now the set screws in the Robart mechanical retracts are stripping; drilled & tapped for #6. My US 120 size with a ST S-2300, pump (Vp-30) & Perry carb is heavy!! Cahnge fuel tank out 3 times, getting smaller, now down to about 14 oz, I love the plane & how it flies, but it surely is Heavy, weights 13#.s!!!
Best Regards
Ed
Hide Signatures
       Post #: 1660
RE: *** Ultra Sport Brotherhood *** - 4/20/2012 2:24 AM
r/coldie
Score: 100
Status: offline
I was thinking about removing the retracts and installing a strap landing gear, but I would rather get the retracts working right. That thing is beautiful with the landing gear sucked up !!!!!
Hide Signatures
(in reply to rebranger)
       Post #: 1661
RE: *** Ultra Sport Brotherhood *** - 4/20/2012 2:54 AM
Zor
Score: 181
Status: offline
Guys,
If you are able to find a business making springs (helicoidal springs).
Have the fellows bend the wire for you where the wheels are going on.
Bring your plane if necessary to show him what you have.
Spring steel will bend upon landing, absorbing shock, but always return to its original form.
So the retract would keep working fine.
I had many models with spring steel landing gears.
Good luck,
Zor
Hide Signatures
       Post #: 1662
RE: *** Ultra Sport Brotherhood *** - 4/20/2012 6:34 PM
rglgatortail
Score: 100
Status: offline
Grass fields do not get along with retracts no amount of thickness of wire will keep them from bending ask me how I know. Either you keep rebending the wire or you will just never retract the gear until you find you a paved runway to enjoy the retract business. That is a nice flying plane and that TT is a great match for it. I hope you enjoy the plane for a long time to come and welcome to the brotherhood.
Robert L. AMA #595312 ____ Club Saito #724
Ultra Sport Brotherhood #79
Hide Signatures
(in reply to Zor)
       Post #: 1663
RE: *** Ultra Sport Brotherhood *** - 4/20/2012 8:19 PM
Zor
Score: 181
Status: offline
quote:
ORIGINAL: r/coldie
r/coldie,
If you make or replace the wire that bends with spring steel wire as I previously posted your problem will be gone.
Think of the springs on the valves of your automobile engine or the helicoidal springs on the car suspension. They keep bending and keep bending but always return to original dimension and shape.
You can even bend the spring wire yourself with heating only the area of the bend for the wheels.
That is not where the present wire bends. The rest will remain a spring wire.
Zor
Hide Signatures
       Post #: 1664
RE: *** Ultra Sport Brotherhood *** - 4/22/2012 7:34 PM
hrrcflyer
Score: 121
Status: offline
quote:
ORIGINAL: hrrcflyer
quote:
ORIGINAL: Mustangman40
quote:
ORIGINAL: hrrcflyer
Well,
''Somone'' was looking out for me this weekend. I was sitting at my flying field yesterday in the 25 knot winds. I was the only person there and I was just getting ready to leave when a friend of mine who I hadn't seen in almost two years, pulls up in his van beside me. We got to talking and out of the blue, he asked me if I had ever got my US 60 kit finished. I told him no, that I sold the kit before I had a chance to start it. Then he proceeds to say ''If you want the one I have, you are more than welcome to it''. He said that he had to stripped the old monocote off and it was just sitting in his garage.... I could not say YES fast enough..........
So next weekend, I will be the proud owner of a US60. I need to find the thread where someone put retracts in their existing wing, because I want to do the same thing. Even though I doubt I can make it electric, I have a YS60 and a Hatori pipe that will suit it just fine.......YAAHHHOOOOO ! ! ! !
David, that sounds like a good combo and should be a blast.. I would look into electric retracts if it was me, I think that would be the way to go being it is built already....
Mustangman40,
You are absolutely right about using electric retracts. I have a pair of the original Lado electrics that I had in my H9 Miss America. The wing mods should be pretty simple. I am however having second thoughts on using my YS60 & pipe though. The motor is supposed to go with a Great Planes Illusion kit that I've been trying to get rid of for the last three years. I do have a backup motor however, a YS91 4 stroke, but if I remember correctly, my friend had a 2 stroke in it the last time I saw him fly it. So I doubt the YS91 will fit. Anyway, if it doesn't I still may put the YS60 on it or buy an OS 75AX for it.
David
Well,
It's looking better and better all the time. We had our anual spring club Fly-In on Saturday and my friend brought me my Ultrasport 60. Needless to say, I was one happy camper. I did confirm that the plane will need to be re-covered so while I was sitting down taking a break, I proceeded to start stripping off the old Monocote. I got over 95% of the wing stripped and most of the fuse as well. The day even got better when another friend and I were talking. I told him that the plane originally flew with an Enya 60 2 stroke. My friend told me he may have a spare motor I can use. When I asked him what he had in mind, he said he has a Webra Speed 61 with a header and pipe so I can save my YS60.
OMG, IS THIS A GREAT HOBBY OR WHAT ?
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
(in reply to hrrcflyer)
       Post #: 1665
RE: *** Ultra Sport Brotherhood *** - 4/25/2012 10:55 PM
Mustangman40
Score: 181
Status: offline
quote:
ORIGINAL: Tango Juliet
Don't forget to flesh-out that cockpit Mustangman, unless you're going to paint the canopy.
I went with painting the canopy, I think it gives it a good look..
Work kind of got in the way of progress, but I found some time today.. I need to get to the HS and get some more covering and my tail wheel, but here are a few pics to show you where I am at..
Jimbo
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Ultra Sport Brotherhood #92
Hide Signatures
(in reply to Tango Juliet)
       Post #: 1666
RE: *** Ultra Sport Brotherhood *** - 4/25/2012 11:58 PM
scottrc
Score: 104
Status: offline
Looking really nice
Hide Signatures
(in reply to Mustangman40)
       Post #: 1667
RE: *** Ultra Sport Brotherhood *** - 4/26/2012 1:45 AM
Tango Juliet
Score: 100
Last Login: 4/12/2013
Status: offline
I like it.
AMA#: 741093 Member: www.acma-rc.com www.tangojulietphotography.com
Ultra Sport Brotherhood #81
Hide Signatures
(in reply to scottrc)
       Post #: 1668
RE: *** Ultra Sport Brotherhood *** - 4/26/2012 12:56 PM
mrshea
Score: 100
Status: offline
i'm about to jaoin my wing. Question did ya'll epoxy on the ribs wo join or ca? I know to use it on the dihedral brace but the instructions say to epoxy that then lock the panels together wit ca. Just curious what you guy's did. Phil
Hide Signatures
       Post #: 1669
RE: *** Ultra Sport Brotherhood *** - 4/26/2012 2:22 PM
Mustangman40
Score: 181
Status: offline
quote:
ORIGINAL: mrshea
I used epoxy on the whole joining of the wing for the added strength...........
Hide Signatures
(in reply to mrshea)
       Post #: 1670
RE: *** Ultra Sport Brotherhood *** - 4/26/2012 2:25 PM
Mustangman40
Score: 181
Status: offline
quote:
ORIGINAL: scottrc
Looking really nice
It will look better once I get the rest of the stripes/color on.
Hide Signatures
       Post #: 1671
RE: *** Ultra Sport Brotherhood *** - 4/26/2012 5:36 PM
hrrcflyer
Score: 121
Status: offline
Hey Jimbo,
Great looking plane so far. I cannot wait to see it finished.................
David
Hide Signatures
       Post #: 1672
RE: *** Ultra Sport Brotherhood *** - 4/30/2012 4:58 PM
Tubthumper
Score: 100
Last Login: 9/24/2012
Status: offline
I'd like to join the brotherhood.  The last number I see is 132.  I'll take 133 if no one has it.  If it's taken where are we at?
Marc
Marc AMA# 943506
Ultra Sport Brotherhood #133
Hide Signatures
       Post #: 1673
RE: *** Ultra Sport Brotherhood *** - 4/30/2012 5:18 PM
rickbrad
Score: 100
Last Login: 5/17/2013
Status: offline
Will someone take over keeping the list from MinnFlyer?  Not me, I would never venture to step in those shoes.
Rick
Club Saito #725, Ultra Sport Brotherhood #104
Hide Signatures
(in reply to Tubthumper)
       Post #: 1674
RE: *** Ultra Sport Brotherhood *** - 4/30/2012 5:23 PM
Tubthumper
Score: 100
Status: offline
I'm just starting my US60 build.  I'm thinking about putting a Saito FG-14b on it. Does anyone have any feedback about this idea?
What most appeals to me about it is Saito's claim that it runs 20 minutes on 4oz of fuel plus it's a gasser.
I've been following a build thread on the US 60 and have decided to go with flaps too.  My radio is a DX7 and is capable of making flaperons.
Has anyone tried the flaperon route and if so how did things work out?
Thanks for the input.
Marc AMA# 943506
Hide Signatures
       Post #: 1675
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
