RE: *** Ultra Sport Brotherhood ***    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: *** Ultra Sport Brotherhood ***
Page: <<   < prev  72 73 74 75 [76] 77 78 79 80 81   next >   >>
Login
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 10:04 PM
KaP2011
Score: 115
Last Login: 6/19/2013
Status: offline
Aerobatic: 15x12-14, 16x10-14, 16.5x10-13
Sport: 17x10-13, 18x10-12
Straight from the OS web page.
_____________________________
KaP2011
AMA #408493
Hide Signatures
(in reply to richwill11)
       Post #: 1876
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 10:33 PM
72
Score: 100
Last Login: 6/7/2013
Status: offline
APC 18-6w or 16-8 3 blade.
Club Saito #614/Ultimate Brotherhood #57
Ultra Sport Brotherhood #34
Hide Signatures
       Post #: 1877
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 11:25 PM
richwill11
Score: 100
Last Login: 6/6/2013
Status: offline
With the 17 or 18" props on the os160fx, in your opinions do you think I will have adequate ground clearance for the prop?  Or will I need to use taller main retract struts?
Hide Signatures
(in reply to 72)
       Post #: 1878
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 11:50 PM
72
Score: 100
Status: offline
I'd say you need about 1" of ground clearance when the airplane is sitting on its wheels and the tail is up and level- takeoff attitude.
Hide Signatures
       Post #: 1879
RE: *** Ultra Sport Brotherhood *** - 10/25/2012 12:00 AM
richwill11
Score: 100
Status: offline
OK, it might be tricky, but I'll check the plans and see if I can obtain an estimated ground clearance measuring 9" from the center engine shaft (for an 18" prop) to see how far above ground the prop tip would be using the stock mains and 3" wheels that might be built with the kit.  Thanks for you help.
Hide Signatures
(in reply to 72)
       Post #: 1880
RE: *** Ultra Sport Brotherhood *** - 10/25/2012 3:30 AM
72
Score: 100
Status: offline
I just measured a set of plans I have and when the wing centerline is parallel to the ground - 0 incidence -  there is 9 1/2 inches to the prop hub. A 16 inch prop would give you 1 1/2 inches clearance.
Hide Signatures
       Post #: 1881
RE: *** Ultra Sport Brotherhood *** - 10/25/2012 4:13 AM
richwill11
Score: 100
Status: offline
How bout that; we're spot on!  I measured also using the same technique and got about the same.  The plans said to use 2 3/4" inch wheels for retracts.  So when I measured from the engine centerline to the line for ground on the bottom of the wheel, I got about 9 1/2" too.  So a 18" prop wouldn't give enough clearance, but the 16" give about 1 1/2".  So then I checked the APC web site and they offer 16" props starting at 3" pitch all the way up to 16" pitch.  Then I downloaded the manual for the engine from the tower site and it calls for several 16" props and one 16.5"  prop for aerobatic use.  It also lists a couple of 17" and one 18" prop for sportsman use.  So now I am happy and excited, because I think I can get the 160 installed OK.  This engine didn't exist back in the 90's, weighs less than the ST2500, and is about the samesize  as the os108 and puts out 3.7HP!  Also took measurements from the motor mount and engine from the tower site and measured the plans, and it will fit nicely.  So my winter project is laid out.
But gotta also figure out the retract install.
BTW, I'm planning to use an os engine mount, but it doesn't have any vibration isolators.  I saw Jtec's snuff vibe kit, but wasn't impressed because you have to drill out you new motor mount to use it.  Do you know of any other vibration mounts that are popular?  Thanks, Rich
Hide Signatures
(in reply to 72)
       Post #: 1882
RE: *** Ultra Sport Brotherhood *** - 10/25/2012 4:50 AM
72
Score: 100
Status: offline
If your prop is balanced and the firewall is solid, you won't have any problems. I am using the OS aluminium predrilled mount for mine. I have found the Xoar props are almost always balanced or require very little to get them that way. My favorite props lately are the Falcon props. I use these on everything up to a DLE111 and I have only had maybe one out of around 15 that needed any balancing.
Hide Signatures
       Post #: 1883
RE: *** Ultra Sport Brotherhood *** - 10/25/2012 9:26 PM
richwill11
Score: 100
Status: offline
Thanks for the info.  Am not familiar with Falcon and Xoar,but will check them out.
Hide Signatures
(in reply to 72)
       Post #: 1884
RE: *** Ultra Sport Brotherhood *** - 10/25/2012 10:21 PM
72
Score: 100
Status: offline
Here are the Falcons. He also has the Xoar's. I like the Falcons myself but have both.
http://www.thunderboltrc.com/index.php?main_page=index&cPath=162&zenid=uvfm7pgtjt3m2s1bgjli1kipf3
Hide Signatures
       Post #: 1885
RE: *** Ultra Sport Brotherhood *** - 10/25/2012 11:24 PM
richwill11
Score: 100
Status: offline
Wow!  This is fascinating stuff.  Thanks for letting me know what's available.  Seems I will need to know how to determine the correct pitch prop for my 160 engine.  Other that trial and error, is there a process to determine your engine requirements for a new engine?  Have you started building your 1000 yet?  Also, do you want me to address you by your first name our just #72?  Jus thought I'd ask.  Rich
Hide Signatures
(in reply to 72)
       Post #: 1886
RE: *** Ultra Sport Brotherhood *** - 10/26/2012 12:05 AM
jrf
Score: 105
Last Login: 6/15/2013
Status: offline
Richwill:
The best way to get the right prop to start with is to find out what other people are using. Do NOT go by the OS prop recommendations. They are intentionally oversized to keep the rpm, and therefore the noise, down for their European and Japanese markets. You will get much better performance and a lot lower operating temps by using the 18 x 6W or 16 x 8 three blade mentioned above.
Jim (My OS 160 fx has outlasted three airframes.)
Hide Signatures
       Post #: 1887
RE: *** Ultra Sport Brotherhood *** - 10/26/2012 2:16 AM
richwill11
Score: 100
Status: offline
Thanks, Jim!
Hide Signatures
(in reply to jrf)
       Post #: 1888
RE: *** Ultra Sport Brotherhood *** - 10/26/2012 3:20 AM
richwill11
Score: 100
Status: offline
Jim, who makes the 16/8 3 blade?
Hide Signatures
       Post #: 1889
RE: *** Ultra Sport Brotherhood *** - 10/26/2012 3:40 AM
72
Score: 100
Status: offline
Rich, Mezjlik and Zoar are 2 companies that make 3 bladed props. They are not cheap!!
I haven't started mine yet and won't until my house renos are done. Probably around Christmas. I have had 2 Ultrasport 60's which were each over 20 years old before they finally met their end.    Lash
Hide Signatures
       Post #: 1890
RE: *** Ultra Sport Brotherhood *** - 10/26/2012 11:59 AM
AJsToyz
Score: 304
Status: offline
Graupner, Master Airscrew are a couple others on the 3 blade props.
www.Deathbychina.com
Hide Signatures
(in reply to 72)
       Post #: 1891
RE: *** Ultra Sport Brotherhood *** - 10/26/2012 4:40 PM
jrf
Score: 105
Status: offline
Master Airscrew makes a 16 x 8 and a 16 x 10 three blade. They are not the most efficient props in the world, but the 160 in a US 1000 does not need to struggle to get the last few %.
Graupner makes 16 x 8 three blade that is more efficient, but expensive. (Google "graupner prop")
Jim
Hide Signatures
       Post #: 1892
RE: *** Ultra Sport Brotherhood *** - 10/26/2012 7:42 PM
richwill11
Score: 100
Status: offline
Thanks for the other prop sources, guys.  Lash, I won't be starting mine til around the same time or after the first of the year.  I mainly want to do the research to make sure that the upgraded components that I want to use will work, and I've found that they are.  Can someone comment on what prower range digital  servos that I should consider.  I'm thinking of Futaba or Hitec brands.  Rich
Hide Signatures
(in reply to jrf)
       Post #: 1893
RE: *** Ultra Sport Brotherhood *** - 10/26/2012 8:26 PM
box car
Score: 100
Last Login: 6/17/2013
Status: online
Read this before you get digital servos
http://www.rcgroups.com/forums/showthread.php?t=801545
Ken
Wherever conversion engines are outlawed, only outlaws will have conversion engines.
Hide Signatures
       Post #: 1894
RE: *** Ultra Sport Brotherhood *** - 10/26/2012 9:10 PM
richwill11
Score: 100
Status: offline
Thanks!
Hide Signatures
(in reply to box car)
       Post #: 1895
RE: *** Ultra Sport Brotherhood *** - 10/27/2012 3:23 PM
pt19 flyer
Score: 100
Status: offline
hi rcken
got a question for you.
on the list I an listed as #97 but on some of the replies, etc
I am listed as #98.
so which one is correct? I assume that since I am #97 on list
that it is the correct one.
thanks
pt19 flyer
BROTHERHOODS ULTIMATE #91 USPORT#97 CUB #133
Hide Signatures
(in reply to RCKen)
       Post #: 1896
RE: *** Ultra Sport Brotherhood *** - 10/31/2012 6:12 PM
AmishWarlord
Score: 121
Last Login: 6/14/2013
Status: offline
Saw a US 1000 up for bid on ebay.
http://www.ebay.com/itm/Great-Planes-Ultra-Sport-1000-Radio-Controlled-Airplane-Kit-/121007690683?pt=US_Character_Radio_Control_Toys&hash=item1c2c9ed3bb
Hide Signatures
(in reply to pt19 flyer)
       Post #: 1897
RE: *** Ultra Sport Brotherhood *** - 10/31/2012 8:27 PM
hrrcflyer
Score: 127
Status: offline
Hello Rich,
I recently had an Ultrasport 1000 with an OS 160 FX. If you decide to go the analog route with your servo's, I used a Futaba 9202 on each elevator half, a 9202 on each aileron and a 9402 on the rudder. If you want to go the digital route, I suggest something in the same torque range. Personally, I wouldn't use a Hitec servo for a paper weight, but of course the choice is yours.
Good luck with your kit construction.
David
Oh BTW, I just remembered that Futaba doesn't make the 9202 anymore. So if you don't already have any, you will need to find an equivalent servo.
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
       Post #: 1898
RE: *** Ultra Sport Brotherhood *** - 10/31/2012 11:02 PM
richwill11
Score: 100
Status: offline
Mannn, thanks for your input, David.  Yes, I've used 9202's before in one of my older helis.  Am also, thinking of going the Sbus route since I need to purchase receiver, servos and all.  Maybe even and HV system with a lipo to keep weight down.  Your thoughts?  If you have a picture, send me one.  I'd like to see your servo setup.  Also thinking of doing flaps.  Did you do flaps?  This plane will have more servos than I've had in a model.  Thanks for your help, Rich
Hide Signatures
(in reply to hrrcflyer)
       Post #: 1899
RE: *** Ultra Sport Brotherhood *** - 11/10/2012 11:11 PM
What Tree
Score: 100
Last Login: 1/7/2013
Status: offline
Just finished a US 60. Irvine .61 Power, can't seem to upload a pic. what number does this make me?
Hide Signatures
       Post #: 1900
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
