RE: *** Ultra Sport Brotherhood ***    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: *** Ultra Sport Brotherhood ***
Page: <<   < prev  72 73 74 [75] 76 77 78 79 80 81   next >   >>
Login
RE: *** Ultra Sport Brotherhood *** - 9/24/2012 5:49 PM
KaP2011
Score: 115
Last Login: 5/22/2013
Status: offline
Thanks Zor. What you are saying is pretty much what I thought.
I'm not out to fly 3D with my US60 but I do want it to fly vertical until I pull back on the throttle. I don't think a .61 or the .75 is capable of that on an 8lb airplane no matter what prop I put on it. I also don't think the FS .95 would do it either. The .95AX may be capable but I can't go larger than a 14" prop.
I have been told by some of the guys in my club that I'm barking up the wrong tree without a paddle
_____________________________
KaP2011
AMA #408493
Hide Signatures
(in reply to Zor)
       Post #: 1851
RE: *** Ultra Sport Brotherhood *** - 9/26/2012 8:24 AM
Gordie M
Score: 100
Last Login: 2/11/2013
Status: offline
Kap,
Try measuring the thrust with the plane tethered to a fish scale and engine / prop full throttle, you'd want to see the fish scale reading more than 8lbs (at a quess I'd say about 30% more) to get 1 to 1 thrust.
The 95AX is going to give you all the vertical you need for sure. I would see the down sides as prop diameter and torque roll. When you snap the throttle open, I'm picking the plane will want to roll around the engine a bit. My Tower Kaos at just over 5lbs with a 55AX does this, especially on a landing overshoot from a slow air speed / low throttle to instant  full throttle, upsets the plane a bit if you bang the throttle in to fast. It's not an issue at higher air speed.
I've also bend my own 3/16 wire gear and lengthened it 1 inch even for the 13 inch props I use with the trike gear configuation. The 3/16 diameter is way stronger than the kit 5/32 wire gear.
Cheers,
Gordie.
Ultrasport brotherhood #29
Hide Signatures
(in reply to KaP2011)
       Post #: 1852
RE: *** Ultra Sport Brotherhood *** - 9/26/2012 1:56 PM
thom25
Score: 100
Last Login: 5/17/2013
Status: offline
Kap,
My US60 with OS-.75AX,APC 14X8, Spring air main gear retracts with 3/16" struts, weighs 8.125#. I can fly straight up until I pull the throttle back! A larger engine may give more power but the prop diameter will be limited by the gear length. A larger engine may also add nose weight that may require tail weight to balance, thus increasing over all weight and reducing thrust to weight ratio. Try the OS .75AX/APC14x8 combo you will like it.
Thom
Thom
AMA #73928, Simla #4, Ultra Sport Brotherhood #138
Hide Signatures
       Post #: 1853
RE: *** Ultra Sport Brotherhood *** - 9/26/2012 2:19 PM
KaP2011
Score: 115
Status: offline
Ok, I'm convinced, I'll order the .75AX. I have been worried that the .95AX would make it too nose heavy and prop clearence for a larger engine will be an issue. My landing gear is 5" from the bottom of the wing to the axle which should give me about an inch of clearence with a 14" prop.
KaP2011
AMA #408493
Hide Signatures
(in reply to thom25)
       Post #: 1854
RE: *** Ultra Sport Brotherhood *** - 9/26/2012 3:12 PM
prgonzalez
Score: 110
Status: offline
My US60 has a Tower Hobbies 0.75 engine with 12x6 APC. Last time I checked, it was pulling over 9 lbs of static force (WOT) checked with a fish scale at the tail wheel . With a dry weight of 7.0 lbs even, she goes unlimited vertical at 3/4" throttle. An US60 at 8 lbs would not be a problem either.
Spitfire Brotherhood #96, Ultra Sport Brotherhood #20
Hide Signatures
       Post #: 1855
RE: *** Ultra Sport Brotherhood *** - 9/27/2012 1:50 PM
Zor
Score: 181
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: Gordie M
Kap,
Cheers,
Gordie.
Hello Gordie,
The following is written more for the general reader.
You probably know this already.
The speed of the human being nervous system communication is such that reaction time is typically one half (1/2) second. The fastest ever measured was one quarter (1/4) second.
For that reason it is best to apply the throttle smoothly in about a two second motion so that if unexpeced model motion takes place then the pilot is able to react fast enough.
Instannt full throttle is not recommended.
Comparing 3/16" dia wire to 5/32" dia wire, the 3/16 is 1.440 times stronger if made of the same material and heat treated with the same procedure.
Have a great day all.
Zor
Hide Signatures
(in reply to Gordie M)
       Post #: 1856
RE: *** Ultra Sport Brotherhood *** - 9/27/2012 4:49 PM
JNorton
Score: 149
Status: offline
Interesting reading about reaction time. http://www.humanbenchmark.com/tests/reactiontime/stats.php
John
Have desk ... Will Fly.... Saito Member #467
Ultimate Brotherhood #11, Ultra Sport Brotherhood #90
Hide Signatures
(in reply to Zor)
       Post #: 1857
RE: *** Ultra Sport Brotherhood *** - 9/29/2012 10:27 PM
Zor
Score: 181
Status: offline
quote:
ORIGINAL: JNorton
John
Hi JNorton . . . long time no see you.
There is a reaction time testor on that site.
I had seen this site a long time ago or a similar site which is from where I remembered some values.
Just tried this site from your posting and I averaged between 250 and 300 ms.
Perhaps typical for an old fellow   .
Zor
Hide Signatures
(in reply to JNorton)
       Post #: 1858
RE: *** Ultra Sport Brotherhood *** - 9/29/2012 11:55 PM
KaP2011
Score: 115
Status: offline
Haha, fun game. best I could do was 231ms after 10 clicks.
KaP2011
AMA #408493
Hide Signatures
(in reply to Zor)
       Post #: 1859
RE: *** Ultra Sport Brotherhood *** - 10/2/2012 8:18 PM
corch
Score: 101
Status: online
LOL, 205.3 avg of five clicks...must be all the video games of my youth.
I had started this kit as my first kit around Feb, but life got in the way with an illness leading to death in the family, so on...
got out to the field for the fourth time this year last sunday, and a buddy had a US40.  He let me fly it, and let's just say, I have now been "re-inspired" to dust off the sanding block and 11 blade and "get back to work."
Urge Congress to keep common sense in the skies
Hide Signatures
       Post #: 1860
RE: *** Ultra Sport Brotherhood *** - 10/2/2012 9:52 PM
Zor
Score: 181
Status: offline
quote:
ORIGINAL: corch
corch,
Nice to see you in the spirit of being a real modeler again.
Zor
Hide Signatures
(in reply to corch)
       Post #: 1861
RE: *** Ultra Sport Brotherhood *** - 10/3/2012 9:49 PM
fly2fly
Score: 100
Last Login: 5/9/2013
Status: offline
A couple of months ago the battery came loose in my US1000 and the plane was destroyed. I was so depressed, I didn't fly for a month and almost quit the hobby.
However a couple of weeks ago I was luckey enough to buy another 1000 that I found on this site. I'm gonna stick with the OS 1.08 from the first plane.
I have flown many plane but the Ultra Sport is my favorite. Flys like a pattern ship and lands like a trainer. I'm not a builder but I love thewse planes and would be honored to join the brotherhood.
The blue one was my first one :-(.  The white one is the new one.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by fly2fly -- 10/3/2012 10:13 PM >
Hide Signatures
(in reply to rglgatortail)
       Post #: 1862
RE: *** Ultra Sport Brotherhood *** - 10/3/2012 10:37 PM
scottrc
Score: 104
Last Login: 5/21/2013
Status: offline
Both your old one and your new one are mighty nice looking planes fly2fly.
If you love your plane, set it free, if it doesn''t return, you should have checked the battery.
Hide Signatures
(in reply to fly2fly)
       Post #: 1863
RE: *** Ultra Sport Brotherhood *** - 10/4/2012 3:06 AM
fly2fly
Score: 100
Status: offline
Thanks, I'm kind of partial to the two  tone scheme of the blue and white. It reminds me of the classic pattern ships of the 70's. It was beautiful. I couldn't find out who built it but I would like to shake his hand. I still have the shattered pieces in a big box. I might try to see if someone can rebuild it for me. I just can't do it.
The white one with the blue, yellow and red trim was built by Dennis Sarette (hope he doesn't mind) of NH. This guy is a master builder and coverer. To say it looks factory would be an insult.I hate to admit it but this is actually a better plane than the old one. It has wing filets, pull/pull rudder, oversized landing gear, and some other goodies that the other one didnt have. If you buy a plane from this guy, it's going to be top quality. I'll try to post some more photos in my gallery.
Yours are nice also. I would love to have a 40 or 60 in my hangar that I could fly when I dont feel like lugging out the big guy.
Hide Signatures
       Post #: 1864
RE: *** Ultra Sport Brotherhood *** - 10/4/2012 10:47 PM
tschuy
Score: 111
Last Login: 5/20/2013
Status: offline
Okay....
You all are forcing me to clear my bench and get back to building my US1000...
Nicely done...
Cheers,
Tim Schuy
tschuy@comcast.net
Hide Signatures
(in reply to scottrc)
       Post #: 1865
RE: *** Ultra Sport Brotherhood *** - 10/11/2012 4:51 PM
rglgatortail
Score: 100
Status: offline
Your in Yak13.
1. Ken Isaac - RCKen
2. Mike Buzzeo - Minnflyer
3. Alex7403
4. Dash008
5. AH1G
6. tschuy
7. MILDBILL-RCU
8. Box car
9. Top Gunn
10. SeaJay
11. Crash Campbell
12. SKYHI1
13. ChuckW
14. RhyanO
15. landeck
16. Ilikebipes
17. airbusdrvr
18. Insanemoondoggie
19. daisy shoot
20. prgonzalez
21. BelAirBob
22. hrrcflyer
23. rastus1
24. tony0707
25. *JCB*
26. Redback
27. bigugly
28. MetallicaJunkie
29. Gordie M
30. Jim_Purcha
31. rcsws
32. jeffsend
33. fireman7875
34. 72
35. ser00
36. Oly
37. cpeisher
38. donzhere
39. SKYHI1
40. kbarko
41. pgilbert
42. rambler53
43. rcjets_63
44. dschroeder
45. Quikturn
46. blueapplepaste
47. green river rc
48. SushiSeeker
49. VCScott
50. FallDownGoBoom
51. ccp10
52. Deadeye
53. Eganwp
54. carlosponti
55. Navy18
56. MineBurg
57. Cdallas2
58. loopyrc
59. Sled
60. Bernard
61. jrbmoto
62. Bubba153
63. Alfredbmor
64. FentonFlyer
65. Sneakywrist
66. BLW
67. smkrcflyer
68. gabarber
69. Amishwarlord
70. JPMacG
71. kamakazie frank
72. RussianFlyer
73. RoyR
74. Red Jeepster
75. Fallingleaf
76. Yukonflier
77. rcjim000
78. goonybird1
79. rglgatortail
80. Latebreaker
81. Tango juliet
82. Saito18
83. hafidy
84. RR24
85. mechdrew
86. siko_flyer
87. Kit
88. n7188u
89. gerryndennis
90. JNorton
91. misterv
92. Mustangman40
93. OntAeronut
94. proptop
95. scottrc
96. scirocco14
97. pt19 flyer
98. Doug47
99. b.bixel
100! bikerbc
101. weezle
102. Mtthwacrss
103. matadco
104. rickbrad
105. GaryHarris
106. Roary m
107. P47Tbolt
108. jp boud
109. arrdee
110. KaP2011
111. HFrank
112. custombuiltrc
113. jquid
114. dasquirrelisme
115. KC10Chief
116. _Tommy D
117. Do328jet
118. sirzepp
119. mrshea
120. AJsToyz
121. svenska3
122. I FLY
123. turnscrew
124. SteveW
125. Super08
126. ma_mulcahy
127. digital_trucker
128. ARTP47
129. us020140
130. Profiled
131. kgibson4
132. r/coldie
133. Tubthumper
134. JH313
135. TWIN FLYER
136. Fliegerboy
137. Doug Robinson
138. thom25
139. Yak13
Robert L. AMA #595312 ____ Club Saito #724
Ultra Sport Brotherhood #79
Hide Signatures
(in reply to Zor)
       Post #: 1866
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 1:42 AM
richwill11
Score: 100
Last Login: 5/15/2013
Status: offline
OK guys, I wana be in too!  I guess I would be #140.  I own a US40 that I built and flew a lot back in the early 90's.  What a great flying plane.  But back then I also purchased a 1000, ST2500, and acquired OS108.  I've just decided to finally build the 1000.   But from what I've read, the engines I have may be a little small.  So I've been looking at an OS160FX.  It's the same weight as the ST2500 and puts out 1hp more.  So please tell me what you guys think.  I wanna do the right engine and retracts too.  Happy I found your group.   Rich
Hide Signatures
       Post #: 1867
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 2:41 AM
72
Score: 100
Last Login: 5/16/2013
Status: offline
Rich, I'm planning a 1000 with the OS160 too. Don't know about the retracts or not yet but I think the OS will be a great engine for this.
Club Saito #614/Ultimate Brotherhood #57
Ultra Sport Brotherhood #34
Hide Signatures
(in reply to richwill11)
       Post #: 1868
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 2:51 AM
richwill11
Score: 100
Status: offline
That's great!  Maybe we can keep in touch to compare notes.  I'm planning to take my time and start my build either before or after xmas.  Don't know about retracts either other than they'd be nice, but may also cost more that I wanna spend.  Rich
Hide Signatures
(in reply to 72)
       Post #: 1869
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 2:58 AM
72
Score: 100
Status: offline
I'm thinking maybe a fuselage mounted carbon fiber gear taildragger.
Hide Signatures
       Post #: 1870
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 3:21 AM
richwill11
Score: 100
Status: offline
yeah mine will be a tail dragger also.
Hide Signatures
(in reply to 72)
       Post #: 1871
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 3:23 AM
Twin_Flyer
Score: 108
Status: offline
72, is the two or four cycle OS 160?
I was thinking of going to a 160 twin, but not in the mood the cut and redo the front so maybe a Saito 150 or YS 140 instead.
I'd still like gas (DLE 30?) but havent found any real feedback from anyone who has done that plus not sure if I have enough prop clearence with the exisiting gear.
Bill S.
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
(in reply to 72)
       Post #: 1872
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 4:28 AM
72
Score: 100
Status: offline
I have an OS 160fx 2 stroke. I also have a dle 20 and 30 but I think the gas engines will require too much of the nose to be cut away to fit around the gassers and it just wouldn't be an Ultrasport anymore. Love my gassers but the Ultra needs to keep its lines I think!!
The dle 30 swings a 19/8 prop so clearance would be bad also. I am running this engine in an EF Yak 74" and it has long gear so no problem there.
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 1873
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 7:21 PM
richwill11
Score: 100
Status: offline
Do you by chance know what the useful prop range might be for the OS160fx?  Trying to determine if there might also be a problem with the ultrasport installation especially with retracts.  Thanks, Rich.
Hide Signatures
(in reply to 72)
       Post #: 1874
RE: *** Ultra Sport Brotherhood *** - 10/24/2012 7:22 PM
richwill11
Score: 100
Status: offline
Sorry I meant to say prop ground problem.
Hide Signatures
       Post #: 1875
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.938RCU1
