EQ6 and Formeco 8-Ball    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> EQ6 and Formeco 8-Ball
Page: [1]
Login
EQ6 and Formeco 8-Ball - 4/26/2010 4:08 AM
NiknJen
Score: 100
Last Login: 5/23/2013
Status: offline
Hello, I have an EQ6 and I am wanting to set the voltage regulator to 6 volts for the servos. Can I use my Formeco 8-Ball voltage tester to check the voltage while setting it? I was hoping to just plug the 8-Ball into an empty servo connection on the smart fly and adjust.
What I was wondering is this, the 8-ball first applys a one amp load for a few seconds, reads, then reads without the load. Will the one amp load mess up the EQ6? I would obviously wait until the load was off to set the voltage.
-Nick
Hide Signatures
       Post #: 1
RE: EQ6 and Formeco 8-Ball - 4/26/2010 6:16 PM
rrritchey
Score: 100
Last Login: 5/20/2013
Status: offline
Hi,
Yes, you can test using the 8-ball and empty servo slot.
_____________________________
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
(in reply to NiknJen)
       Post #: 2
RE: EQ6 and Formeco 8-Ball - 4/27/2010 7:59 PM
NiknJen
Score: 100
Status: offline
Thanks the 8-Ball worked great.
One more question, I know a fully charged 6 volt battery reads more than 6 volts. What do you suggest setting the regulator at to represent a fully charged 6 volt battery. I'm using Futaba 9157s
Hide Signatures
(in reply to rrritchey)
       Post #: 3
RE: EQ6 and Formeco 8-Ball - 4/27/2010 8:44 PM
rrritchey
Score: 100
Status: offline
Hi,
What kind of batteries are you using on the Eq6? I need to know this to tell you what the maximum voltage you can set the regulator to without dropping out at the end of battery life.
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
       Post #: 4
RE: EQ6 and Formeco 8-Ball - 4/27/2010 9:43 PM
NiknJen
Score: 100
Status: offline
2- Flight Power 2200 mAh 2s 7.4 Lipo's. I'm running 7 - 9157's and one standard digital servos.
Hide Signatures
       Post #: 5
RE: EQ6 and Formeco 8-Ball - 4/27/2010 9:46 PM
rrritchey
Score: 100
Status: offline
Hi,
You can set the Eq6 up to its limit of 6.5V if you want. You might want to check the voltage the 9157s can take. Futabas are a lot pickier about voltage than JRs or Hitecs.
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
       Post #: 6
RE: EQ6 and Formeco 8-Ball - 4/28/2010 5:31 AM
NiknJen
Score: 100
Status: offline
Thanks for the prompt replies, I'll check the suggested voltage.
-Nick
Hide Signatures
       Post #: 7
RE: EQ6 and Formeco 8-Ball - 6/24/2010 11:48 AM
billybriggs
Score: 100
Last Login: 11/23/2011
Status: offline
Hi Robert, Bill Briggs here getting ready for Vegas fri wedding for one of my nieces. Taking the Extra to Fly first flite down at Bennet field. I cant seem to get my Eq6 to set on Channel 5 of my RD 8000. did all the things to set like you say in the instructions. It flashes and everything like it is supposed to but I still when I throw the toggle switch on the radio nothing happens the light to the engine stays on and always has juice to the engine what is wrong or do i have a bad eq or should I reset everything back to original again. Can you help me I hope cant get a hold of Jeffrey right now he works and dont want to worry him to much I know he knows radios but I was thinking there might be something about the Airtronics that might be different to do can you help me. If I dont get back to you right away I might be in vegas. thanks Bill Briggs dokbriggs@verizon.net
Hide Signatures
       Post #: 8
RE: EQ6 and Formeco 8-Ball - 6/24/2010 6:58 PM
rrritchey
Score: 100
Status: offline
Hi Bill,
If you can call me at the office, 480-460-2652, and be with your plane I can probably help you. I really doubt the Eq6 has a problem. Also, take a spare servo and plug it directly into the receiver on the channel you have programmed for the cutoff and make sure the switch activates the servo.
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
(in reply to billybriggs)
       Post #: 9
RE: EQ6 and Formeco 8-Ball - 7/31/2010 1:11 PM
Karlsson
Score: 105
Last Login: 10/20/2012
Status: offline
[Quote] ORIGINAL : rrritchey
Excuse my bad description before! Tell me how I change the tension in EQ6
Sincerely. Roger
< Message edited by Karlsson -- 8/1/2010 12:16 PM >
Hide Signatures
       Post #: 10
RE: EQ6 and Formeco 8-Ball - 7/31/2010 6:51 PM
rrritchey
Score: 100
Status: offline
Hi,
You need to use a voltmeter on one of the servo outputs while you are setting the voltage of the regulator.
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
(in reply to Karlsson)
       Post #: 11
RE: EQ6 and Formeco 8-Ball - 8/1/2010 3:03 PM
Karlsson
Score: 105
Status: offline
quote:
ORIGINAL: rrritchey
Hi,
I know I should use a voltmeter, but how do I change the EQ6 to get a different voltage? I does not see it in the manual!
Sincerely. Roger
Hide Signatures
       Post #: 12
RE: EQ6 and Formeco 8-Ball - 8/1/2010 7:17 PM
rrritchey
Score: 100
Status: offline
Hi Roger,
Its in the "PowerSystem Eq6 User Guide" under "Adjusting The Output Voltage". If you have misplaced this manual you can download it from the website.
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
       Post #: 13
RE: EQ6 and Formeco 8-Ball - 8/2/2010 9:45 PM
Karlsson
Score: 105
Status: offline
quote:
ORIGINAL: rrritchey
Hi Roger,
Its in the ''PowerSystem Eq6 User Guide'' under ''Adjusting The Output Voltage''. If you have misplaced this manual you can download it from the website.
Hello!
I fixed it by setting Volter!
Thanks for the info!
Sincerely. Roger
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.016RCU1
