Great Planes Master Caddy field box
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> User Product Reviews >> Great Planes Master Caddy field box
Page: [1]
Login
Great Planes Master Caddy field box - 7/18/2003 10:07:50 AM
suitcase
Status: offline
I don't know how well other brands of field boxes are but this one is of very poor quality. Right out of the box it strikes you as cheap. It came with several seams pulled loose and the back of two drawers were separated. The APS Tote that detaches doesn't fit properly because the screws that hold it are not on the same centers as the box. I had to use one of the screws that holds the fuel jug velcro keeper to hold one side on at the top. Reharging the 12v battery will require removing four screws to get to the battery. It did have all of the hardware and was simple to assemble. I've only used it once so I don't how it will hold up in the long run.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXPS86&P=7
< Message edited by suitcase -- Jul 18 2003 5:13AM >
       Post #: 1
RE: Great Planes Master Caddy field box - 11/28/2003 6:36:55 PM
Stik-n-Rdr
Status: offline
Just got mine in and agree with you. I haven't started assembly, but it sure looks cheaply made. Sure hope I don't have the same problems you did. What's up with the power panel hole? Why couldn't it be sized correctly for my Tower Hobbies Deluxe PP so I don't have to make it larger?
How's yours holding up at the field (the true test)?
(in reply to suitcase)
       Post #: 2
RE: Great Planes Master Caddy field box - 11/28/2003 11:06:43 PM
jboy381-RCU
Status: offline
they must make them on friday or monday thanks for the heads up on this product...
john
_____________________________
count your blessings,not your problems
(in reply to Stik-n-Rdr)
       Post #: 3
RE: Great Planes Master Caddy field box - 11/28/2003 11:45:52 PM
Stik-n-Rdr
Status: offline
I'm putting it together now and it's not too bad. I had to enlarge the power panel slot quite a bit. The wood for the trays looks a little frazzled, but that's all. The trays slide in and out just fine. The rest of the box, including the finish, is actually not bad at all. Time will tell. Here are some pictures for you (excuse the cat, she's always got to be right in the middle of what I'm doing).
Oh, the box on the right of the wide angle shot is my Goldberg Extreme 330 that I ordered with the box. I'll be working on that tomorrow (yeah!). The plane in the background is a Sonic Low Wing 25 ARF that flies great.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to jboy381-RCU)
       Post #: 4
RE: Great Planes Master Caddy field box - 11/29/2003 4:47:14 AM
Stik-n-Rdr
Status: offline
I'm finally done. Had to solder panel connectors onto my starter, fuel pump, and battery charger. The box was easy to put together but weighs a ton now that it's full of my 'critical items'. Sure hope it holds up.
I'm going to charge my battery through the starter connectors on the panel. I don't see a reason to take the APS side off to charge the battery as long as I'm careful and don't have my fuel pump and glow circuit turned on.
So far I'm happy with the box. Now I'll have everything I need in one place and right next to me and the plane on the ramp.
Here are some completed pictures.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 5
RE: Great Planes Master Caddy field box - 12/2/2003 10:50:21 PM
Mike Ledbetter
Status: offline
I have the same unit and am very happy with it. You can charge the 12V battery from the terminals on the front. It holds all the heavy stuff I have to take to the field.
I put mine together with Gorilla Glue and finished it with two coats of Varathane DiamondKote.
Nice unit. Regards.
       Post #: 6
RE: Great Planes Master Caddy field box - 12/2/2003 11:24:05 PM
Stik-n-Rdr
Status: offline
Good to know someone likes the Master Caddy. I'm lazy so went with the stock setup. Like I said, the wood in the drawers was a little cheesy but everything else is pretty tough. I'll repair this one, or buy another if it succumbs to fuel damage. I figure I'll get one to two years out of it and will build my own once I figure out what I need/want.
How did you route your fuel pump leads to the power panel? I figured the best location for the pump would be as close to the jug as possible, so am stretching my leads to the panel along the starboard side of the box.
Thanks for your input Mike.....
(in reply to Mike Ledbetter)
       Post #: 7
RE: Great Planes Master Caddy field box - 12/3/2003 9:16:36 PM
Mike Ledbetter
Status: offline
No electric fuel pump for me; you'd have to disconnect it to use the APU separate from the master caddy. I pump my 8 ounces of fuel into the plane manually
       Post #: 8
RE: Great Planes Master Caddy field box - 12/4/2003 12:05:32 AM
CAPtain232
Status: offline
I have the KIT VERSION and it has been GREAT
CUSTOM GIANT SCALE BUILDER
PROTOTYPE MODEL BUILDING for full scale aircraft
current project can be seen at http://www.geversaircraft.com
       Post #: 9
RE: Great Planes Master Caddy field box - 12/24/2003 5:40:34 PM
rik756
Status: offline
I bought the Pre-Built version and it too appears fairly cheap. I beaded some thick around all the major seams and wicked some thin into the seams of the drawers. I had not desire to remove the APU so I permanently attached it with some wood screws and a metal strap on the bottom. I have to admit I was hoping for more quality myself but overall it's not been bad. The paint they use it super thick so I imagine it's pretty fuel proof and it is resistant to the little dents/dings that would scratch a thinner paint.
(in reply to CAPtain232)
       Post #: 10
RE: Great Planes Master Caddy field box - 12/24/2003 7:02:04 PM
aaron2874
Status: offline
I bought the kit and used it for a year. It's held up real nice. I was generous with the glue and reinforced all wood joints with brads. However, it just wasn't big enough for all my stuff and it was very heavy. Then, I found "the ultimate field box from Hell" while perusing the forums here. Check out the link below. I've been using a similar box for the last two years and it is great!! My GP master caddy has been shelved ever since. And the best part is the price. About 30 bucks. Whoever designed this box should get an award. It was definately made for the lazy man in me. Great idea Billy!!!
http://www.rcuniverse.com/forum/fb.asp?m=167247&key=hell
24 hours in a day. 24 beers in a case. Coincidence? I think not!
(in reply to rik756)
       Post #: 11
RE: Great Planes Master Caddy field box - 12/26/2003 1:50:02 AM
Rocketman612
Status: offline
I also have the kit version and it went together with no problem. Looks good and has held up well for over 3 yrs. Pete
"Remember, all im offering is the truth, nothing more..."
Morpheus
(in reply to aaron2874)
       Post #: 12
RE: Great Planes Master Caddy field box - 12/6/2004 12:11:08 AM
Warbird Brian
Status: offline
Deleted. Did a seqarch and this came up. Didn't realise it was in the review section. I was going to ask a few questions...
WBB over and out
< Message edited by Warbird Brian -- 12/6/2004 12:12:52 AM >
(in reply to Rocketman612)
       Post #: 13
RE: Great Planes Master Caddy field box - 12/6/2004 2:15:31 AM
Stik-n-Rdr
Status: offline
Ask away Brian. I've been using my Master Caddy for close to two years now and love it.
I'm starting to go gas in the next few months so will probably go with just a gas can and hand pump for my next field box.
(in reply to Warbird Brian)
       Post #: 14
RE: Great Planes Master Caddy field box - 1/1/2005 5:54:03 PM
starscream25
Status: offline
does somebody know where i can get the instruction manual...
       Post #: 15
RE: Great Planes Master Caddy field box - 1/2/2005 12:06:35 AM
Stik-n-Rdr
Status: offline
It's not on Great Planes website that's for sure.
Good luck.
(in reply to starscream25)
