Flyboy Dave
Joined: 3/20/2002 From: San Bernardino County, CA, USA Status: offline
....it's not that bad of a motor, just not really powerful. Things that exasperate the problems (aside from the cheap needle valve) are sometimes operator induced. I'm not saying that some guys don't know how to run 'em....but listen.... : .... In the first place, the FX is NOT a big powerful motor. You guys are way over-propping them, adding to the overheating problems. Put a 13-6 on it, and let it turn. Secondly, the big ABC engines need to run a little richer than a ringed motor, they run hotter. The fuel....(here we go : )....I just saw a guy wipe out a new Magnum .91 XLS with three runs, with a cowled motor, on synthetic only oil. Shot....no compression. The big ringless motors need castor oil to survive, plain and simple. Use some 15% Powermaster, and dump 4 oz more castor in it....the motor wont fry.... Cowlings, and Pitts mufflers are nice....but they add to the overheating problems. Given a chance the Fx is ok, just not a powerhouse. With the right prop, fuel, lubrication, cooling, tuning, and some proper break-in....they will run fine, and not overheat. Dave.
_____________________________
An engineer says.... "That won''t work". A mechanic says..."Oh yeah, watch this". "Old Age, and Treachery will overcome youth and skill". Revver Bro #4.
