lucien
NM, USA Status: offline
[QUOTE]Originally posted by FLYBOY Would like to, but have had it for about a year. I thought about sending it to them anyway and seeing what they charge to test it and see what they can do, but with 3 of them having the same problems, I figure I am ready to cut my losses and use a different brand. I have a new Webra Speed 61 in the box that will fly the plane well, or an old 61 SF that runs great. Wish I wouldn't have sold my Super Tigre .75. Will probably order another one. They run so well. I have an NIB 91 FX yet. Was going to put the pair in a Super Duelist I have. Not even a consideration now. Have to get a pair of ST .75s instead. Bummer. As you said, Lots of time spent in R and D. Too bad they didn't spend a little more and make something that works. I have also heard about an oversized O ring tower sells in packs of 2 for $15. Bad enough that they can't make it work, but then they rape you on a 50 cent O ring. Thats adding insult to injury. [/QUOTE] I've been following this for a while myself. I used to have a .61fx; it was mounted on a great planes ugly stick. It was the most flawlessly running motor I've ever owned and it never gave any problems either on the plane or on the bench. I'm about to purchase a 1.60fx for another project. My personal suspicion is a fuel flow problem (what else could it be) caused probably by excessive heating of the needle valve unit. This looks particularly troublesome on the .91fx, being as how, just eyballing a picture of the motor, the needle is _right_ there behind the head (and that motor probably runs hot anyway due to the large displacement/small crankcase size) and attached directly to the backplate of the motor by a surely very good heat-conducting flange. The .61fx probably doesn't have the problem to that great of a degree since it's a smaller motor (puts out less heat) and the needle valve doesn't appear to be right behind the head. That, combined with the completely open-air installation on my stick, is probably why I didn't have trouble with mine. On the 1.60fx, the needle appears to just be attached with that bolt on bracket which won't conduct too much heat to the valve. Anyway, it shouldn't be too hard to debug this problem, since overheating/leaning/quitting ain't rocket science to figure out. It can only be one of two things: not enough fuel or not enough air-cooling (or both). Has anyone tried sawing the needle off the backplate and mounting it somewhere away from heat? I think I heard of someone doing that in another thread and that fixed it. LS
