Futaba 6EX 2.4ghz radio possible glitch    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Futaba 6EX 2.4ghz radio possible glitch
Page: [1] 2   next >   >>
Login
Futaba 6EX 2.4ghz radio possible glitch - 5/2/2010 5:23 PM
michaelwcollins
Score: 100
Last Login: 9/22/2011
Status: offline
I have been flying my PA Addiction with Futaba's 6ex radio and I have started to notice some problems with my servos. First it was my rudder servo that wouldn't respond properly but that seemed to go away, and it happened while my brother was turning on his Spektrum DX6i radio so I stupidly dismissed it.
Yesterday I was flying, alone, and I lost up elevator response while trying to dodge some powerlines and managed to hit the planet instead. These are brand new Hitec HS65mg's and I don't think they are the issue.
I have the servo wire extensions securely placed and tied together and the servo wires were not coming loose from the rx. I noticed on the ground that I had full down response but momentarily had no up on the elevator then it "magically" cleared up. Too bad this was after my wheel pants were shoved through my wings and the prop was in two pieces.
Anybody have something similiar happen or have any advise on the issue?
Hide Signatures
       Post #: 1
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/2/2010 5:35 PM
Steve Percifield
Score: 108
Last Login: 5/25/2013
Status: offline
Try rebinding and make sure your battery is up to snuff.
_____________________________
Sir Percy
Hoosier Dawn Patrol
Hide Signatures
(in reply to michaelwcollins)
       Post #: 2
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/2/2010 7:19 PM
michaelwcollins
Score: 100
Status: offline
I'll try rebinding. The battery was freshly charged and only has about 9 or 10 flights on it.
The problem is intermittent, so the next time I connect it doesn't happen and it might start up while I'm in the air as it did previously.
No risk no reward I guess.
Hide Signatures
(in reply to Steve Percifield)
       Post #: 3
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/2/2010 8:12 PM
Steve Percifield
Score: 108
Status: offline
what model receiver are you using? While everything is on and operating. Try wiggling all the connections. This seems like an intermittant power problem to me. Make sure the receiver always has the green light on while doing all the wire shaking and wiggling.
Sir Percy
Hoosier Dawn Patrol
Hide Signatures
       Post #: 4
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/3/2010 12:04 AM
michaelwcollins
Score: 100
Status: offline
I'll try anything, but each time it only occured with one servo and in one particular direction.
The first time was the rudder, full right with partial left.
Next was the elevator, full down with partial up.
Maybe I should only fly inverted and in left side down knife edge.
Hide Signatures
       Post #: 5
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/3/2010 12:19 AM
Steve Percifield
Score: 108
Status: offline
Any chance you have another receiver to try? Or borrow one to try. Try testing and eliminating parts 1 at a time and see what happens. You may have a cold connection on the receiver power srtip that is allowing intermittant voltage spikes to the servos. That's why it would nice to know if the receiver is staying bound when this occurs. Also try eliminating the switch and see what happens
Whoops, Are you flying electric??? Then change your BEC .. If staying bound, the problem is the voltsge running to the servos, so the SCR, if using one, may be the problem.
just thinking out loud.
steve
Sir Percy
Hoosier Dawn Patrol
Hide Signatures
       Post #: 6
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/3/2010 7:25 PM
michaelwcollins
Score: 100
Status: offline
I rebound the receiver and experienced the same problem. I then switched out servos and the problem transferred to the new servo. It has to be radio or receiver related. FYI, I'm using an R606FS receiver.
Hide Signatures
       Post #: 7
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/3/2010 9:35 PM
dant-RCU
Score: 100
Status: offline
It could also be the switch. I had a switch problem and discovered it when I was having intermittent problems
and the radio did not go into failsafe which indicated a loss of power.
You didn't say whether you went into failsafe or not - did you??
Dan
Dan Taylor
American Turf Flyers, Inc.
Hide Signatures
       Post #: 8
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/3/2010 10:39 PM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
Try using a different brand or model servo
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
(in reply to dant-RCU)
       Post #: 9
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/3/2010 11:09 PM
jester_s1
Score: 233
Last Login: 5/24/2013
Status: offline
You've eliminated servos, so that's not it. Your problem is not system wide, so that should eliminate a battery, wiring or switch issue (although I would check those as electrical systems are by far the most common problem causers). That only leaves your radio system. If you have another reciever, give it an extended testing. If that goes well, you've found your problem. If not, then you either have 2 bad recievers or a bad transmitter or transmitter battery.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to MinnFlyer)
       Post #: 10
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/3/2010 11:29 PM
Bax
Score: 169
Status: offline
How does the system perform when you use Futaba servos? Please be aware that all non-Futaba servos don't "play well" with Futaba equipment.
Also, you mentioned that the battery pack had 9 or 10 flights on it. If it was 9 or 10 flights since you charged it, is it possible that you were trying to fly with a depleted battery pack? If it was 9 or 10 flights total on the pack, how many flights since full charge did you have on the battery pack when the system started to act up?
A battery pack that's going low can cause a bunch of different problems. You get the intermittency because you don't have the same conditions all the time. Sometimes, your flying puts quite a load on the servos, which results in a lot of current flow that causes the battery voltage to drop quite a bit. That will give you problems because when the load is removed, the current goes 'way down, and the battery voltage comes up again. Usually, though, the lowered voltage will cause complete lockouts, and not "funny" servo movements.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to jester_s1)
       Post #: 11
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/8/2010 9:37 AM
bret191
Score: 100
Last Login: 5/15/2013
Status: offline
I want to put my 2 cents in, I have the same radio and have had to send it in for repair 3 times in two years. The last time Futaba even sent me a new EX and this radio has the same problem, ch3 eratic, channels reversing all by there self, touchy op. ect. My Ex's have been very unrelieable to say the least! Don't take any chances, send it in to Futaba for a check befor you loose a plane or two like me.
quote:
ORIGINAL: michaelwcollins
I have the servo wire extensions securely placed and tied together and the servo wires were not coming loose from the rx. I noticed on the ground that I had full down response but momentarily had no up on the elevator then it ''magically'' cleared up. Too bad this was after my wheel pants were shoved through my wings and the prop was in two pieces.
Hide Signatures
       Post #: 12
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/9/2010 1:51 AM
dash008
Score: 115
Last Login: 5/18/2013
Status: offline
I have the 72 mhz version of the same radio (6EXP). I had the same problem, channel 3 (throttle) had a mind of it's own. It would jump around. I noticed it was doing the same thing on all my planes, some with different brand servos, so it had to be a problem with the transmitter. I also noticed I could sometimes get a couple flights in before it started acting up so I bought a new battery for it and so far the problem has gone away.
Ultra Sport Brotherhood #4
Hide Signatures
(in reply to bret191)
       Post #: 13
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/10/2010 9:31 PM
michaelwcollins
Score: 100
Status: offline
The battery had a fresh charge and if it's a matter of Futaba radios not working with non-Futaba servos then I want no part of it. My next radio will be JR of Spektrum.
Hide Signatures
(in reply to dash008)
       Post #: 14
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/10/2010 9:53 PM
MrCoffeeMax
Score: 105
Last Login: 2/16/2012
Status: offline
That's a decision you'll live to regret!
Hide Signatures
       Post #: 15
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/10/2010 9:55 PM
MinnFlyer
Score: 390
Status: offline
Hide Signatures
(in reply to MrCoffeeMax)
       Post #: 16
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/10/2010 10:38 PM
ceecrb1
Score: 120
Last Login: 5/20/2013
Status: offline
the 6ex does have cheaper pots on the control sticks.. Just last month I had to replace my throttle pot for just this reason..
as you move the stick from one extreme to the other, it will flutter..
the ultimate test for this is checking on another modle.... ask another club member with a futaba rigged plane if you can bind to theirs and test... this will rull out EVERY part at the RX end.
after investigating i found out that 6ex has cheaper parts that the 7c and up do no have..... MANY people have experienced problems with the throttle stick.. google it..
I managed to get a replacement and install it with zero effort.. but i´m an electrical engineer.... if you are half capable of souldering PCB's its no hardship to swap one and there is no calibrating process as the physical design of the tx forces the pots to a specific place.
Goldwing MX2 & DLE 30 + Harris smoke pump
Seagull Super Tucano 91 & DLE 20
Hide Signatures
       Post #: 17
RE: Futaba 6EX 2.4ghz radio possible glitch - 5/15/2010 6:16 PM
michaelwcollins
Score: 100
Status: offline
I have several friends and family members who fly JR and Spektrum and have had no problems. I used to fly JR but I got this radio for free and regrettfully got rid of my JR radio that I never had problems with. I doubt I'll live to regret going back.
Hide Signatures
       Post #: 18
RE: Futaba 6EX 2.4ghz radio possible glitch - 8/22/2010 1:58 AM
Soko42vv
Score: 100
Last Login: 8/19/2012
Status: offline
RB1,
Where did you purchase the throttle pots for your 6ex? I need to do the same. Any part numbers you can provide would be appreciated otherwise I will just tear into the belly of the beast. My first stop would be digikey.
Tks
Hide Signatures
(in reply to ceecrb1)
       Post #: 19
RE: Futaba 6EX 2.4ghz radio possible glitch - 8/22/2010 2:27 AM
Penuts
Score: 100
Last Login: 7/29/2011
Status: offline
If you go to the thread under Questions and Answers look for the thread Airtronics Radio (penuts) and about the forth down i made another statement why im looking for another radio,it gives you the details why i want to change from Futaba to ??? you just might find it interesting.No more Futaba for me. That was the last straw.
Dick
Hide Signatures
(in reply to Soko42vv)
       Post #: 20
RE: Futaba 6EX 2.4ghz radio possible glitch - 9/2/2010 10:13 PM
marshr
Score: 100
Last Login: 7/16/2012
Status: offline
On my Futaba 6EX 2.4g transmitter, about three years old, the throttle began to jump at full throttle a month ago. It would behave normally if I applied some slight upward pressure against the stick, but would begin to jump about a click below full throttle if I didn't. It did the same thing on three other airplanes and none of the airplanes did this when I rebound them to my 7C 2.4 radio. I wrote to Futaba service and to Radio South and asked if these had been a frequent problem. Futaba said no, and Radio South said yes. Radio South made the repair and all is fine on the throttle now, but a month after that repair, the aileron stick is doing the same thing at full right. The pots in this radio are considerably cheaper looking than I see in my 7C, T6XAS, or even the 6EX-pcm. I am in the process of obtaining three replacement pots so I can replace the one that is now bad and have two more on hand when the other two go bad, which I expect to happen. This radio should be recalled IMHO. If anyone has had any luck with Hobbico Service in that regard, I'd like to hear about it. Meanwhile, if you have any simliar problems as this, Radio South has been good and I only wish I had had them replace all four pots the first time instead of just the throttle pot. Not wanting to throw more money into a three year old, low-end radio, I will replace the pots myself and see if I can keep it running a little longer. This model sure isn't made like my two T6XAS's that are 8 years old, thousands of flights, and going strong.....
Hide Signatures
(in reply to Penuts)
       Post #: 21
RE: Futaba 6EX 2.4ghz radio possible glitch - 9/3/2010 3:22 AM
red head
Score: 135
Status: offline
Just a thought: Are you using the " CORRECT " servo arms ???? Their not all the same !! ENJOY !!! RED
Hide Signatures
(in reply to marshr)
       Post #: 22
RE: Futaba 6EX 2.4ghz radio possible glitch - 12/1/2010 4:33 PM
longbaot
Score: 100
Last Login: 5/4/2013
Status: offline
I just searched this site because my 6ex has the same problem as described above. Several in my club bought Futaba 6EX at the same time. After very little use (less then one hour) the pots have failed. I am still using Futaba radios that are 15 years old and have never had a problem. The new 6EX not so much. I am not fixing mine it is going in the junk.
Hide Signatures
(in reply to red head)
       Post #: 23
RE: Futaba 6EX 2.4ghz radio possible glitch - 12/1/2010 4:50 PM
marshr
Score: 100
Status: offline
Thanks for suggestion on servo arms. Yes, nothing changed there - same stock Futaba arms on the Futaba servos, but I've seen where others have forced JR (or was it HiTec ? anyway not the problem here) arms on Futaba's or other way around, with resultant slippage. No, the issue is the potentiometers, as confirmed by Tony at Radio South and by the fact that when I changed the second one myself, the issue went away. It 'probably' isn't a 'plane crasher' since the jumping only occurs at the extreme end of the stick movement. At the center-range, everything works normally, but when you get to the full throw of the stick, it will jump or should I say, twitch some.
Hide Signatures
(in reply to longbaot)
       Post #: 24
RE: Futaba 6EX 2.4ghz radio possible glitch - 12/1/2010 5:47 PM
orbsah
Score: 100
Last Login: 5/23/2013
Status: offline
Anyone know if this pot issue relates only to the 6EX on 2.4GHz and not the 6EX on 72MHz? I have a 6EX on 72MHz and have not noticed this (although now I'll be on the lookout).
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
