carbon wingnut
Hi All, We at Fromeco Scale Avionics are currently working on a new charging system. We are currently in the initial testing Phases of our design with alpha and beta tests to follow very soon. We are hoping to release this new charger by the end of summer. Our chargers basic specs are: - 3 Port standard, (expandable to 4 and maybe 5 ports, for additional cost). - Lithium Ion, NiCad, NiMH capable on all ports. - Capable of charging different chemistries at the same time. (i.e. Lithium on port 1, NiCad on port 2, NiMH on port 3). - 1.7 amp charge rate on all three ports, (Power supply dependent) - Peak detect for NiCad and NiMH, with soft start for highly discharged packs, and post-peak cycle trickle charge. - Lithium Ion charging will also have soft start for those who go below the VDC Red line, and new packs. LI charging will rely on the standard methods to monitor charge duration, (i.e. current/VDC/*timer (*timer in as safety precaution)). - AC/DC input power capable. -Will be made in America and serviced here as well. We currently do not have plans for a discharge function to be built into the box. However, we may come out with a secondary unit that will have the discharge features. This way, every channel will not need the support electronics for discharging. We have tried to streamline the charger as much as possible so that it will be affordable to the ordinary modeler. Besides being highly functional, cost is our driving factor. When we release this unit, our target price is going to be $160.00 and it looks like this will happen for the 3 channel unit. The power supply will be sold separately. We will sell the power supply for $50.00, this however is not firm as we are still looking for cheaper power supply and/or cheaper wholesale distributor of the power supply that we need. My partner and I have looked into including a discharger, liquid crystal displays, programmability over and above what we have already. It just adds too much to the price and ends up stinging the modeler in the end. We just wanted to post this to all of you out here in cyberland and ask your opinions. We will probably have a “name that new charger” contest, where the winner gets a new free charger. Once we get out of the Alpha and Beta testing mode we will be posting pictures of the final unit. We will also want to take about 20 to 25 preorders before we start producing it. Thank you for your time Kurt Cook Fromeco Scale Avionics LLC [url]www.fromeco.org[/url] [url]www.wingut@sandynet.org[/url]
