motor mount    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> motor mount
Page: [1]
Login
motor mount - 5/11/2010 2:50 AM
71dartswinger
Score: 100
Last Login: 5/22/2013
Status: offline
this is the second motor mount  that has broken on Logans airboat
this is 1/8" aluminum angle the first was exactly the same break.
built new ones out of 1/4" plywood
the engine is only a Fox .25 bbs
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: motor mount - 5/11/2010 4:04 AM
RS 38-40
Score: 100
Last Login: 5/23/2013
Status: offline
Looks like a vibration problem . Maybe the prop is out of balance .
Hide Signatures
(in reply to 71dartswinger)
       Post #: 2
RE: motor mount - 5/11/2010 4:45 AM
71dartswinger
Score: 100
Status: offline
its only the one side that breaks (from front of boat its right side)
the motor has been changed from this picture from OS.20 to Fox .25
had no problems with .20 other than fuel/oil leaking out of front of crank and around strap on exhaust
checked prop balance its fine but i think plastic spinner is out of balance has different size screws
going to pickup metal nut spinner
Click for fullsize
< Message edited by 71dartswinger -- 5/12/2010 5:24 AM >
Hide Signatures
(in reply to RS 38-40)
       Post #: 3
RE: motor mount - 5/13/2010 5:15 PM
DJLaPalme
Score: 110
Status: offline
If you did'nt use a break to bend the aluminum chances are the bend area is full of small cracks that will cause the piece to break with the vibration from the engine. To bend aluminum without the weak areas you have to use the right radius for the thickness of the metal. Someone on here will be able to help with the problem. Dennis
_____________________________
Affiliated with Mudmasher Airboats.
Hide Signatures
       Post #: 4
RE: motor mount - 5/13/2010 11:56 PM
71dartswinger
Score: 100
Status: offline
its 1/8"x1"x1"  angle  i bought at lowes
Hide Signatures
(in reply to DJLaPalme)
       Post #: 5
RE: motor mount - 5/14/2010 3:46 AM
RS 38-40
Score: 100
Status: offline
One thing you might want to look at when you make another mount is that the holes are not oversize and that they are lined up with the motor holes . It also might help to add a doubler under the motor to give it a little more meat . The angle you are using is not usually very hard and any movement will elongate the holes and put more stress on the mount . A prop doesn't have to be out of balance much to cause problems .
Hide Signatures
       Post #: 6
RE: motor mount - 5/14/2010 5:15 AM
71dartswinger
Score: 100
Status: offline
borrowed a prop balancer from a guy at work and prop is out of balance
got where it will stay horizontal  but put vertical it is out of balance.The center hole is not centered.
bought new prop and spinner today and balanced it .
the holes in aluminum were the same size as the ones on motor
and the bolts were still tight . the break line follows the edge of the motor mounting flange
like i said this is the second one broken. mount now is 1/4" plywood
< Message edited by 71dartswinger -- 5/15/2010 4:54 AM >
Hide Signatures
       Post #: 7
RE: motor mount - 5/17/2010 7:18 AM
Mr Cajun Gator
Score: 100
Last Login: 9/25/2012
Status: offline
place a thin strip of wood or even better, rubber between the engine and the aluminum
Catch a Gator by the Tail and hang on for the Ride!
Cajun Gator Airboats, M.AB.A
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
