YS91FZ problems
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> YS91FZ problems
Page: [1]
Login
YS91FZ problems - 7/19/2003 7:32:03 PM
John Hawkins
Status: offline
I have a problem with my YS91FZ. It will suddenly go to idle in flight. Sometimes it will come back after a few seconds by returning the stick to idle and advancing it. At others times it will load and stumble when the throttle is advanced. In the session before the most recent one, fuel was pouring out of it when I landed indicating a leak past the plunger. I took the regulator apart and removed the spring and plunger and flushed it with fuel, although there no evidence of dirt, and reassembled it. The regulator was set flush and the main needle set initially open 1 1/2 turns. The engine was run and the main needle set and a minor adjustment made to the regulator. With 15% Omega and a 14x8 APC rpm was initially ~9700 and then settled back to ~9300. Idle, transition and top end were fine. At the field I had one normal flight and in the typical pattern of the past year, the engine repeated its previous behaviour in the second flight. The engine is about two years old but I haven't been able to get much time on it although I have lots of practice landing without power. (One significant crash too.) Before the current problems developed the engine was always vague on the main needle.
The diaphragm, plunger and spring have been replaced. The airbox was warped and is now sealed with high temp silicone. The check valve functioned normally but was replaced anyway. The system holds pressure for prolonged periods. Valve clearances has been set to specs. A new OS#F plug was installed. A fuel filter is used and is clean. The fuel runs fine in a 91AC. The carb was disassembled in the recent past and I found a piece of debris that I thought might have been moving around in the groove and obstructing fuel flow. Removing it made no difference.
After the engine went wonky on the second flight yesterday the main needle response was irregular and it would momentarily drop rpm in ground running at full throttle. At one point fuel was dripping from it. The regulator screw was run in until it bottomed and backed out to flush and the main needle set to 1 1/4 open. This stopped the fuel leak and once again the engine was fine - until a few minutes into the next flight and we were back to the same behaviour that has plagued this thing for the last year. Perhaps it had just cooled off and healed itself temporarily.
To eliminate question about mechanical operation of the throttle the servo and receiver were both swapped out. The transmitter runs several other models. The throttle arm is not slipping. As you might gather, this engine has more than sucked the joy out of flying.
Can you offer any help?
[URL=http://members.accesswave.ca/~parklane/Home.html]http://members.accesswave.ca/~parklane/Home.html[/URL]
       Post #: 1
YS91FZ problems - 7/19/2003 7:48:38 PM
Dave Shadel
Status: offline
From the stated age of the engine, it is possible that the gas port mod has not been done to it. It certainly has the symptoms of an engine that needs it.
It should be looked at. Please send it in as soon as possible.
YS Service
1295 Industrial Court
Gardnerville,
Nv 89410
Phone 775 782 4562
(in reply to John Hawkins)
       Post #: 2
YS91FZ problems - 7/19/2003 8:18:24 PM
John Hawkins
Status: offline
Dave, OK, will do. It is past anything I can do to solve the problem.
       Post #: 3
YS91FZ problems - 7/24/2003 2:00:45 AM
John Hawkins
Status: offline
Dave,
The engine is on the way to you for service. Can you explain what the gas port mod is?
John
       Post #: 4
YS91FZ problems - 7/24/2003 2:02:12 AM
Dave Shadel
Status: offline
A series of holes drilled through the top of the piston behind the ring for better ring seal.
       Post #: 5
YS91FZ problems - 7/24/2003 2:09:38 AM
John Hawkins
Status: offline
As I thought but wasn't certain. Is the ring tension purposely low?
       Post #: 6
YS91FZ problems - 7/24/2003 2:19:05 AM
John Hawkins
Status: offline
       Post #: 7
YS91FZ problems - 7/24/2003 2:19:26 AM
Dave Shadel
Status: offline
In an engine that didn't depend on a regulator which is operated by crankcase pressure, it wouldn't matter, but ring leakage drives the regulator nuts! That is why I decide to start using it and the YS factory has incorporated it into all new production.
       Post #: 8
YS91FZ problems - 7/24/2003 2:29:55 AM
John Hawkins
Status: offline
I can see where the case pressure would be all over the place and make for all sorts of trouble. Incidentally, is it possible for the case to hold enough pressure after shut down to unseat the plunger? Do the ports have any tendency to carbon up when using Omega? Sounds like a good application for a Dykes ring.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU5
