RE: Yellow Aircraft F-16C EDF Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: Yellow Aircraft F-16C EDF Build Page: <<   < prev  2 3 4 5 6 7 8 [9] 10 11   next >   >>
Login
RE: Yellow Aircraft F-16C EDF Build - 6/21/2012 5:37 AM
Wisdumb
Score: 100
Last Login: 5/10/2013
Status: offline
Installing the ESC, going over placement, a little bit of heat shrink, and some capacitors!  Action packed indeed!
Hide Signatures
(in reply to Wisdumb)
       Post #: 201
RE: Yellow Aircraft F-16C EDF Build - 6/29/2012 2:04 AM
Wisdumb
Score: 100
Status: offline
EPISODE #69
Exciting stuff in this one!  Check it out!
Hide Signatures
       Post #: 202
RE: Yellow Aircraft F-16C EDF Build - 7/1/2012 6:19 AM
Wisdumb
Score: 100
Status: offline
Check out the latest installment.  Some VERY exciting stuff in this one.  Let's just say that I should be able to do some taxi tests tomorrow weather permitting. :-)
Hide Signatures
       Post #: 203
RE: Yellow Aircraft F-16C EDF Build - 7/2/2012 5:22 AM
Wisdumb
Score: 100
Status: offline
Ok, I got a chance to taxi today!  Check out the video to see.
I do have a small issue with the wheels not tracking.  The grub screws to keep the wheels pointed correctly don't seem to keep them in place.  I think I'll either need to get inside and file a flat spot, or maybe make a hole and tap it?… I'll figure it out.  Hopefully nothing too in depth.
Hide Signatures
       Post #: 204
RE: Yellow Aircraft F-16C EDF Build - 7/2/2012 2:45 PM
juanjulian
Score: 100
Last Login: 5/21/2013
Status: offline
 Very goog editing.
Think a flat spot should domthe trick.
Fallowing.
Cheers
Juan
Hide Signatures
       Post #: 205
RE: Yellow Aircraft F-16C EDF Build - 7/4/2012 8:54 AM
Wisdumb
Score: 100
Status: offline
Late night episode!  I fixed the gear problems (Tracking and brakes.)  Check it out in the video:
Hide Signatures
(in reply to juanjulian)
       Post #: 206
RE: Yellow Aircraft F-16C EDF Build - 7/8/2012 4:41 AM
Wisdumb
Score: 100
Status: offline
I tried again the flying field today and the brakes work fine. I think I like the solid braking better than the "anti-lock."
Dave at the flying field helped me get my radio programmed so that the brakes are activated when I put in about 40%-50% down elevator. I just couldn't get it to activate. It turned out all that was to crank up the sub trim some.
While testing the brakes we noticed it started listing to one side. I thought that was strange. When we brought it back to the bench we noticed one of the bolts that attaches the gear to the bulkhead was gone! Doh! I checked the other bolt and it was loose as well. I was planning on going through and applying loctite to everything later, but maybe sooner than later is better
We found the bolt on the runway and put it back in.
One last "that sorta sucks" moment was when I wanted to test the non anti-lock braking. The balsa block I have holding the pushrod tube in place for the nose steering busted loose from the fuselage. I'll make another with some ply and hysol in place.
It's hot and miserable so I'm not sure how much progress I'll make this weekend.
Hide Signatures
       Post #: 207
RE: Yellow Aircraft F-16C EDF Build - 7/17/2012 3:23 PM
Wisdumb
Score: 100
Status: offline
Here's some canopy building action!
Hide Signatures
       Post #: 208
RE: Yellow Aircraft F-16C EDF Build - 7/18/2012 2:36 PM
Wisdumb
Score: 100
Status: offline
Canopy Buildin' Action #2 (It moves!)
Hide Signatures
       Post #: 209
RE: Yellow Aircraft F-16C EDF Build - 9/7/2012 12:43 AM
Wisdumb
Score: 100
Status: offline
I'm back!
Hide Signatures
       Post #: 210
RE: Yellow Aircraft F-16C EDF Build - 9/9/2012 9:43 PM
Wisdumb
Score: 100
Status: offline
Here's the completed aileron torque rod assemblies and some aileron movie' action.
Note: Be sure when you install the brass tubes on the inside that they do not protrude past the wooden servo tray… I had one that had about 1/8" protrusion and it made it so that I could not put on the aileron because none of the hinges would line up.  I had to grind it down to make it work.
Hide Signatures
       Post #: 211
RE: Yellow Aircraft F-16C EDF Build - 9/23/2012 11:49 PM
Wisdumb
Score: 100
Status: offline
Quick video update.  Some stuff for sale, skip to 3:25 if you don't want to see that.
Hide Signatures
       Post #: 212
RE: Yellow Aircraft F-16C EDF Build - 9/30/2012 9:18 AM
Wisdumb
Score: 100
Status: offline
Working on finalizing the ailerons.  I had to add caps to the ends to cover the hole I had to make to get to the torque rod "sleeve" that fell inside.  I only need to glass the one aileron since I did the other a looooong time ago.
Hide Signatures
       Post #: 213
RE: Yellow Aircraft F-16C EDF Build - 10/1/2012 3:41 AM
Wisdumb
Score: 100
Status: offline
Continuing finishing the ailerons.  Here is a glassing video for those of you interested.  I didn't speed anything up so those interested can see the process from start to finish and the technique.
Hide Signatures
       Post #: 214
RE: Yellow Aircraft F-16C EDF Build - 10/3/2012 8:56 AM
YellowAircraft
Score: 181
Last Login: 5/22/2013
Status: online
quote:
ORIGINAL: Wisdumb
Yeah,
You're supposed to adjust the wheels to your desired toe-in and grind a flat spot on the top of the wire to set it. Glad you did that.
_____________________________
Yellow Aircraft, JetCat Engines and Turn Key Jets
yellowaircraftplanesdotcom
Hide Signatures
       Post #: 215
RE: Yellow Aircraft F-16C EDF Build - 10/4/2012 7:24 AM
Wisdumb
Score: 100
Status: offline
Yeah, I finally figured it out... someone else also posted that the grub screw was at the top, not the bottom... doh!  It was no wonder I couldn't get them to stay put!
Hide Signatures
(in reply to YellowAircraft)
       Post #: 216
RE: Yellow Aircraft F-16C EDF Build - 10/4/2012 7:26 AM
Wisdumb
Score: 100
Status: offline
Sorry guys, I couldn't help it… I had to try out those dry transfers from aeroloft… and I love those things! They were a little tough around the curved surface and I had to work out some wrinkles, but man does it look good! I'll make a video next time I swear! (The wings are pretty close to being ready to paint, so it won't be long&hellip
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 217
RE: Yellow Aircraft F-16C EDF Build - 10/5/2012 4:26 PM
Ro
Score: 100
Status: online
Looking forward to getting one of these from Yellow aircraft / S. Evans!
Hide Signatures
(in reply to MrN79)
       Post #: 218
RE: Yellow Aircraft F-16C EDF Build - 10/5/2012 8:38 PM
JustFlyIt
Score: 100
Status: offline
 I am so ready to see this bird fly.
Hide Signatures
(in reply to Ro)
       Post #: 219
RE: Yellow Aircraft F-16C EDF Build - 10/6/2012 6:21 AM
Wisdumb
Score: 100
Status: offline
Here's part 3 of episode #77.  This one's packed full of glass weave filling dry transfer scratching' mayhem!
Hide Signatures
(in reply to JustFlyIt)
       Post #: 220
RE: Yellow Aircraft F-16C EDF Build - 10/7/2012 5:44 AM
Wisdumb
Score: 100
Status: offline
Here's the last of the aileron finishing.  I have to say I really think the bondo spot putty and acetone brush on technique to fill the weave is the way to go.  It sands so easy and gives a good finish.  I also think it saves on weight.
Hide Signatures
       Post #: 221
RE: Yellow Aircraft F-16C EDF Build - 10/8/2012 4:15 AM
YellowAircraft
Score: 181
Status: online
Hi,
Nice finished product. Have you ever tried thinning the resin and brushing it through the cloth with a paint brush? I cut Z-poxy 60/40 with denatured alcohol (more alcohol than resin). I lay the cloth onto the part and brush the mixture straight through. It's considerably faster if you ever want to give it a try. I can get both sides of all of the wood surfaces on this F-16 glassed in about 2.5 hours on a sunny day, and one of those hours is just for drying time.
Hide Signatures
       Post #: 222
RE: Yellow Aircraft F-16C EDF Build - 10/8/2012 4:33 AM
Wisdumb
Score: 100
Status: offline
Time to start prepping the missile rails for paint. I primed them and am in the process of eliminating the seam with some bondo spot putty.
Something tells me these would look much sweeter with some missiles attached!
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 223
RE: Yellow Aircraft F-16C EDF Build - 10/8/2012 4:36 AM
Wisdumb
Score: 100
Status: offline
Can anyone provide a link to some good walkarounds or decal placement for all the "no steps" and "dangers" and whatnot?  If anyone has some pics of the Fort Smith Alabama ANG Razorbacks that would be awesome.  It is proving to be much more difficult than I thought it would.
Hide Signatures
       Post #: 224
RE: Yellow Aircraft F-16C EDF Build - 10/8/2012 4:41 AM
Wisdumb
Score: 100
Status: offline
quote:
ORIGINAL: YellowAircraft
Hi,
I have tried that, it works good.  I was too lazy to go down to the garage to get the denatured alcohol .  Thanks for the suggestion.  I'll do that for sure when I do my next one on all surfaces, it does go much faster.
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.156RCU1
