RE: Yellow Aircraft F-16C EDF Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: Yellow Aircraft F-16C EDF Build
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Yellow Aircraft F-16C EDF Build - 9/17/2010 2:11 AM
Wisdumb
Score: 100
Last Login: 5/10/2013
Status: offline
Ok, here's the final result.  Overall it looks pretty good.  Check it out:
Hide Signatures
(in reply to Wisdumb)
       Post #: 76
RE: Yellow Aircraft F-16C EDF Build - 9/21/2010 4:01 AM
Wisdumb
Score: 100
Status: offline
Here we go... the nose wheel servo mounting bracket in all its glory! Ok, tried to make it sound more exciting than it is.
Hide Signatures
       Post #: 77
RE: Yellow Aircraft F-16C EDF Build - 9/22/2010 3:28 AM
Wicked98
Score: 100
Last Login: 10/27/2011
Status: offline
Anything new?
Hide Signatures
       Post #: 78
RE: Yellow Aircraft F-16C EDF Build - 9/22/2010 4:47 AM
Wisdumb
Score: 100
Status: offline
quote:
ORIGINAL: Wicked98
Anything new?
I'm just waiting on my Stumax.  He said he should be able to send it out by Friday.  I'm not feeling well today so not much going on there.  I did play with the airbrush yesterday and painted one side of the vertical stab in neutral grey.  I also made the decals on the computer and sized them correctly, but the decal paper I bought won't work on my inkjet, the ink just beads off.  I need to go someplace with laser printers or use a copy machine.  I've also ordered new air hose from BVM as I've been advised not to use the stuff that came with the gear as it is too flexible and may be prone to leaks.
Hide Signatures
(in reply to Wicked98)
       Post #: 79
RE: Yellow Aircraft F-16C EDF Build - 9/27/2010 9:58 AM
YellowAircraft
Score: 181
Last Login: 5/21/2013
Status: offline
Hi,
The black super-flexible stuff for the brakes can be problematic if used on the gear, but the other colors (except that translucent blue) of air tubing are just fine. If they develop leaks, it will be the first I've heard of it.
Very nice build, btw.
_____________________________
Yellow Aircraft, JetCat Engines and Turn Key Jets
yellowaircraftplanesdotcom
Hide Signatures
       Post #: 80
RE: Yellow Aircraft F-16C EDF Build - 9/29/2010 8:41 AM
Wisdumb
Score: 100
Status: offline
quote:
ORIGINAL: YellowAircraft
Hi,
Thanks!  I'm hoping I can use all black (at least where visible) so it will be more scale, so hopefully the BVM stuff will fit the bill.
Hide Signatures
(in reply to YellowAircraft)
       Post #: 81
RE: Yellow Aircraft F-16C EDF Build - 9/29/2010 8:42 AM
Wisdumb
Score: 100
Status: offline
Ok gang I'm back on it.  Here's a breakdown of where we are, and the little that I've done since the last video:
Hide Signatures
       Post #: 82
RE: Yellow Aircraft F-16C EDF Build - 9/30/2010 9:12 AM
Wisdumb
Score: 100
Status: offline
Ok, here's the tutorial on how to make the missile rail using invertmast's method.  I tried to squeeze it all into one video, but it just wouldn't fit.  I'll make another video of how to prepare the wingtip to attach the rail.
Hide Signatures
       Post #: 83
RE: Yellow Aircraft F-16C EDF Build - 9/30/2010 10:47 AM
Wisdumb
Score: 100
Status: offline
Here's the last bit that couldn't fit in the first video of how to mount the missile rail.
Hide Signatures
       Post #: 84
RE: Yellow Aircraft F-16C EDF Build - 10/4/2010 1:47 AM
Wisdumb
Score: 100
Status: offline
 Ok, I decided to smooth out the interior of the gear doors for a better finish.  I painted them and they are ready to install.  Here's how I did it:
< Message edited by Wisdumb -- 10/4/2010 2:27 AM >
Hide Signatures
       Post #: 85
RE: Yellow Aircraft F-16C EDF Build - 10/5/2010 10:42 AM
Wisdumb
Score: 100
Status: offline
Hey Gang!
  Ok, here's a special "episode".  I got a little surprise in the mail today... hmmm... what in the world could it be?  Check it out below to find out!
Hide Signatures
       Post #: 86
RE: Yellow Aircraft F-16C EDF Build - 10/8/2010 12:01 AM
4stripes
Score: 100
Last Login: 10/1/2012
Status: offline
I have a Yellow Aircraft NEW plastic canopy and fiberglass frame for sale. Perfect condition. Reason for selling, bought to fit another make F-16 and it's too large.
Still in original box.
Eric
ericklepsch@bell.net
Hide Signatures
       Post #: 87
RE: Yellow Aircraft F-16C EDF Build - 10/8/2010 7:34 AM
Wisdumb
Score: 100
Status: offline
Here's another video how I attached the "new" main gear doors after they were painted.
Hide Signatures
(in reply to 4stripes)
       Post #: 88
RE: Yellow Aircraft F-16C EDF Build - 10/11/2010 1:42 AM
Wisdumb
Score: 100
Status: offline
Well, here's a little servo tray action.  I didn't mention it in the video, but you do have to glue in a small piece of included brass tubing where the torque rod goes through the plywood.  Be sure to do that.
I had to open the hole a bit on the ply piece so that the brass would conform to the same angle as the torque rod.  Other than that it was pretty much smooth sailing on this assembly.
Hide Signatures
       Post #: 89
RE: Yellow Aircraft F-16C EDF Build - 10/16/2010 11:45 PM
Wisdumb
Score: 100
Status: offline
Here's a quick video update. We've got a few goals this weekend. What could they be? Check out the video to find out.
Hide Signatures
       Post #: 90
RE: Yellow Aircraft F-16C EDF Build - 10/17/2010 9:10 AM
Wisdumb
Score: 100
Status: offline
Here's the progress thus far today. I forgot that I had to finish the other servo tray, so I did. I still have not achieved goal #1 of mounting the nose gear door
Hide Signatures
       Post #: 91
RE: Yellow Aircraft F-16C EDF Build - 10/20/2010 8:50 AM
Wisdumb
Score: 100
Status: offline
Here's a quick update:
Hide Signatures
       Post #: 92
RE: Yellow Aircraft F-16C EDF Build - 10/23/2010 4:55 AM
LoneRanger
Score: 100
Last Login: 4/26/2013
Status: offline
i have gone through your videos up to date and i can not for the life of me see where you mentioned what kind of "primer" you are using! I know its in a can, and it look like it goes on pretty good and sands easy.
help me out with a manufacturer and part number.
L.R.
Hey Ya'll, watch this!!!!!
Hide Signatures
(in reply to MrN79)
       Post #: 93
RE: Yellow Aircraft F-16C EDF Build - 10/24/2010 4:17 AM
Wisdumb
Score: 100
Status: offline
Unless you have a Fred Meyer store in your area, I don't think you'll be able to find it.  It is a store brand called "HD designs" grey primer.  I'm in California now so I don't have a UPC# or any other useful information and there aren't any Fred Meyer stores here.
UPDATE: Guaranteed you don't have that store in your location, they are a west coast and Alaska retailer owned by Kroger.
Hide Signatures
(in reply to LoneRanger)
       Post #: 94
RE: Yellow Aircraft F-16C EDF Build - 10/26/2010 8:24 AM
Wisdumb
Score: 100
Status: offline
Just got a few things done.  Check 'em out in the video (in 1080p).  Mainly wanted to see how the new resolution works on youtube.
Hide Signatures
       Post #: 95
RE: Yellow Aircraft F-16C EDF Build - 10/27/2010 9:25 AM
Wisdumb
Score: 100
Status: offline
Here's the next video in the saga known as "Building the Yellow Aircraft F-16C". This time we start prepping for the air system installation. Check it out:
Hide Signatures
       Post #: 96
RE: Yellow Aircraft F-16C EDF Build - 11/3/2010 10:13 AM
Wisdumb
Score: 100
Status: offline
Here's a quickie:
Hide Signatures
       Post #: 97
RE: Yellow Aircraft F-16C EDF Build - 11/7/2010 3:09 AM
Wisdumb
Score: 100
Status: offline
Well, here's a little pilot adjusting action, and a little on the cockpit. I want everything to fit well in there, so I'm taking my time to do it right. I hate taking my time, but it always seems to make me happy in the end...
Hide Signatures
       Post #: 98
RE: Yellow Aircraft F-16C EDF Build - 11/8/2010 7:50 AM
Wisdumb
Score: 100
Status: offline
Here's some more cockpit, pilot, ejections seat assembly. Starting to come along pretty well. Take a look:
Hide Signatures
       Post #: 99
RE: Yellow Aircraft F-16C EDF Build - 11/9/2010 9:52 AM
reaper31
Score: 100
Last Login: 4/11/2013
Status: offline
man, been watching this tread as i have decided to build this kit as soon as i gather the funds to buy the kit (just had to buy a new TX)
it is just beautiful. since you are working on the cockpit. i just wanted to show you guys what i have been doing for my helis, i was planning on doing this for this kit as well.
i make these using a 3D printer can't wait to get started. i might contact yellow aircraft to see i they sell just the cockpit parts so i can get started.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.563RCU1
