RE: Scoop! Too early to release information.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: Scoop! Too early to release information.
Page: <<   < prev  1 2 3 4 5 6 [7] 8   next >   >>
Login
RE: Scoop! Too early to release information. - 10/22/2012 1:40 PM
gkaraolides
Score: 100
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: bjr_93tz
Is it just me or does the horizontal stab on the ''original'' look a lot bigger than on the reproduction? The distance from the leading edge of the stab to the leading edge of the fin is very different.
The leading edge of the stab on the original is indeed closer to the leading edge of the fin, but that's because the stab root is set higher on the fuselage on the original, not because the stab is bigger.
You can see this in that side view pic. Extend the line of the fuse top deck past the stab on both models, and compare.
Also check out that three quarters rear view pic. You can see that the original has more anhedral on the stab and the stab root is set higher.
The actual size of the stab seems to me to be about the same.
I guess that keeps the centre of the side area of the stab at about the same height on original and reproduction Curare, which makes sense if they wanted to reduce stab anhedral without affecting other qualities.
They seem to have kept the wing dihedral the same, so all they have done is reduce the effect of the stab anhedral without affecting much else.
The effect of the stab anhedral is to provide a roll-in moment with top rudder in knife edge, to counter the roll-out moment from the wing anhedral, without transmitter mixers which didn't exist when the original was designed. So if the reproduction requires less roll-in from the stab in knife edge, all else being kept pretty much equal, this means the reproduction has a higher centre of gravity than the original. This might be because the original was designed and set up with a tuned pipe weighing about 200 grammes hung under the fuselage, while the reproduction is designed for electric power or i/c power without a tuned pipe.
Best regards,
G.
Hide Signatures
(in reply to bjr_93tz)
       Post #: 151
RE: Scoop! Too early to release information. - 10/22/2012 7:55 PM
stuntflyr
Score: 137
Last Login: 5/19/2013
Status: online
Thanks Bo,
Wife's home now, she can guide me through the German.
Chris...
Hide Signatures
(in reply to bem)
       Post #: 152
RE: Scoop! Too early to release information. - 10/22/2012 11:09 PM
bjr_93tz
Score: 100
Status: offline
quote:
ORIGINAL: gkaraolides
...They seem to have kept the wing dihedral the same, so all they have done is reduce the effect of the stab anhedral without affecting much else.
It wouldn't surprise me if there were a few tweaks made.
I used to fly mine with a .75 turning an 11x9 or 11x10 prop and it flew great. Fit a 12x6 and it'd grunt around a knife edge loop, but apart from pulling huge verticals it was pretty much a dog to fly so I'd expect the type of props the electric crowd like to run might require some airframe tweaking. Have just fitted a Scorpion HK-4035-400 running 10S on an 11x10 prop and happy with the initial performance (only 1 flight) but very unhappy with the vibration from the motor. I sent it back to them and have just received it back so I'll put it back in tonight and see if the vibes are still there.
Mine's 20yo now, full of oil and I'd love to build another as they're a beautiful plane to fly.
Hide Signatures
(in reply to gkaraolides)
       Post #: 153
RE: Scoop! Too early to release information. - 10/23/2012 3:30 AM
Jim_Purcha
Score: 120
Last Login: 5/18/2013
Status: offline
I always wanted to a Curare to have a unique plane at the field. Sure looks lighther than the 1/4" sides and blocks in the original plans.
Jim
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Jim_Purcha -- 10/23/2012 4:03 AM >
_____________________________
Ultra Sport Brotherhood #30
Hide Signatures
(in reply to doxilia)
       Post #: 154
RE: Scoop! Too early to release information. - 10/23/2012 5:12 AM
countilaw
Score: 219
Status: offline
Look at all those  Curare's     that   all look just alike.
Frank
It''s a hobby, not a job.
Hide Signatures
(in reply to Jim_Purcha)
       Post #: 155
RE: Scoop! Too early to release information. - 10/23/2012 5:47 AM
EscapeFlyer
Score: 120
Status: offline
quote:
ORIGINAL: countilaw
Frank
Agreed....
Brian
N Central Regional Director
Classic Pattern Association
Hide Signatures
(in reply to countilaw)
       Post #: 156
RE: Scoop! Too early to release information. - 10/23/2012 8:06 PM
hrdflite
Score: 100
Last Login: 5/17/2013
Status: offline
i want a set of wings of the bottom of the stack ,should be nice and straight.
Hide Signatures
(in reply to EscapeFlyer)
       Post #: 157
RE: Scoop! Too early to release information. - 10/24/2012 2:03 AM
dhal22
Score: 138
Status: offline
quote:
ORIGINAL: hrdflite
I was thinking the same thing.
David
Hide Signatures
(in reply to hrdflite)
       Post #: 158
RE: Scoop! Too early to release information. - 10/24/2012 5:16 AM
alcarafa
Score: 105
Status: offline
quote:
ORIGINAL: hrdflite
Thats not the best way to stock'em.... that is for sure
Rafa.
Hide Signatures
       Post #: 159
RE: Scoop! Too early to release information. - 10/24/2012 6:17 PM
countilaw
Score: 219
Status: offline
Does this company have  a   license to  build and distribute the Curare?      If not,  I don't think I would be buying one.      If you can't download music from the internet without paying the royalty,  why should this company sell  Curare's  without paying the royalty?
Any comments?
Frank
Hide Signatures
(in reply to alcarafa)
       Post #: 160
RE: Scoop! Too early to release information. - 10/24/2012 7:58 PM
doxilia
Score: 136
Status: offline
Frank,
Hanno and the developers are intimately involved. They live close to each other in Austria (if not in the same town). I believe Hanno shopped often at the developers store - hence the project.
This ARF is fully blessed by him. Check out the Facebook ( ) pages - a lot of the project background is (or at least, was) there.
I wonder if this ARF is successful if they'll follow suit with a Magic or better yet, a Mystic or Sensation!
I'd buy a Hanno approved Mystic 60 ARF... I have the perfect engine and pipe for it, the Hanno RF-P, waiting downstairs for it's wings!
David
Hide Signatures
       Post #: 161
RE: Scoop! Too early to release information. - 10/24/2012 9:15 PM
ShinySteelRobot
Score: 100
Last Login: 10/31/2012
Status: offline
If sales take off, I'd love to see someone on this side of the Atlantic remake the Tiporare or Illusion pattern plane as an ARF.
Hide Signatures
       Post #: 162
RE: Scoop! Too early to release information. - 10/25/2012 12:11 AM
bjr_93tz
Score: 100
Status: offline
quote:
ORIGINAL: countilaw
Any comments?
Frank
After looking at a photo on page 6 of this thread of some old dude named Hanno with his original Curare holding the reproduction with a grin on his face, I probably would have left that question unasked and the assumptions unmade.
However if sombody is worried that the designers from other countries that ripped off the Curare (or at least some of it's features) and sold it under different but similiar sounding names back in the 70's aren't getting their "cut" then by all means, ask the questions
Hide Signatures
       Post #: 163
RE: Scoop! Too early to release information. - 10/25/2012 2:00 AM
doxilia
Score: 136
Status: offline
quote:
ORIGINAL: ShinySteelRobot
I don't think that's going to happen. Personally, I don't think it makes any sense to produce wood fuse Tipo's as ARF's. The whole concept of the Tipo was to finesse and simplify some of the construction of the original Curare (among other things). The wood fuse Tipo is simpler to build yet hard to reproduce time and time again in wood reason for which the glass versions were made. The tuck lines in particular along with how the "canopy" portion of the Tipo is constructed are tricky to deal with as ARF's. Omitting these details tends to loose the character of the Tipo and Illusion.
Also, covering a Tipo or Illusion wood fuse is a bad proposition. I discovered this from doing it on a little one.
Having said that, glass Tipo's and Illusions exist as ARF's..., they just need a little paint before flying...
David
Hide Signatures
(in reply to ShinySteelRobot)
       Post #: 164
RE: Scoop! Too early to release information. - 10/25/2012 5:48 AM
countilaw
Score: 219
Status: offline
Hey ,  I was just asking the question.         If  Hanno is involved, then it's great.       I just get concerned that so many people have put so much into this hobby,  and then someone comes along and rips off  thier ideas or takes advantage of the original designer's  hard work.
I didn't mean to appear  petulent.
Frank
Hide Signatures
       Post #: 165
RE: Scoop! Too early to release information. - 10/25/2012 6:04 AM
doxilia
Score: 136
Status: offline
Frank,
I see where you're coming from. For these Austrian developers to go ahead with a Curare ARF and not involve Hanno would have been adding insult to injury. One thing's for sure, there have been and continue to be so many iterations and kits of the Curare in different forms that I've lost count. I wouldn't be surprised if Hanno also had.
Stopping "kitters" of the Curare is like trying to stop the DVD movie replication business - it's everywhere. The good news is that we don't want it stopped...
David
Hide Signatures
       Post #: 166
RE: Scoop! Too early to release information. - 10/26/2012 1:45 AM
hrdflite
Score: 100
Status: offline
QUALITY LINE KITS     CURARE , IS ALICENCED PRODUCT.
Hide Signatures
       Post #: 167
RE: Scoop! Too early to release information. - 10/26/2012 4:10 AM
dphill2
Score: 100
Status: offline
Got tired of waiting so I scratched one out !!!!
Click for fullsize
Hide Signatures
       Post #: 168
RE: Scoop! Too early to release information. - 10/26/2012 5:59 AM
countilaw
Score: 219
Status: offline
quote:
ORIGINAL: hrdflite
[/quote
Hrdflite,    I can't wait to get my hands on another   Majic    from Quality Line Kits.    I   was able to get  an original  Header  from  Singapore with the help of another member here on  RCU.   Picked up a    pipe   for   $15   from a  LHS and retracts from  Ebay.    Now I'm just saving money for the plane.     The  first Majic I got from  QLK was fantastic,   take that back,   it was Majic.
Frank
Hide Signatures
       Post #: 169
RE: Scoop! Too early to release information. - 10/26/2012 6:25 AM
Rendegade
Score: 105
Status: offline
quote:
ORIGINAL: doxilia
Frank,
Stopping ''kitters'' of the Curare is like trying to stop the DVD movie replication business - it's everywhere. The good news is that we don't want it stopped...
David
What a wonderful problem to have. I wonder if he's astounded that 36 years later the curare would still have a cult following? Never in his wildest dreams I'll bet.
It''''s easy to fly, just throw yourself at the ground and miss!
Hide Signatures
       Post #: 170
RE: Scoop! Too early to release information. - 10/26/2012 9:44 AM
Jon Wold
Score: 105
Last Login: 5/8/2013
Status: offline
Hi, I have test flown the Curare ARF in Austria a few weeks ago. I can confirm it is not only endorsed by Hanno, he is the mastermind behind the project. Both Hanno and Schweighofer have tested the pre-production models extensively, with glow and electric power, and the delay (should have hit the shops a year ago) is in part due to the testing and subsequent change orders. The ARF model is based on the MK Curare 60 drawings.
Hanno has spent a lot of time with setting up his electric version, and plans to publish his own settings for all control surfaces including the flap/elevator mixes, dual rates, expos, CG and so on, so everyone can start with a perfect setup. One thing that was only recently discovered was that there is a difference in knife edge mix between electric and glow setups. Due to the battery position above the centerline, a slight increase in dihedral is recommended for electric setup.
The ARF has a very nice battery tray/hatch functionality, and also accepts glow engines with or without pipe with no modifications. It has a fully sheeted wing and stab, and it's beautifully built and covered. It is reported to weigh half a kilo less than the original.
F3A blog: http://www.aerowold.com
Hide Signatures
(in reply to Rendegade)
       Post #: 171
RE: Scoop! Too early to release information. - 10/26/2012 2:03 PM
Sport_Pilot
Score: 233
Status: offline
Which one is the original prototype?  The photo indicates the blue trimed one is, but your e-mail said it yellowed, but the green trimed one appears yellowed.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 172
RE: Scoop! Too early to release information. - 10/26/2012 3:32 PM
doxilia
Score: 136
Status: offline
quote:
ORIGINAL: Sport_Pilot
The photos show what appears to be a ~30 year old model perhaps owned by Hanno. The paint yellowing and apparently larger stab on this model was discussed and is what was being referred to as the "original prototype". I probably should have referred to it as an "original model" instead. When you say my "e-mail" you probably mean my post.
I don't think the blue trim covered ARF would be an "original prototype" of the ARF at this stage of development. It could very well be the electric model that Hanno has been setting up and that Jon refers to in his post above.
David
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 173
RE: Scoop! Too early to release information. - 10/26/2012 4:15 PM
Jon Wold
Score: 105
Status: offline
In the old/new comparison photo, the orange/green is one of the TOC Curares. The Circus Circus stickers are obvious enough, but you can also see a dark spot on the inner part of the wing where speed brakes protrude out from both top and bottom. He had lots of different version, one was for Springfield WC, one for South Africa, and the TOC versions. Differences were airfoils, brakes and spoilers. The blue/orange is Hannos electric ARF.
Hide Signatures
       Post #: 174
RE: Scoop! Too early to release information. - 10/26/2012 4:19 PM
PatternPilot
Score: 125
Status: offline
dphill2...
I hope your going to buff up that spinner..
Plane looks good !
Scott cpa#2
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
(in reply to Jon Wold)
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.641RCU1
