RE: HK Small Bolt Hydro same as HOTR    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: HK Small Bolt Hydro same as HOTR
Page: <<   < prev  41 42 43 44 45 46 47 [48] 49 50   next >   >>
Login
RE: HK Small Bolt Hydro same as HOTR - 1/4/2012 2:52 PM
sundogz
Score: 129
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: Rake
This all happened with one of those. I dont remember if the FS was set though.
Oops, sorry. Hopefully it wasn't set, like you said. Those kind of problems are real naggers. Hope you figure it out!
_____________________________
Arpro Mono,Genesis,Tenshock Essenz, PowerJet Viper,ABC Jet Ski,TearInto Jet Sprint, Legend & Discovery Sailers, JetCat proto
Hide Signatures
(in reply to Rake)
       Post #: 1176
RE: HK Small Bolt Hydro same as HOTR - 1/6/2012 2:40 AM
tremblay7
Score: 100
Last Login: 12/21/2012
Status: offline
Can not get my flex shaft out. Any idea??
Hide Signatures
(in reply to sundogz)
       Post #: 1177
RE: HK Small Bolt Hydro same as HOTR - 1/6/2012 3:26 AM
sundogz
Score: 129
Status: offline
I'm not 100 percent sure, but I think it is a two piece shaft (flex/prop) with a square end. If so, you need to remove the strut to pull the flex out as he prop shaft goes in from the rear of the strut. I hope I'm right on this one - maybe someone else (Rake?) will help out here.
Hide Signatures
(in reply to tremblay7)
       Post #: 1178
RE: HK Small Bolt Hydro same as HOTR - 1/6/2012 9:14 AM
Rake
Score: 110
Last Login: 4/17/2013
Status: offline
Stock shaft is 2 piece yes.
Remove the prop, undo the dog, release the coupler flex shaft screw and pull it out.
Hide Signatures
       Post #: 1179
RE: HK Small Bolt Hydro same as HOTR - 1/6/2012 9:54 AM
carakter
Score: 100
Last Login: 4/24/2013
Status: offline
quote:
ORIGINAL: tremblay7
If you will just read from Page 1, you will learn a lot about this boat - maintenance included.
Hide Signatures
       Post #: 1180
RE: HK Small Bolt Hydro same as HOTR - 9/23/2012 6:46 PM
Rake
Score: 110
Status: offline
I'm back.
Bolt is on the desk being fitted out again.
Any news guys ?
Hide Signatures
(in reply to carakter)
       Post #: 1181
RE: HK Small Bolt Hydro same as HOTR - 9/23/2012 8:26 PM
sundogz
Score: 129
Status: offline
Wow, it has been a while and by coincidence I was out tuning my Tenshock mini hydro today for the first time in 6 months or better. Glad to see you're back in the swing of things!
Hide Signatures
(in reply to Rake)
       Post #: 1182
RE: HK Small Bolt Hydro same as HOTR - 9/23/2012 8:34 PM
nickster46
Score: 100
Status: offline
Hi guys! That's a long time ago! My Bolt is still in the shed.
Didn't had some time to run it this summer.
 I also need to buy a new lipo charger so I can charge my batteries to test if they still work!
Right now I am going to buy a new charger first!
Hide Signatures
       Post #: 1183
RE: HK Small Bolt Hydro same as HOTR - 9/23/2012 8:35 PM
Rake
Score: 110
Status: offline
quote:
ORIGINAL: sundogz
Hey old friend, good to hear you.
Well I decided to crack on and finish what I started tonight and thought of dropping in to say hi.
I now also have a big version
http://youtube.com/watch?v=5Qw44teQqgw
Hide Signatures
       Post #: 1184
RE: HK Small Bolt Hydro same as HOTR - 9/23/2012 9:25 PM
Rake
Score: 110
Status: offline
Hi Nicster too - all we need now is caracter and we have a full on reunion !
4800kv keda now fitted....
Hide Signatures
(in reply to Rake)
       Post #: 1185
RE: HK Small Bolt Hydro same as HOTR - 9/24/2012 2:18 AM
carakter
Score: 100
Status: offline
 Present!
I thought everyone has moved on and lost interest in the Bolt.
Anyways, just like to report that I am still where I left off the last time . . .
Got the plastic EKOS props but never got to test them.
well maybe that the gang is here,  I might as well plan some weekend testing.
Glad to hear from you all my friends!
Hide Signatures
(in reply to Rake)
       Post #: 1186
RE: HK Small Bolt Hydro same as HOTR - 9/24/2012 3:50 AM
sundogz
Score: 129
Status: offline
quote:
ORIGINAL: Rake
If you thought these little boats can get expensive....well, you can guess the rest!
Good to hear from you Boltsters Sadly, I've had to thin my fleet and sold the Bolt a while back But kept my Tenshock Mini Hydro, as these are so much fun.
Hide Signatures
(in reply to Rake)
       Post #: 1187
RE: HK Small Bolt Hydro same as HOTR - 9/24/2012 8:40 AM
nickster46
Score: 100
Status: offline
LiPo balance charger is ordered, so now I need to search for all my batteries and test them if they still work.
The summer is gone since this week so I have  to be quick for a test run with the Bolt because otherwise it will be way too cold to stand next to the water haha.
Hide Signatures
       Post #: 1188
RE: HK Small Bolt Hydro same as HOTR - 9/26/2012 3:23 PM
Rake
Score: 110
Status: offline
Mine still amazingly work.
Going 2S 2200mah 40-50C on a Keda 4800kv = 34000 rpm
This is a rebuilt hull from one of my famous out of control events.
Just need to stick the servo down, Greece the shaft and test run !
Hide Signatures
(in reply to nickster46)
       Post #: 1189
RE: HK Small Bolt Hydro same as HOTR - 9/26/2012 5:13 PM
sundogz
Score: 129
Status: offline
quote:
ORIGINAL: Rake
Yes, weren't you having control problems the last time out? Maybe the gremlins got antsy and left! Hope all turns out well.
Hide Signatures
(in reply to Rake)
       Post #: 1190
RE: HK Small Bolt Hydro same as HOTR - 9/26/2012 9:16 PM
Rake
Score: 110
Status: offline
Well sdz thats what worries me, have they ?
This time analogue servo and fail safe checked !
Got a brand new hull and another wrecked one to fix too
Hide Signatures
       Post #: 1191
RE: HK Small Bolt Hydro same as HOTR - 9/27/2012 9:55 PM
Rake
Score: 110
Status: offline
Some pics for the return of Bolt 1
Hide Signatures
(in reply to Rake)
       Post #: 1192
RE: HK Small Bolt Hydro same as HOTR - 9/28/2012 2:40 AM
sundogz
Score: 129
Status: offline
Great color contrast. I found Black boats look cool, but are sometimes hard to keep up with on the water. There's no missing that boat!
Hide Signatures
(in reply to Rake)
       Post #: 1193
RE: HK Small Bolt Hydro same as HOTR - 9/28/2012 5:16 AM
carakter
Score: 100
Status: offline
@Rake - I myself go for loud colors. Kinda' hard to miss when running side by side with other boats .
            Not to mention the water spray!
            But honestly, my eyes are not what they used to be!   . . .
Anyways, I can't help but notice that silicone shaft seal rubbing on the motor coupler - looks like extra drag.
Maybe pull it back a bit just enough to clear some minute space in between?
Also, just wanted to ask if that Keda is a 2 pole motor.
Let us know how she goes.
@Sundogz - Do you have the TS carbon hull?
By the way, any of you guys move up to the HK Vortex?
< Message edited by carakter -- 9/28/2012 8:13 AM >
Hide Signatures
(in reply to Rake)
       Post #: 1194
RE: HK Small Bolt Hydro same as HOTR - 9/28/2012 2:10 PM
sundogz
Score: 129
Status: offline
quote:
ORIGINAL: carakter
Yes, the carbon version. I haven't run a vortex, but I jumped up to an H&M Lifter hydroplane which I plan to outfit like their Striker (no front canard or rear fins). The Lake I've been using is large and wavy most of the time, so I need to scale up (or run early or late to avoid big waves).
Hide Signatures
       Post #: 1195
RE: HK Small Bolt Hydro same as HOTR - 9/28/2012 7:09 PM
Landor
Score: 100
Last Login: 4/18/2013
Status: offline
Thanks for activating the tread. So...
quote:
ORIGINAL: sundogz
... I think you could get a little more speed by eliminating the 2s lipo used for the servo - just wire in the ubec to the speed controller battery terminals.
quote:
ORIGINAL: Landor
Thank you for the BEC power tip!
... finally today, almost a year later I did this change .
I also changed the motor to Leopard 2445 3400kv one.
Hide Signatures
       Post #: 1196
RE: HK Small Bolt Hydro same as HOTR - 9/28/2012 7:40 PM
Rake
Score: 110
Status: offline
Hi caracter
Thanks for the comments, it's all lubed and grease comes out of the silicone so perhaps no drag ? Might cut it anyway.
Vantaa - been there saw moose !
Hide Signatures
(in reply to Landor)
       Post #: 1197
RE: HK Small Bolt Hydro same as HOTR - 9/28/2012 8:39 PM
Landor
Score: 100
Status: offline
quote:
ORIGINAL: Rake
Well, I have not seen a moose here. Only in a bit more country side area. White-tailed deer is propably the closest to moose I have seen here. I have never been in UK, perhaps one day.
My boating has this summer focused on Genesis. Finally I managed to hit the 100 km/h target.
http://www.youtube.com/watch?v=fZ6zAwuHKsM
Now it is nice to test the Small bolt.
Hide Signatures
(in reply to Rake)
       Post #: 1198
RE: HK Small Bolt Hydro same as HOTR - 9/28/2012 9:18 PM
sundogz
Score: 129
Status: offline
quote:
ORIGINAL: Landor
Good show! That is a hot setup. Ive got the 1500kv version for 6s use - and a 45mm Octura. I was hoping to get similar speeds on my Genesis. I don't mean to hijack this thread, but are you running the inline rudder?
Hide Signatures
       Post #: 1199
RE: HK Small Bolt Hydro same as HOTR - 9/28/2012 11:00 PM
Landor
Score: 100
Status: offline
quote:
ORIGINAL: sundogz
Yes literally very hot setup. Strategy here was - "smoke or go", this time it was the "go". After this one minute drive the leopard plastic wire feed through was partly melting. But above 100 km/h in gps was my only goal. I tried this target with two motor-esc combinations earlier this summer without success. First time the leopard 4074 motor (2000kv+180a) didn't seem to have enough torgue. Second time my Himodel Hv ESC lived only 100 sec in preliminary test with T600 1400 kv motor. Last winter I installed an offset rudder so also this latest run was done with offset rudder.
Someting about small bolt...
This spring I tested two motors. The leopard 2040 4450kv didn't live long. I did few runs also with Leopard 2435 4000kv motor (Astec models accidentally sent me one when I ordered the 2445 3400kv). The 2435 4000kv motor was working guite OK but it was lacking torgue. Speeds were not anything special.
I hope the 2445 3400kv motor fixes the torque issue.
Hide Signatures
       Post #: 1200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
