RE: ESM 50cc Corsair    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: ESM 50cc Corsair
Page: <<   < prev  32 33 [34] 35 36 37 38 39 40 41   next >   >>
Login
RE: ESM 50cc Corsair - 2/19/2012 6:08 PM
Orion09
Score: 100
Last Login: 5/19/2013
Status: offline
 Wow is right. Do you know the all up weight? Get your local machine shop to turn a big steel prop nut for you.
Hide Signatures
(in reply to higharc)
       Post #: 826
RE: ESM 50cc Corsair - 2/19/2012 6:10 PM
kwik
Score: 105
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: higharc
I just checked my balance using the Saito FG-57T engine and found out I will need approx. 59.6 oz. up front including flight and ignition batteries. Checked with landing gear up. Wow!
That is 3 times more than me. FG-57 as well.
On the ice today;
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 827
RE: ESM 50cc Corsair - 2/19/2012 6:47 PM
vasek
Score: 147
Status: offline
kwik, I see you northern guys don't fear winters!
Do you have a close up pic of you hatch (open/ closed), I like the location. Never seen one there
Cheers, V.
_____________________________
Remember: Speed is life!
Hide Signatures
(in reply to kwik)
       Post #: 828
RE: ESM 50cc Corsair - 2/19/2012 7:23 PM
kwik
Score: 105
Status: offline
Here;
The colors are different in daylight; Its the flash doing most of it.....although my "home-paint" is much more matte, than the
factory paint...
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to vasek)
       Post #: 829
RE: ESM 50cc Corsair - 2/22/2012 10:02 AM
stoat
Score: 105
Last Login: 1/21/2013
Status: offline
Retracts and wheels are in! Made up track plates for the olios as the ESM stops are crap and slowly let your legs get longer resulting in the U/C jamming up. Not a great idea.....
Replaces all the bolts so I could get the wheel closer to the leg - and the stock ones are made of cheese. New 6mm bolt for wheel axle too.
Next was cowling. Pretty standard except for my patient lock screw system using nyrod inner to stop the cowling screws from vibrating out...
Then time to bolt that monster motor in the nose.
Yep, its tight! The plug caps will stick out so I will have to split the cowling so I can get it off - no biggie.
CORSAIR Brotherhood # 76 - Also known as Toast in other forums...
Hide Signatures
(in reply to kwik)
       Post #: 830
RE: ESM 50cc Corsair - 2/23/2012 10:26 PM
MSC
Score: 100
Last Login: 4/22/2013
Status: offline
Wow Stoat! Is that a dle111? I have a G62 and it flies fine....... Good luck. Would really like to hear how it flies...
MSC
Hide Signatures
(in reply to stoat)
       Post #: 831
RE: ESM 50cc Corsair - 2/23/2012 10:44 PM
Peter_OZ
Score: 108
Last Login: 5/17/2013
Status: offline
straight up and out of sight I would suggest . . .
fun police have struck again
Hide Signatures
(in reply to MSC)
       Post #: 832
RE: ESM 50cc Corsair - 2/23/2012 11:53 PM
stoat
Score: 105
Status: offline
Yer, I like to have a little in reserve when I fly.
Interesting to note, The full size corsair runs 2000 hp at a flying weight of 8980 pounds for a rating of 0.22 hp per pound. The super corsair had 3800 hp at almost the same weight so was rated at 0.42 hp/lb. Mine will be 11 HP at 25 pounds for a rating of 0.44 hp/lb so almost the same grunt as a Super Corsair... Makes you think eh? Some mad bugger strapped on a piece if aluminium powered by almost 4000 hp and flew it around? Suddenly I feel almost sane....
Hide Signatures
(in reply to Peter_OZ)
       Post #: 833
RE: ESM 50cc Corsair - 2/24/2012 12:03 AM
Peter_OZ
Score: 108
Status: offline
don't forget good old reynolds numbers - will have a big effect on your numbers
Hide Signatures
(in reply to stoat)
       Post #: 834
RE: ESM 50cc Corsair - 2/24/2012 12:19 AM
stoat
Score: 105
Status: offline
True. The numbers I have quoted really mean very little. Its just a interesting comparison for when people say I over power my planes. I cant find out what thrust specs the twin wasp produces in a Corsair. The DLE will give me 25kg @ sea level on a 27 x 10 prop. 25 kg! Thats 55 pounds! over twice what the plane will weigh. Pretty sure even the Super Corsair didnt have close to that thrust to weight. However it does have stacks or momentum that models just cant have. The extra thrust should mimic this...
Hide Signatures
       Post #: 835
RE: ESM 50cc Corsair - 2/24/2012 12:21 AM
BobH
Score: 116
Status: offline
A scale plane can typically fly at 1 hp/10lbs. So you have a rocket. Not to mention flutter and extra air frame stress thats a real potential. Good luck.
BobH.
Hide Signatures
(in reply to stoat)
       Post #: 836
RE: ESM 50cc Corsair - 2/24/2012 12:22 AM
Peter_OZ
Score: 108
Status: offline
good luck with that
Hide Signatures
(in reply to stoat)
       Post #: 837
RE: ESM 50cc Corsair - 2/24/2012 12:56 AM
stoat
Score: 105
Status: offline
Its OK guys, I'm qualified...
Luckily I have installed a devise that leats me vary the power output of the motor at will. I can always use this to reduce the thrust and therefore speed/loading on the airframe...
Hide Signatures
       Post #: 838
RE: ESM 50cc Corsair - 2/24/2012 1:12 AM
Orion09
Score: 100
Status: offline
 Got the Evolution mounted today.Put 3 degrees of thrust in it.The cylinders and intakes had to be loosened to get the Keleo exhaust on but it went well.A little sketchy getting all seven manifolds started without cross threads.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 839
RE: ESM 50cc Corsair - 2/24/2012 1:32 AM
BobH
Score: 116
Status: offline
I have one of those Evolution engies. I wouldnt mind putting it in one of those Corsairs.
BobH.
Hide Signatures
(in reply to Orion09)
       Post #: 840
RE: ESM 50cc Corsair - 2/24/2012 1:50 AM
wherewaldo
Score: 100
Last Login: 5/12/2013
Status: offline
nice looking engine... what is the displacement ?
Hide Signatures
(in reply to BobH)
       Post #: 841
RE: ESM 50cc Corsair - 2/24/2012 1:54 AM
Thunderbolt47
Score: 111
Status: offline
quote:
ORIGINAL: stoat
Plus you get to run a big nice scale size prop. That 111 should be able to swing a 26" 3blader. COOL
Greg Norman said, "Happiness is a long walk with a putter." Obviously he never flew a P-51 Mustang. :)
Hide Signatures
(in reply to stoat)
       Post #: 842
RE: ESM 50cc Corsair - 2/24/2012 1:59 AM
wherewaldo
Score: 100
Status: offline
and if i may ask where did you get the sets of standoffs...
i am trying to mount an asp 400 and i have to come out 2in ...i like the way yours is set up...
Hide Signatures
(in reply to wherewaldo)
       Post #: 843
RE: ESM 50cc Corsair - 2/24/2012 3:07 AM
Orion09
Score: 100
Status: offline
 Its a77cc glow at about 4.8 hp.The standoffs are heat dissipating which I didn,t need here but had around and fit are from thunderbolt rc.They are rc guys who carry lots of nice stuff for larger gassers etc.
Hide Signatures
       Post #: 844
RE: ESM 50cc Corsair - 2/24/2012 3:18 AM
wherewaldo
Score: 100
Status: offline
k thanks , i am familiar with them have bought a few things from them.....i assume the engine is fairly heavy
did you re-enforce the fire wall or nose gear in your plane or left it stock?
Hide Signatures
       Post #: 845
RE: ESM 50cc Corsair - 2/24/2012 3:28 AM
Orion09
Score: 100
Status: offline
 I laid in some carbon between the firewall and first former and epoxyed there mount cylinder.It should be lots strong.
Click for fullsize
Hide Signatures
       Post #: 846
RE: ESM 50cc Corsair - 2/24/2012 3:48 AM
wherewaldo
Score: 100
Status: offline
looks  good ..think i will do something similar ...thanks for the info!
Hide Signatures
       Post #: 847
RE: ESM 50cc Corsair - 2/24/2012 9:57 AM
stoat
Score: 105
Status: offline
I did the same as there is a joint about 20mm back from the firewall that doesnt look too strong.
Hide Signatures
       Post #: 848
RE: ESM 50cc Corsair - 2/24/2012 3:39 PM
mmflytie
Score: 100
Status: offline
How well does that steer and stop on that ice?
Hide Signatures
(in reply to kwik)
       Post #: 849
RE: ESM 50cc Corsair - 2/24/2012 3:48 PM
mmflytie
Score: 100
Status: offline
Well here is my finished cockpit and pilot.  Now I just hope I can get it in the plane!
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to stoat)
       Post #: 850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
