YNOT
Joined: 11/29/2001 From: Lake Jackson, TX, USA Status: offline
OK, I'm starting to like the plane a bit more now that I have a few more flights on it. In fact, Saturday night, I flew it at a night fly. Set Up: Irvine 53 w/ Tower muffler, 4721's in the wing, 9402 on the rudder, 9203 on the elevator, CF gear, lighter foam wheels, Tru Turn spinner & tail wheel, 6 volt 1100 mill pack, CF rods and ball joints on all surfaces, aluminum servo horns, 5 lbs 8 ozs. On the stabs breaking: I used Dave Brown carbon fiber, that I laminate onto the bottom of the horizontal stab at the trailing edge. I have used this method on several planes and have NEVER had one break. I have broken many with flying wires. I did not add any additional right thrust to the motor and I have no vertical issues. I am using a 2 stroke only swinging a 12' prop, however if you are using a 4 stroker swinging a 14" prop, you may want to add a washer behind the mount and add some right to it. I moved the CG back some, 7 inch's back. It flat spins better, hovers better, knife edges a little better and does everything just a little faster. I have the battery pack located right on the CG and the receiver on the other side of the middle bulkhead. So no additional weight was added. Mods: I double beveled the horizontal and vertical stabs to get more throw. Elevator high rate is 70 degrees and low is 45. On high rate it will do a waterfall, however you have to work the throttle. If I use spoileron it will just flip over and over and over and over. It does a great knife edge spin. The rudder will now SLAP the elevator half's at high rate. I used 1 1/4" servo arms. To do this, you need to swap sides on the elevator and rudder servos, so you don't get a weird angle on your control rod. This bird does a great Harrier and spoilerons are not needed. The Funtana does not seem to like flying very slow. I was thinking mine was heavy, however with the Funtana weight thread, I am right on par with others. The Funtana is not as forgiving as the Flip or UCD or a Profile. This bird is not for the faint at heart and it will keep you thumbs, eyes and brain on FULL alert.
_____________________________
YNOT, Snap, Flip & Hover, Tony D
