Battle systm for AirsoftTanks
one of our comrades in Ekaterinburg does it...
[youtube]http://www.youtube.com/watch?v=6Cdyey4Rip8&feature=player_embedded[/youtube]
Incription 1) light indicator of shots 2) reload button
how it works piezo sensors are inside and reacton turret or body touch, when BBhits the tank...video shows it...
RE: Battle systm for AirsoftTanks
I wonder how it functions on uneven terrain or simply just driving while the piezoelectric sensors are on? Very cool nonetheless!
AB, CANADA
ORIGINAL: BiggTony
YHR,
exactly that is wahat we are also aking the guys...
but anyway thenew video with extra sensors
[youtube]http://www.youtube.com/watch?v=K9StEkuS0uU&feature=player_embedded[/youtube]
Ya piezioelctric sensors ......ya..............that the first thing that came to my mind. What the heck are those, are they like shock sensors likethey use on that show the"Deadliest Warrior"Be cause those are large for a 16th sclae tank.
Funny i notice a bb hits it stops the tank i notice he taps the tank it stops?
Now when you shoot your airsoft from the tank i know the turret snaps back real hard sometimes won't this make the sensors go off if a light tap of a bb does?
Don't think this will work ...that's my take on it.
Only way it could work (in my mind) is making the sensitivity of the impact sensor real low.......which means the opposing tank needs to launch an airsoft bb with the impact of a marble and limit terrain to the gym floor. But, this is just an assumption...I don't know if this guy has a microcontroller in the tank and programmed to respond to a single impact over repeated vibrations of the terrain. However, I doubt it at this point.
Could this system be adappted to a fixed target mode? Say, a pill box or fuel tank or ammo supply? Could the output be changed to diffrent effects for diffrent targets?
I'm thinking flashing LEDs and perhaps smoke and sound when you score a "kill" on a pillbox or some ammo depo. That would solve the tank bumping over terrain problem and give us all more things to shoot at. Movable "fixed "targets we could set up and have our buddies do "seak and destory missions" while we try to stop them.
What if the only way to win is to prevent the other side from taking out your fuel supply at all costs. One good shot by them and it's over. You would need to hold them back out of range with your tanks.
Each side gets one fixed target to hide behind their lines. Both sides must defend their Target and attempt to destory the other sides. Kind'a capture the flag with 1/16 scale tanks. Perhaps an IR version for those poor boys.
It's an idea I have been pondering for awhile but those boys in Russia seem to be ahead of me on the R&D side. Keep it up and keep us posted.
I see them sold for about $100 US each. Two ( more fun ) for $190 US. Switches to change the type of explosion and adjust the sound level. Some cool looking outside that will fit in with all our other tank stuff...
A plastic pillbox with dummy cannon, comes in two sizes!... Ammo depo, fuel tanks, command post, etc...
I would buy two.
I would buy two.
Guys,
we have also many qs to the people that are testing this system.
So I will keep you informed re steps they are passing through while they adopt their "baby" to the tank battle reality...
Hi, this is my project
No, I've tested this aspect very first, piezo-sensor is sensitive only to very "sharp" hits - with very large speed.
I'll take some video, how this system woks while shooting.
PS: Sorry for my poor english.
ORIGINAL: shenlonco
ORIGINAL: BiggTony
Only way it could work (in my mind) is making the sensitivity of the impact sensor real low.......which means the opposing tank needs tolaunchan airsoft bb with the impact of a marble and limit terrain to the gym floor. But, this is just an assumption...I don't know if this guy has a microcontroller in the tank and programmed to respond to a single impact over repeated vibrations of the terrain. However, I doubt it at this point.
That is detail photo of this modified tank internal parts:
ORIGINAL: Pah co chu puk
I'm thinking flashing LEDs and perhaps smoke and sound when you score a "kill" on a pillbox or some ammo depo. That would solve the tank bumping over terrain problem and give us all more things to shoot at. Movable "fixed "targets we could set up and have our buddies do "seakand destory missions" while we try to stop them.
The original idea of my project - airsoft battle of human-controlled and half\full autonomous robots in different scenarios.
"Defend the base / Search and destroy" is one of main scenarios. Other standard scenarios - Duel, Deathmatch, CTF(but for robots only - because gripper is need).
ORIGINAL: XeaX
Yes, there is MCUin my tank, but there is no need even for ADC - I use simple digital port on 3.3V running mcu. Because tank body is relatively large and made from plastic - it works like filter for vibration from chassis. And even in some fake hits will occure on stone terrain - I'll install rubber insertings between chassis and upper body of tank.
ORIGINAL: BiggTony
ORIGINAL: BiggTony
Thanks for clarifying and I stand corrected. Is the unit programmed to ignore continuous pulses sent by the sensor?
ORIGINAL: BiggTony
Is this just something your doing as a personal project or do you plan to market something like this and if you do, how would you propose keeping the costs down using microcontollers?
I think that sometimes owners of RC-tanks can play with futuristic scenarion in one field with RC-controlled and even fully autonomous robots with airsoft "weapons".
And about "keeping cost down" - I don't understand. Entry level MCU, and even Arduino Nano (as example of small MCU project) cost is not so high.
ORIGINAL: XeaX
to market mean to promote it for future sale.
Xeax,
Micro controllers don't necessarily mean high cost, but programming does, then manufacturing, and configuration, labor and so forth. But you clarified that that your system is simple by means of a variable resistor.
A good " rule of thumb" for manufacturing and marketing products like this is to:
Take your production costs and multiply by 5 to 6 for your final retail cost to concumers.
This allows for the cost of materials, production, storrage, transport, taxes and marketing of the product.
Anyway I need MCU for playing sounds - "hit" and "destroyed".
And in theory we can add miniUSB port for firmware update, setting up hit points, or even setup options like "2 hit points decrease in case of turret hit".
PS: My primary target of this project for now - is robot battle.
That means, that first of all I'll try to make mcu-based working hit detection controller. If it will be interesting for RC-tank owners(in terms of sales volume)- I'll start specific project "RC-tank airsoft hit detector", in which may be I remove MCU from module.
PPS: Sorry about my poor english
XeaX,
Very cool, thinking out side the box. Keep us posted please.
Pah co chu puk, quote
"Each side gets one fixed target to hide behind their lines. Both sides must defend their Target and attempt to destory the other sides. Kind'a capture the flag with 1/16 scale tanks. Perhaps an IR version for those poor boys."
I like this idea also, thanks all for sharing. This gives me some ideas of my own.
DT
ps - XeaX, don't worry about your english your fine....I can't speak any Russian
DT
ORIGINAL: XeaX
As for all this pricenonsense, not important. Just finish your project! lol
ON, CANADA
I guess the team with the stonger guns would have a definite advantage. They could destroy the other team even long before they get in range to inflict any damage themselves. Sounds familiar (lol)
