Swick Taylorcraft
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Swick Taylorcraft
Page: [1] 2 3   next >   >>
Login
Swick Taylorcraft - 7/22/2003 1:36:55 AM
Praire Flyer
Status: offline
I have the Plans for the Swick Taylorcraft from Model Airplane News. Thinking of building my first scratch built. Any feedback about these plans, and the weight of finished plane? Also does anyone know if somone makes a fiberglass cowl for this plan?
       Post #: 1
RE: Swick Taylorcraft - 11/15/2006 8:03:37 PM
hifly2104
Status: offline
check out the thread 1/4 Swick Taylorcraft
I managed to find one of these almost completely built .Not completely but enough that I can say I did some of the work. At the present I am building the right wing left is already built. Do you know how much harder it is to build one to match a previously built by someone else. Like most people no one follow the plans 100% as with the wing I have to match . So I have to look at the plans look at the wing check cap strip etc sizes. The other thing I am using a wing jig the previous builder had and have never used one before not saying its not a good thing just a little different .. The instructions I have the pictures are dark (not that you can't use them )and grainy. Instructions well I read them and will reread them but as my build is further along than a Start I don't think I overly need them . I am sure some one out there makes a glass cowl for this plane but the cowl they describe made with wood that the top comes off sounds kinda like what I want ,not sure I will build it exactly as describe as with the materials used. This is one of the things I like about this hobby I can experiment and DO IT MY Way
If I can find the scanner we had here and get it to work and you would like a copy of the instructions PM me here with your email address I will be glad to send them
< Message edited by hifly2104 -- 11/15/2006 11:09:51 PM >
(in reply to Praire Flyer)
       Post #: 2
RE: Swick Taylorcraft - 11/15/2006 9:00:46 PM
KI8FR
Status: offline
I have a 1/4 taylorcraft and I do know who made the kid or if it is crached or not.. do you have a pic of what your plane looks like?
(in reply to hifly2104)
       Post #: 3
RE: Swick Taylorcraft - 11/15/2006 9:46:44 PM
mmattockx
Status: offline
quote:
ORIGINAL: hifly2104
hifly,
I searched for the thread you mentioned, but only found this one:
http://www.rcuniverse.com/forum/m_838499/anchors_838499/mpage_1/key_swick/anchor/tm.htm#838499
It only has one reply and nothing else. Did I miss it?
Mark
_____________________________
Waco Brotherhood #4
       Post #: 4
RE: Swick Taylorcraft - 11/16/2006 12:43:14 AM
hifly2104
Status: offline
Hi Mark , i just mentioned it as it appeared 2 threads on the same topic could be going and thought it might be easier to pull everyone into one thread.
Tellspin37 unsure of what you mean "I have a 1/4 taylorcraft and I do know who made the kid or if it is crached or not." I don't have any pics right now but will take some when I have finished the wing The plane I have is the one mentioned that is scratch built from the plans in MAN
< Message edited by hifly2104 -- 11/16/2006 12:44:01 AM >
(in reply to mmattockx)
       Post #: 5
RE: Swick Taylorcraft - 11/16/2006 2:40:15 AM
Looper
Status: offline
The plans for the Swick were in two parts; the first part was published with the MAN article and the second part came with the the set of plans. The plans were drawn by the late Jim Simpson who was an avid T-Craft fan. He published several other plans and they were all good. IMHO, the Swick was his best work. I built and occasionally fly the version that was kitted by ACE. Any T-Craft is a fine flyer due to its great moments and the semi-symmetrical airfoil. I believe Stans Fiberglass has a cowl available. Good luck, Frank
< Message edited by Looper -- 11/16/2006 2:45:39 AM >
       Post #: 6
RE: Swick Taylorcraft - 11/16/2006 3:22:54 AM
KI8FR
Status: offline
The one I have is a 1/4 scale. I is alot like the sig 1/4 scale j3. but sig did not make this. It looks to be scrach bilt. The cow on this plane that I have is the same cow but fiberglass that is on the sig j3 1/4 scale. The plane is grate. I love it.. but I get asked about the plane all the time and no anser for it.
That is why I asked about it.
Paul
(in reply to Looper)
       Post #: 7
RE: Swick Taylorcraft - 11/16/2006 3:40:15 AM
hifly2104
Status: offline
Hey Tellspin thats not a problem I just didn't understand what you originally asked .I will try and get some pictures on here by the weekend .That is if I can figure that out. As Looper stated the one I am building is by the late Jim Simpson
(in reply to KI8FR)
       Post #: 8
RE: Swick Taylorcraft - 11/16/2006 3:43:23 AM
mmattockx
Status: offline
quote:
ORIGINAL: Looper
All good news, as I ordered these plans a few weeks back and am waiting impatiently to get them into my hands.
Do you have any weights for this model? I am thinking that either a G-26 or Brillelli 40GT would make a great flyer depending on weight. It will be finished with Koverall and dope (really, is there any other way to finish?? ) as well.
Mark
Waco Brotherhood #4
       Post #: 9
RE: Swick Taylorcraft - 11/16/2006 12:51:12 PM
hifly2104
Status: offline
The plans say the bare bones shell weighs just 5lbs I can see that with what I have already have built . I guess from there its weight of covering and servos and engine that will get it up there. Duh now that was a no brainer reply , but I hope you know what I meant. I was thinking of using a 1.08 or a 1.48 ASP or MDS. I have a weedwhacker conversion that was in another 1/4 scale Tcraft but I have it set aside for a Treehopper ( www.rcguys.com)I bought for my 6 year old daughter for Christmas
Covering I was going to use Super Coverite I have a large 4'x15' roll I used the older coverite years ago and had tremendous luck with it . I will experiment with waterbased acrylic enamel. Try it on something small and if I like it go with it.Paint scheme now that is the trick . I need plane to be red and yellow so I can see it in the sky. Other colours tend to, well go black or blend in with the sky. Must be an Age thing
       Post #: 10
RE: Swick Taylorcraft - 11/16/2006 5:42:20 PM
mmattockx
Status: offline
quote:
ORIGINAL: hifly2104
With a 5lb airframe, I can see ending up around 13lb with a 40cc Brillelli on board. That would be an awesome combination, with close to unlimited vertical and that nice gas engine sound, along with cheap operation. I can see this plane becoming a daily flier that goes to the field every time I do.
Mark
Waco Brotherhood #4
       Post #: 11
RE: Swick Taylorcraft - 11/19/2006 6:16:36 PM
hifly2104
Status: offline
Ok I will play the silly game how does one add pictures to a Thread. They are on a floppy disc (Sony Digital Camera)
Thanks Mike
       Post #: 12
RE: Swick Taylorcraft - 11/19/2006 9:46:21 PM
Skinny Bob
Status: offline
Mike, if you can convert them to .jpeg format they will upload providing they are not to big. 6000KB is max size.
Bob
Skinny Bob - AMA 713081
WACO Brotherhood #10
       Post #: 13
RE: Swick Taylorcraft - 11/19/2006 11:50:40 PM
hifly2104
Status: offline
Well I can save them to my pictures don't know if that changes them to a jpeg format or not but what do I do to get them from My Pictures to this thread Don't seem to see anywhere that it says add attachment
(in reply to Skinny Bob)
       Post #: 14
RE: Swick Taylorcraft - 11/20/2006 4:13:07 AM
mmattockx
Status: offline
Mike,
You need to use the "reply" button on the top right of each post, not the quick reply box at the bottom of the screen. Then it gives a link in the bottom of the text box to upload pics. Hit that, then browse the the location on your computer where they are stored and it will upload them.
BTW, got my plans order yesterday and had a quick look at the Swick Taylorcraft plans. Nice plans, fairly extensive building and not as big as I was expecting. Should be very enjoyable to get into it and have the balsa chips flying.
Mark
Waco Brotherhood #4
       Post #: 15
RE: Swick Taylorcraft - 11/20/2006 11:38:00 AM
hifly2104
Status: offline
Ok That was supposed to work .The first picture is an incomplete fuse, which may seem easy but I have always found it easier to cut pieces together when there are more than one the same. As you can see where wing fastens isn't there on the one side and you can see the new wing .
Maybe its a location thing ,you being on the prairies lol ,but I think this is quite a large plane As you can see with the wing on it spans nearly 8' the fuse is over 14" wide. I will definitely be using a 148 engine or bigger on this plane
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by hifly2104 -- 11/22/2006 3:22:56 AM >
