RE: wren supersport    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: wren supersport
Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: wren supersport - 7/2/2010 6:10 PM
BaldEagel
Score: 118
Last Login: 5/18/2013
Status: offline
I am agreeing with the fact that no action could be taken with the sent back turbine because someone was not there as on post No 95, Keep up Harry.
Mike
_____________________________
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to HarryC)
       Post #: 101
RE: wren supersport - 7/2/2010 6:15 PM
HarryC
Score: 100
Status: offline
That's right Mike, it's a dreadful crime for some of the staff to go and actually sell the product for a couple of days to keep the business afloat in these most difficult of times.
H
Hide Signatures
(in reply to BaldEagel)
       Post #: 102
RE: wren supersport - 7/2/2010 8:20 PM
BaldEagel
Score: 118
Status: offline
Now your getting the idea Harry , if any buisness relies on just one or two individuals to run, it will not be able to give sufficient support or technical back up to its customers, it rearly is that simple.
Mike
Hide Signatures
       Post #: 103
RE: wren supersport - 7/2/2010 8:37 PM
Eddie P
Score: 120
Last Login: 5/19/2013
Status: offline
Dang... do you guys whine this much or more "whilst" off line? Just morbidly curious I suppose.
Hide Signatures
       Post #: 104
RE: wren supersport - 7/2/2010 9:13 PM
lozza1965
Score: 105
Status: offline
F**k me only i only said i thought that someone should stay behind, as does seem the case does one comment credit so much crap.
http://www.flickr.com/photos/laurie-hughes/
Hide Signatures
(in reply to Eddie P)
       Post #: 105
RE: wren supersport - 7/2/2010 9:25 PM
box55555
Score: 100
Last Login: 5/14/2013
Status: offline
My how we seem to love to deviate from the thread matter.
Talking to Paul, they have been able to replicate my problem back at Wren HQ. It seems that on very high temperature days it is possible for the electronics to drift off. This seems to manifest itself in the trottle command giving greater than 100% input. This is then not understood by the ECU which then give the shut down command. This would bare out the facts, as Merryfield was hot and some.
Two things to note, me must use the wing bags to shade the electronics in the blazing mid day sun and secondly any funny antics on running, do a re-learn of the trottle first.
All things back in the airframe, but next door is not to keen on the noise. Off to the flying site tomorrow morning, so will update after that.
settings on the returned ECU
Accel delay 012
Deaccel delay 015
Stabalisation delay 050
Pump start Auto+0
Pump ramp 006
Hide Signatures
       Post #: 106
RE: wren supersport - 7/2/2010 10:26 PM
highhorse
Score: 116
Status: offline
Uh-Oh.
I can't imagine a that your temps approach what we have here in the southern U.S.
What were the outside temps on your problem days?
RCU Rocks, I''d hate to be without it !!
Hide Signatures
(in reply to box55555)
       Post #: 107
RE: wren supersport - 7/2/2010 10:34 PM
Eddie P
Score: 120
Status: offline
The outside temperatures, when running my Supersport, have approached 41-42c, or 106f. My FADEC resides just aft of my canopy, however, it is below the cockpit tub so it may, in effect, be shielded from the majority of the heat soak. However the cockpit is scale and dark and the paint in general is not reflective, so it would absorb a lot of heat if it weren't for me placing a white towel over the glass when it is sitting.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to highhorse)
       Post #: 108
RE: wren supersport - 7/2/2010 10:42 PM
box55555
Score: 100
Status: offline
Hi USA
Love the gorgious airframe.
Thankfully we do not get that warm, but my ECU in on the top in direct sunlight. Have learnt my lesson from now on.
Hide Signatures
       Post #: 109
RE: wren supersport - 7/2/2010 11:29 PM
Gaspar
Score: 105
Status: offline
It is the transmitter that you must protect from heat, the ecu is fine up to 85ºC, beyond this temperature it stop working, but don't have drift.
Gaspar
Owner of: www.xicoy.com Partner of:www.jets-munt.com
Hide Signatures
       Post #: 110
RE: wren supersport - 7/3/2010 1:18 AM
causeitflies
Score: 120
Status: offline
Here are the pics of the install...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Mark P
An Expert has made every mistake - A Master has made every mistake twice
Hide Signatures
(in reply to Gaspar)
       Post #: 111
RE: wren supersport - 7/3/2010 2:30 AM
davo580
Score: 100
Last Login: 5/17/2013
Status: offline
in the pictures i did not see air holes in the canopy. the more air intake the better
Hide Signatures
(in reply to causeitflies)
       Post #: 112
RE: wren supersport - 7/3/2010 2:35 AM
c_makhija
Score: 100
Status: offline
Here in India we have had hundreds of flights on Wren turbines. Our winter temperature are 30 degrees C and summer temperatures  are 40 degrees C. So far 1 supersport  and 1 160 had similar problems as described in this thread new out of the box, all different settings were tried but they refused to run reliably, both engines were sent to Wren and both came back running perfect. So far we have had to change no settings on any of the Wrens running here due to high temperatures. yes its always a good idea to cover electronics from direct sunlight.
Chaitanya.
quote:
ORIGINAL: box55555
Accel delay 012
Deaccel delay 015
Pump start Auto+0
Pump ramp 006
Hide Signatures
       Post #: 113
RE: wren supersport - 7/3/2010 4:07 AM
gooseF22
Score: 103
Last Login: 4/30/2013
Status: offline
cause...
move your ecu to the other side of the plane. moving it away from the fuel pump just in case its making electrical or magnetic noise. cant hurt..
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to c_makhija)
       Post #: 114
RE: wren supersport - 7/3/2010 4:12 AM
causeitflies
Score: 120
Status: offline
quote:
ORIGINAL: gooseF22
cause...
Goose,
Not my plane. I just posted the pics for paulflys4fun...
Mark P
Hide Signatures
(in reply to gooseF22)
       Post #: 115
RE: wren supersport - 7/3/2010 6:20 AM
gooseF22
Score: 103
Status: offline
quote:
ORIGINAL: causeitflies
quote:
ORIGINAL: gooseF22
cause...
Goose,
Oh. OK..
NVM..
I just spent the last two months working in the Electromagnetic Laboratory testing our new Geo Orbit Satellite system and I saw some neat things about magnetic and electromag interference coming from things... A little fuel pump puts off a field that can affect electronics, especially when power is applied to accelerate. gave me a new appreciation for installations to not stuff things too tight. Our ECUs also give off a bit of EMI as guys know from the 72MHz days. I just wonder if a fuel pump can affect an ECU.. I think maybe yes?
Goose
Hide Signatures
       Post #: 116
RE: wren supersport - 7/3/2010 10:27 AM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: Eddie P
Dang... do you guys whine this much or more ''whilst'' off line? Just morbidly curious I suppose.
Whine off line NO, but complain when I don't get service YES, there is a difference, and you did ask.
Mike
Hide Signatures
       Post #: 117
RE: wren supersport - 7/3/2010 11:31 PM
new2jets
Score: 100
Last Login: 1/31/2012
Status: offline
These motors which went back to wren what did they say was wrong ??????
IF it was just ecu setting we would have put that right at home, somthink fishy here !.
I FEEL THE NEED THE NEED FOR SPEED
Hide Signatures
       Post #: 118
RE: wren supersport - 7/3/2010 11:37 PM
box55555
Score: 100
Status: offline
Hi New2jets
Only the pump and the ECU went back.
Have been down the field and all seems to be well.
Will update on Friday
Hide Signatures
(in reply to new2jets)
       Post #: 119
RE: wren supersport - 7/5/2010 7:45 PM
HarryC
Score: 100
Status: offline
Don't know if the info is of any help at all, may just be spurious coincidence, but these people were having Jetcat problems in some versions of the Boomer http://jmajets.co.uk/board/viewtopic.php?f=3&t=1778
Hide Signatures
       Post #: 120
RE: wren supersport - 7/5/2010 8:16 PM
Forgues Research
Score: 100
Last Login: 10/31/2011
Status: offline
quote:
ORIGINAL: HarryC
The other problem he mentions with glow plug, well I have solved this problem forever with a spark ignition I developped , works flawlessly... for what its worth.
Roger
Hide Signatures
       Post #: 121
RE: wren supersport - 7/5/2010 11:27 PM
Xairflyer
Score: 105
Status: offline
quote:
ORIGINAL: Forgues Research
Roger
Tell me more ? something myself and a friend was talking about only recently
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to Forgues Research)
       Post #: 122
RE: wren supersport - 7/6/2010 12:03 AM
Forgues Research
Score: 100
Status: offline
quote:
ORIGINAL: Xairflyer
Roger
I replace the glow plug with the same size spark plug, put a resistor (30 ohm) instead of the glow plug, no mods to the ecu or engine . easily put back the glow plug if you wish although I don't know why would want that LOL.
in my case, I only use propane for starting and not the propane/butane mix. it might work but I haven't tried it and the propane only works flawlessly so why change.
But with my setup, I use a needle valve in the propane line instead of a pulsating valve. and you will notice a lot less propane is needed , the needle is opened about .75 of a turn to 1 turn.
After developing my own system I am now having the complete setup made out in china , plug and play....
Roger
Hide Signatures
(in reply to Xairflyer)
       Post #: 123
RE: wren supersport - 7/6/2010 12:38 AM
Xairflyer
Score: 105
Status: offline
What are you using as an ignition for the spark plug?
www.jmaireland.com
Hide Signatures
       Post #: 124
RE: wren supersport - 7/6/2010 12:43 AM
Forgues Research
Score: 100
Status: offline
quote:
ORIGINAL: Xairflyer
I use a regular ignition module but without the auto advance and make it fire continuously with a timer I made . As I said I now have them made with everything built in
Roger
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
