Ys91ac ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Ys91ac ?
Page: [1]
Login
Ys91ac ? - 7/22/2003 7:39:35 AM
rhd-RCU
Status: offline
After several years of having this engine I finally started it up.
My problem is that when going down to idle at a certain point it starts going faster again. You can not kill the engine. The lowest the idle will go is around 3 or 4 thousand, I must be doing something wrong
_____________________________
rd
       Post #: 1
idle problem - 7/22/2003 7:44:52 AM
blue62
Status: offline
sounds like you might have a leak around the base of the carb...does it have an o-ring around the bottom? check for leaks with wd 40 or some other type of spray oil if it is leaking it will slow down for a second then speed up again
good luck
(in reply to rhd-RCU)
       Post #: 2
Ys91ac ? - 7/22/2003 7:49:44 AM
rhd-RCU
Status: offline
The only time it changes speed is when I move the throttle. Below half throttle it starts speeding up again
rd
       Post #: 3
Ys91ac ? - 7/22/2003 8:12:27 AM
azhar
Status: offline
rhd,
1) Check and clean your diaphragm.
2) Make sure that your regulator screw is flush with the housing.
3)Make sure your idle stop screw is allowing your throttle to fully close.
Let's start with these measures first and let us know what happens.
Good Luck
Azhar
       Post #: 4
Ys91ac ? - 7/23/2003 8:04:10 AM
rhd-RCU
Status: offline
I tried everything. I even called YS. They said it was some kind of air leak. I can't seem to find one. I am sending it back to them. Thanks for the help
rd
       Post #: 5
Y S RepaIr expert - 7/23/2003 9:10:20 AM
dickj
Status: offline
If its out of warranty contact rcengman on this site for a excellent repair job at much less cost than the mfg. charges. he is excellent.
Whatever goes up, doesn't necessarily come back in the same conditon.
       Post #: 6
Ys91ac ? - 7/23/2003 8:00:43 PM
deputydog
Status: offline
more than likely your O rings in and around your air chamber are cracked from being dry. The simple thing to do is get an O ring set from Central Hobbies. Best $20 you'll ever spend!
       Post #: 7
Ys91ac ? - 7/23/2003 9:47:23 PM
rhd-RCU
Status: offline
Thanks guys,
I got it fixed. One of the valve guides was pushed out of it's o-ring a little bit. Runs like a champ now. Time to go fly.
rd
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU5
