RE: Central NEW YORK boaters    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Central NEW YORK boaters
Page: <<   < prev  31 32 [33] 34 35 36 37 38 39 40   next >   >>
Login
RE: Central NEW YORK boaters - 10/10/2011 9:09 PM
engineman351
Score: 100
Last Login: 5/15/2013
Status: offline
Neil, Are you actually using a G2D motor?? I don't have any extra barbs, but I'd give you a WA167 carb that used to work very well on a G2D motor. I think they have a little small venturi size 11.11mm vs 12.5mm for a WT257/488. Roger
Hide Signatures
(in reply to advanced builder)
       Post #: 801
RE: Central NEW YORK boaters - 10/10/2011 9:10 PM
advanced builder
Score: 105
Last Login: 5/21/2013
Status: offline
Roger I did see a hull still in the box ,here on the buy and sell section. You need to build it. Roger the belts were Aquacraft I think he said $6.00 it that right? After getting this .67 CMB it's a hard starter. If you feel the Prather Belts are better I 'll get them. I f you have any in stock ,if not I can order here in town I have several new ones but if I bust em like that I may need more.
Craig get that big OS out that will eat the fuel.Quick I thought I was stocked up good on nitro ,until me messing with the .67 stuff. We will be here into next year if we just used the .12 hulls getting rid of 3/4 gal nitro. Craig you were fast enough this year on 40% I keep 40 % around for the hot & humid days. A lot less trouble in that weather 50 % gets fussy. I did get some readings on my Boris meter. Now is the time to mess with that. The # will be different from each meter. I think your meter will read different than mine. Right?
_____________________________
Stoney Pond Model Boat Club, Canandaigua, NY
International racer
Hide Signatures
(in reply to engineman351)
       Post #: 802
RE: Central NEW YORK boaters - 10/10/2011 9:30 PM
engineman351
Score: 100
Status: offline
Craig, My Cajun Bullet is a gasser. I have run it only once in Elmira in Open Rigger, but I really do not know how fast it was. It certainly looked like a good E-bay speed!! There were always dead boats to avoid (mine sometimes!!) and I was really shaking down the handling and prop selection. I'm pretty sure Scott's .67 SGX finished a lap ahead of me as I didn't care about the start or swinging wide in the corners. If I can get back out to Stony Pond, I'll strap a GPS on it to see how fast it goes. I've actually had it with me a few times on Thursdays, but the sun and moon weren't in the right positions to allow me to take it out of the truck!! Probably a better rigger to compare your 45 to would be the old .67 Mongoose. Thats a little smaller boat and seemed to have predictable handling the one time I tested it at Elmira. If I get time to replece the throttle servo and cable I'll bring that too. Roger
Hide Signatures
(in reply to Blackout)
       Post #: 803
RE: Central NEW YORK boaters - 10/10/2011 9:31 PM
Billk44
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: advanced builder
Neil,
I believe Frankie G. worked that 67 Greenhead you have. Are you using 24v starters? Starts my 67 Greenhead with ease. In a 67 cat, expect to use 20 ounces+ fuel per race. 67 rigger used 16+ ounces. That is why we had that much fuel to sell. Once it get hot & humid, anything over 50% makes it interesting. That is why I always used 3rd channel remote needles.
Bill
Hide Signatures
       Post #: 804
RE: Central NEW YORK boaters - 10/10/2011 9:39 PM
engineman351
Score: 100
Status: offline
Neil, The Whiplash in the 'Classified' is a Sport 40. Let me know if you come across A Whiplash GenII gasser. I'll check the Dan's stock on Belts tomorrow night. Thanks, Roger
Hide Signatures
       Post #: 805
RE: Central NEW YORK boaters - 10/10/2011 9:46 PM
engineman351
Score: 100
Status: offline
Bill, My 24V starter wouldn't crank it. I know my 24V starter uses 4AMP batteries which I thought might be an issue. However, I don't have any problems cranking my .67 Picco or .82 K&B stuff. Neil and Craig's starters wouldn't crank it either. I think they use 24V too. Neil starts his big OS stuff ok. Roger
Hide Signatures
(in reply to Billk44)
       Post #: 806
RE: Central NEW YORK boaters - 10/11/2011 2:48 AM
Blackout
Score: 100
Status: offline
Yes, the number will be different for each meter.
I have not ordered a new piston/sleeve/rod for my O.S. 91. I'm trying to decide whether to just use that money toward a big block CMB....
Craig Mapstone, IMPBA #20305S, Stony Pond Model Boat Club
2012 D1 20 Hydro Champion
Hide Signatures
       Post #: 807
RE: Central NEW YORK boaters - 10/11/2011 12:48 PM
Billk44
Score: 100
Status: offline
quote:
ORIGINAL: engineman351
Has me wondering what the squish is set at on Neil's 67. My starter batteries are 7 amps per battery. My Macs were nastier to start than the CMBs.
Hide Signatures
       Post #: 808
RE: Central NEW YORK boaters - 10/11/2011 3:04 PM
advanced builder
Score: 105
Status: offline
Bill ,I haven't opened up the .67 CMB. I was going to test the v hull. First All looks OK Yes she starts hard . I broke 2 used belts in Elmira on my.67 cat. I can swap out the carb on the EV and my Aeromarine hull will be ready to test.
International racer
Hide Signatures
       Post #: 809
RE: Central NEW YORK boaters - 10/11/2011 4:23 PM
tomstoys2
Score: 100
Last Login: 5/13/2013
Status: offline
Hey Guys,
One of these days I'm going to make it out to Stoney Pond. I went to Buffalo this weekend for the Bills game and ran FE with some of the guys from the area on Sat. Weekends like that don't come around to often. I thought I would share a few videos.
This is my buddy's Phil Thomas Hydro running 6s. He's go a new custom turn fin that seems to be working very well:
http://www.youtube.com/watch?v=xzaRdtTJRmc
This one is my friend John's carbon fiber 36" cat with twin counter rotating outrunners. He's still got some tweeking to go.
http://www.youtube.com/watch?v=Ud8SvpbFBHE
Hope to see you all soon.
Tom
Hide Signatures
       Post #: 810
RE: Central NEW YORK boaters - 10/11/2011 5:07 PM
Blackout
Score: 100
Status: offline
quote:
ORIGINAL: tomstoys2
Hey Guys,
This one is my friend John's carbon fiber 36'' cat with twin counter rotating outrunners. He's still got some tweeking to go.
Tom
Thanks for sharing. Looks like a good place to run. Is that at the University of Buffalo? Looks like you have geese too....
Hide Signatures
(in reply to tomstoys2)
       Post #: 811
RE: Central NEW YORK boaters - 10/11/2011 5:13 PM
tomstoys2
Score: 100
Status: offline
It's just a little past UB. Called Muir Lake. It's in a small office park that the Scale guys run at. Electric only(sorry). Ya, man do I hate goose poop!
Hide Signatures
       Post #: 812
RE: Central NEW YORK boaters - 10/11/2011 5:52 PM
Billk44
Score: 100
Status: offline
Neil,
Roger may have squish guage you could borrow. A lot easier. I am betting it is set tight with the amount of power it is putting out. That engine would be murder in a rigger.................
Bill
Hide Signatures
       Post #: 813
RE: Central NEW YORK boaters - 10/12/2011 1:22 PM
advanced builder
Score: 105
Status: offline
Bill I was thinking a .45 short kit from Zippkits and my .67 CMB until I seen that Video of a .45 running. that's crazy fast. I'm not to sure I want to go that fast. At least with a gas rigger I can go off pipe and get back on, not so with nitro. The .45 kit is 1/2 done. the gas rigger I'm working on the tub.
International racer
Hide Signatures
       Post #: 814
RE: Central NEW YORK boaters - 10/12/2011 1:58 PM
Billk44
Score: 100
Status: offline
Neil,
Do some research on Jim's before you build. Some folks shimmed the strut in addition to toeing in the right sponson to stop the right pulling. Nice rigger if you can rid of the bad habits. Other folks added 1" sponson ride pads to improve performance. A little reading may save you some frustration. These boats will run 70+ and the right pulling makes them very difficult to race with. 2718/2 (no lift) really made it cook..............
Bill
Hide Signatures
       Post #: 815
RE: Central NEW YORK boaters - 10/12/2011 2:58 PM
engineman351
Score: 100
Status: offline
Neil, Dan's Crafts has all three Aquacraft belt sizes (1 ea) in stock @$4.99. We only have the small and medium sizes of the Octura belts @$7.29. If you want to 'stock up' let me know and I can order some more for you and get them to you thru Craig. Roger
Hide Signatures
       Post #: 816
RE: Central NEW YORK boaters - 10/12/2011 5:02 PM
Blackout
Score: 100
Status: offline
Neil, Here is one thread to look at for tuning the JAE gas riggers.
http://www.jrcbd.com/showthread.php?t=51968&highlight=handling
Seems like it's all in the turn fin, rudder, and prop selection for the JAE riggers....
Hide Signatures
       Post #: 817
RE: Central NEW YORK boaters - 10/12/2011 6:24 PM
advanced builder
Score: 105
Status: offline
quote:
ORIGINAL: Blackout
Looks like I got some reading to do. Thanks Craig
International racer
Hide Signatures
       Post #: 818
RE: Central NEW YORK boaters - 10/12/2011 6:27 PM
Billk44
Score: 100
Status: offline
quote:
ORIGINAL: Blackout
Neil,
I tried the stock trun fin as well as the Accu-tech and a heavy modified Dick Tyndall (Virginia Craftsman) turn fins. All pulled to one degree especially the stock one. Enjoy the reading because that guy ended up selling his.
Bill
Hide Signatures
       Post #: 819
RE: Central NEW YORK boaters - 10/12/2011 7:30 PM
Blackout
Score: 100
Status: offline
quote:
ORIGINAL: Billk44
quote:
ORIGINAL: Blackout
Neil,
Bill
I found it interesting that Rod G. said they stopped testing the prototype gas JAE once they hit 70 mph with a stock engine.
The JAE design may run too free in the water for gas engines. It may need more than just a rudder out back to counter the prop walk. Did anyone try adding a left turn angle in the strut similar to what the Seaducer monos have?
Just thinking out loud.
Hide Signatures
       Post #: 820
RE: Central NEW YORK boaters - 10/12/2011 7:45 PM
advanced builder
Score: 105
Status: offline
Here you go so nicads can't explode This is what happen last night as I was watching the baseball game A big pop like firecracker and some sparkles and smoke. Not doing anything just setting ,I charged it a few days ago.
Bill I believe I have the latest fin from Joe I recall last year He had several to test out.
Click to see fullsize image.
Click for fullsize
International racer
Hide Signatures
       Post #: 821
RE: Central NEW YORK boaters - 10/12/2011 7:59 PM
engineman351
Score: 100
Status: offline
Neil, Tell me more about those NiMh cells. Was that just sitting alone or was it in a vehicle? The only time I have seen them go off on their own is if the shrink wrap was abraided and the cells were allowed to short on a metal surface. The old NiCd's and NiMh's actually do vent with a pop or 'explosion'...LiPo's will actually burn like a flare with a LOT of heat (usually more dangerous). Roger C.
Hide Signatures
       Post #: 822
RE: Central NEW YORK boaters - 10/12/2011 8:04 PM
advanced builder
Score: 105
Status: offline
They were just setting there. No warning no smell until the explosion. On a wooden table the wrap was vented or not fully wrapped.
International racer
Hide Signatures
       Post #: 823
RE: Central NEW YORK boaters - 10/12/2011 8:09 PM
Blackout
Score: 100
Status: offline
Neil, Put a Novarossi .46 in your JAE 45 and it will be faster than your gas JAE. That gas stuff is just too hard to tune....
My .21 JAE comes off pipe and back on just fine. Just keep the pipe a little long, the prop a little small, and the engine mostly stock.
Hide Signatures
       Post #: 824
RE: Central NEW YORK boaters - 10/12/2011 8:10 PM
Blackout
Score: 100
Status: offline
Wow, that's scary stuff.
Hide Signatures
       Post #: 825
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.858RCU1
