RE: Central NEW YORK boaters    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Central NEW YORK boaters
Page: <<   < prev  70 71 [72] 73 74 75 76 77 78 79   next >   >>
Login
RE: Central NEW YORK boaters - 4/25/2012 7:12 PM
advanced builder
Score: 105
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: engineman351
I stole most of this off an e-airplane site:
The ''C'' rating tells you how much current it is safe to draw from your battery. It's expressed in terms of the capacity C.
So a 1200mAh 10C battery is good for 12A (10 x 1200mA/1000) and the same size 12C battery would be good for 14.4A (12 x 1200mA/1000). An example: One battery is 900mAh and 10C so it is good for a 9A draw. A second battery is a bit smaller at 850mAh but higher rated at 12C so it's good for a 10.2A draw. You can plug in the numbers for whatever pack you are using to see how many amps you can potentially draw.
The C rating doesn't mean your motor will go faster or run for longer. It just means that if you ever want to use more current, by using the battery with a different motor or a bigger prop, the 12C battery will allow more than the 10C version.
Furthermore most RC’ers treat the ‘C’ rating as a ‘burst’ or max amp draw situation…but to know how close you are actually getting to the ‘burst’ level, you need some form of a ‘Watt Meter’ to really understand what is happening in your set-up. My rule of thumb is: The higher the ‘C’ rating the less chance there is of exceeding the battery’s capacity to give up current and not hurt your battery.
Anyway...my 2 cents (again!!) Roger
So {50 x 2200/1000} 11.0A draw or am I off. I told my LHS what I was going to use them for. As I didn't see were the brown wire on the starter went. I will put the stuff together and let you do the final wiring. I'm not totally sure about my wiring skills. I will get it close. I will make the box large enough for all lips sizes.
_____________________________
Stoney Pond Model Boat Club, Canandaigua, NY
International racer
Hide Signatures
(in reply to engineman351)
       Post #: 1776
RE: Central NEW YORK boaters - 4/25/2012 7:28 PM
Blackout
Score: 100
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: advanced builder
That's fine. Brown wire is the positive, or negative if you are starting an outboard.
Craig Mapstone, IMPBA #20305S, Stony Pond Model Boat Club
2012 D1 20 Hydro Champion
Hide Signatures
(in reply to advanced builder)
       Post #: 1777
RE: Central NEW YORK boaters - 4/25/2012 7:31 PM
Blackout
Score: 100
Status: offline
Speaking of fast electrics... Here is a picture from Jim's Dock. To see it, you may need to be logged in to Jim's....
I guess we need a fire extinguisher handy with FE boats....
Hide Signatures
(in reply to Blackout)
       Post #: 1778
RE: Central NEW YORK boaters - 4/25/2012 7:37 PM
Billk44
Score: 100
Last Login: 5/15/2013
Status: offline
quote:
ORIGINAL: Blackout
I think a Type IV is needed for LiPo's and Roger can probably clarify. A few years back we had some killer FEs in from Ohio and Canada. They were S and T riggers. An 8s rigger caught fire sitting on the stand with the batteries disconnected. I could not believe how fast the flames went from 1' to 6' or 7'. Don't use puffed packs or you are asking for trouble.
Hide Signatures
       Post #: 1779
RE: Central NEW YORK boaters - 4/25/2012 8:27 PM
Blackout
Score: 100
Status: offline
You are good for 110 amps, 50 x 2.2 ah.
I am good for 100 amps, 25 x 4.0 ah.
The Dynatron starter is rated for 100 amps, so you are good to go.
Roger, Good info!! Thanks!
Hide Signatures
       Post #: 1780
RE: Central NEW YORK boaters - 4/25/2012 10:07 PM
Joe Petro
Score: 108
Status: offline
I meant Pete in Elmira.
Yes, I will call you when we go there. We will be running our 72 inch vee soon, and I need a large area...
Joe
-Zippkits-
People make this a great hobby!
Hide Signatures
(in reply to BULLITTGT)
       Post #: 1781
RE: Central NEW YORK boaters - 4/25/2012 10:26 PM
BULLITTGT
Score: 100
Last Login: 12/16/2012
Status: offline
72 inch V ..........u kiddin me? is this another one of your mega machines or will this reach production someday?
tell me its a turbine please..........i gotta see this!
Hide Signatures
(in reply to Joe Petro)
       Post #: 1782
RE: Central NEW YORK boaters - 4/26/2012 1:41 AM
Joe Petro
Score: 108
Status: offline
Turbine like styling...
Joe
-Zippkits-
Hide Signatures
       Post #: 1783
RE: Central NEW YORK boaters - 4/26/2012 3:19 PM
advanced builder
Score: 105
Status: offline
quote:
ORIGINAL: Joe Petro
Joe
Is the new hull in production. We could call it the Sleazy Vee Has the bottom angle been changed ?
Cheezy Vee sounds better. got the double ee
Pee Vee after Petro
Wee Vee after Wee Wee Tango
< Message edited by advanced builder -- 4/26/2012 3:57 PM >
International racer
Hide Signatures
       Post #: 1784
RE: Central NEW YORK boaters - 4/26/2012 4:23 PM
Blackout
Score: 100
Status: offline
If all goes well, I'll be running my .12 Zippkit rigger for the first time this Sunday afternoon!
Let me know if anyone else wants to run on Sunday afternoon.
Hide Signatures
       Post #: 1785
RE: Central NEW YORK boaters - 4/26/2012 4:52 PM
advanced builder
Score: 105
Status: offline
Rigger Sunday will be a good one.12:00 12:30 is fine for me. My .12 carb has the mods that Glenn mentions Low speed needle is flush with the carbs inside wall. And the brass carb pipe modified. Looking at a few of my older carbs the brass fuel pipe cuts are all facing down. My .12 NR isn't starting. Looks like no compression. The .18 Go has no waterlines as that water jacket is very heavy and big. I added the .12 NR air fin-ed head. Will it over heat !!!!! Bob .18 needs water. we found that one out. I'll need to do some tub cutting to get the 6 oz tank inside.
International racer
Hide Signatures
       Post #: 1786
RE: Central NEW YORK boaters - 4/26/2012 5:42 PM
Blackout
Score: 100
Status: offline
Sunday at 12:30 sounds good.
Reading about carb mods, it sounds like cutting the spray bar at 90 degrees gives better fuel atomization.
Yes, Bob's .18 needs full water. Kinda funny how some need water, some don't.... My air cooled head should work o.k. I didn't want to run water lines; .12 riggers are so small.
I hope to bench run the .12 motor in Saturday night using a heat gun to warm the head before starting. There is allot of pinch, which seems to be the norm for these small engines.
Do you have the flex 6oz. slant tank? Mine fit in fine, just need to squeeze the tank. Friction should keep this tank in, but it does stick up 1/4". No big deal since I'm not running a cowl. I like to go in the water early, so 6oz was needed.
Hide Signatures
       Post #: 1787
RE: Central NEW YORK boaters - 4/26/2012 6:05 PM
Billk44
Score: 100
Status: offline
quote:
ORIGINAL: Blackout
Do you have the flex 6oz. slant tank? Mine fit in fine, just need to squeeze the tank. Friction should keep this tank in, but it does stick up 1/4''. No big deal since I'm not running a cowl. I like to go in the water early, so 6oz was needed.
The flex tanks can be shaped nicely using a heat gun to make them fit. Too bad these can't be used for gas.
Hide Signatures
       Post #: 1788
RE: Central NEW YORK boaters - 4/27/2012 1:29 AM
advanced builder
Score: 105
Status: offline
We will have a .45 rigger for testing. I ordered a headbutton on the .45 CMB ,The glowplug thread is NOT right. I can swap out my spare for parts. Do they sell another kind of plug bigger thread???? It's a turbo head, from Stu I'll call him tomorrow. Got me scratching my head on this one. I went to tighten the coupler and added my piston-stop. No good. way off.
International racer
Hide Signatures
(in reply to Billk44)
       Post #: 1789
RE: Central NEW YORK boaters - 4/27/2012 5:17 AM
c.k.y.
Score: 105
Last Login: 5/5/2013
Status: offline
Hi advanced builder
I hope to use the translation function to understand what you say
Modified  turbo head ?
I have an old photograph taken in the 1990s Australia to the World Championships.....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1790
RE: Central NEW YORK boaters - 4/27/2012 3:22 PM
Blackout
Score: 100
Status: offline
Not sure on the plug??? Strange....
The .45 rigger should break some Stony Pond records! Bring your stop watch!
Hide Signatures
       Post #: 1791
RE: Central NEW YORK boaters - 4/27/2012 3:24 PM
Blackout
Score: 100
Status: offline
quote:
ORIGINAL: c.k.y.
Hi advanced builder
Always good to see the old pictures! Thanks for sharing!
Hide Signatures
(in reply to c.k.y.)
       Post #: 1792
RE: Central NEW YORK boaters - 4/27/2012 3:35 PM
advanced builder
Score: 105
Status: offline
c.k.y. , Stu Barr is the CMB dealer over here. I ordered a .45 CMB headbutton and the darn thing has the wrong glow plug treads It was to be a turbo head ,looks like any normal button. Who's that with you ?
I've never been to a world championship event. Must be a big race ,guys coming from all over the world .
Thanks for reply
Neil
International racer
Hide Signatures
       Post #: 1793
RE: Central NEW YORK boaters - 4/27/2012 3:45 PM
advanced builder
Score: 105
Status: offline
quote:
ORIGINAL: c.k.y.
Hi advanced builder
That's one cool old hull. I like the engine mount. What size engine.
International racer
Hide Signatures
       Post #: 1794
RE: Central NEW YORK boaters - 4/27/2012 4:41 PM
engineman351
Score: 100
Status: offline
I always like seeing older hulls from Europe and Asia. The monos alway look like thay are designed to run in rough water...and look like they could 'roll over' and keep on going. Sort of like the current 'Eco' hulls raced in Europe currently. The motor mount in c.k.y.'s pic is similar to a the Solinger mounts we use on our small riggers. Simple and effective. Everything doesn't have to be anodized and cost $65 to work. Roger
Hide Signatures
       Post #: 1795
RE: Central NEW YORK boaters - 4/27/2012 6:22 PM
Blackout
Score: 100
Status: offline
Kinda like my $3.50 JAE 21 strut.
Hide Signatures
       Post #: 1796
RE: Central NEW YORK boaters - 4/28/2012 1:14 AM
advanced builder
Score: 105
Status: offline
Your water tight linkage is a good price as well.Craig I kinda did the same on the .45 linkage. A piece of water line to seal .I'm adding the pipe mount and still need to add the water line. ALSO using that 3 rd channel. I better read up. Bill I have the same 3rd channel needle you have. Which line goes to the carb top or bottom? I think top but need to double CK
International racer
Hide Signatures
       Post #: 1797
RE: Central NEW YORK boaters - 4/28/2012 1:17 PM
Billk44
Score: 100
Status: offline
On a Ferrette type needle base, the top goes to the carb. The flow goes past the leading edge of the needle (bottom to top). Not sure how you are going to get the initial setting. If using a flow meter make sure it goes through the remote needle. The needle allows for less than a 1/4 turn throw in either direction so you have to be close but it really stops you from shooting yourself in the foot. It is really slick how remotely changing the needle will affect engine performance.
Hide Signatures
       Post #: 1798
RE: Central NEW YORK boaters - 4/28/2012 2:14 PM
advanced builder
Score: 105
Status: offline
Looks like another freeze last night. 34 right now but sunny. We will learn on the fly. Ill bring my flow meter. I may try to start the engine today. And get a reading on the flow meter. Craig my starter parts are here and the box is sealed. I did do some wiring That 2 nd black wire has got me stumped.
International racer
Hide Signatures
       Post #: 1799
RE: Central NEW YORK boaters - 4/28/2012 2:52 PM
c.k.y.
Score: 105
Status: offline
Thanks for reply
Neil
Hi Neil
I'm sorry I translation errors
In the photo on the left is my right is my British friends.
The boat using older CMB-90/15c.c.( engine mounts the United Kingdom making, material is aluminum alloy)
I like to make different types of boat
I also have a JAE-21 but did not have time to finish it
In 1976 and produces (CANARD HYDRO) some photos
 CKY
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1800
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.516RCU1
