RE: Central NEW YORK boaters    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Central NEW YORK boaters
Page: <<   < prev  75 76 [77] 78 79 80 81 82 83 84   next >   >>
Login
RE: Central NEW YORK boaters - 5/8/2012 2:52 AM
engineman351
Score: 100
Last Login: 5/15/2013
Status: offline
Hydro Junkie...I met with the hydro owner over the weekend and got a good look at the plans. He definitely missed the inside risers on both sponsons. It looks like Dumas only beveled the outside of the left sponson at 45 deg. I won't be able to start fixing it until the weekend and will consider just adding the inside risers with new ride pads as well as removing what is there already and starting with a squared up block of styrofoam so I can be sure I have the pads at the correct height and flat level. To me, the hardest part will be re-glassing the repair and and finishing for paint. I also have to replace the driveline with 1/4 inch cable and a 5/16ths tube. Probably the smartest move over the weekend was to give the owner some experience on the radio with a simple deepvee. We are going to keep up with the practicing on small vee's and cats so he gets the hand eye coordination necessary to even attempt wheeling a hydro. When we see he can get a Miss Vegas around the buoys and back to the dock then well see if he ready for his boat. Thanks for the Newton pics. Do you recall the thread on a 1/8 scale hydro build that shows the Dumas hydro bottom?? I saw it the other day, but can't find it again. You were part of the dialog. If you know what I am refereing to, maybe you could send me the link. I think it was on IW. Thanks again. Roger C.
Hide Signatures
(in reply to Hydro Junkie)
       Post #: 1901
RE: Central NEW YORK boaters - 5/8/2012 4:43 AM
Hydro Junkie
Score: 116
Last Login: 5/25/2013
Status: offline
All of the boats looked really good, not sure about the chest high launch on the Vector's run though
Hide Signatures
(in reply to Canadian LoCo)
       Post #: 1902
RE: Central NEW YORK boaters - 5/8/2012 4:59 AM
Hydro Junkie
Score: 116
Status: offline
Roger, is it one of these:
http://www.rcuniverse.com/forum/m_10828546/mpage_4/key_/tm.htm
http://www.rcuniverse.com/forum/m_9618442/mpage_9/tm.htm
If the one you're refering to isn't one of these, I'll have to check IW when I get home from work which won't be for another 2.5-3 hours
Hide Signatures
       Post #: 1903
RE: Central NEW YORK boaters - 5/8/2012 9:27 AM
Hydro Junkie
Score: 116
Status: offline
Okay, I'm home and found the following:
http://www.intlwaters.com/index.php?showtopic=45564&st=60
This is the only one I found that showed the boat built with stock sponsons. I would advise AGAINST using foam inside the pads. If the pads leak, the foam will absorb water, some foams quickly and some slowly. If you leave them hollow, you can always drain out the water with a simple hole in the transom. Another option would be to leave the back of the pad open and just seal the inside with epoxy. Two center ribs running down the length should be enough to keep the bottom flat between the outside frames
Hide Signatures
       Post #: 1904
RE: Central NEW YORK boaters - 5/8/2012 11:37 AM
c.k.y.
Score: 105
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: Blackout
Roger's .21 Seaducer.
Hi friends
Thank you for sharing the beautiful video...
Play video fine adjustment of the control and boats adjustment !!
CKY
Hide Signatures
(in reply to Blackout)
       Post #: 1905
RE: Central NEW YORK boaters - 5/8/2012 12:16 PM
Blackout
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: engineman351
If you need a block of blue foam, I have some I can give you on Saturday. Unless I'm missing something, I see foam being the best way to fix it. Epoxy the foam to the bottom, shape it, and then add 1/16" ply. Just like a rigger sponson. Blue foam will not absorb water very easily as far as I know.
_____________________________
Craig Mapstone, IMPBA #20305S, Stony Pond Model Boat Club
2012 D1 20 Hydro Champion
Hide Signatures
(in reply to engineman351)
       Post #: 1906
RE: Central NEW YORK boaters - 5/8/2012 3:14 PM
engineman351
Score: 100
Status: offline
Hydro Junkie, Thanks for the links. I can see the sponson build for both sides. Like I said earlier...will probably start the repair over the weekend. Roger
Hide Signatures
       Post #: 1907
RE: Central NEW YORK boaters - 5/8/2012 3:23 PM
engineman351
Score: 100
Status: offline
Craig, Thanks for the foam offer. I will keep that in mind as I decide how best to re-construct the ride pads. Dale may also have some pieces left in the kit that might help retain the proper contour of the inside risers as well as the bevel on the outside sponson. I will have to see what wood he has left. FYI...I removed the boom tubes from the gas rigger. They measure .625OD .500ID, seems like pretty common 5/8ths aluminum tubing. I will check Debbie Supply to see what they have before looking at McMaster Carr. I do hope to run on Saturday...but I am still not sure what chores I have to address first. Roger
Hide Signatures
       Post #: 1908
RE: Central NEW YORK boaters - 5/8/2012 4:15 PM
advanced builder
Score: 105
Last Login: 5/23/2013
Status: offline
I have plywood lots do you need some.
Stoney Pond Model Boat Club, Canandaigua, NY
International racer
Hide Signatures
       Post #: 1909
RE: Central NEW YORK boaters - 5/8/2012 5:16 PM
Blackout
Score: 100
Status: offline
Looks like McMaster has .509" ID and .495" ID in 6061 5/8" O.D. aluminum tubes.
http://www.mcmaster.com/#standard-aluminum-hollow-tubing/=hg2vqh
Hide Signatures
       Post #: 1910
RE: Central NEW YORK boaters - 5/8/2012 11:21 PM
Hydro Junkie
Score: 116
Status: offline
Roger, forget about the kit's foam. The kit has the white foam that falls apart at a touch. If you decide to use foam, go with the blue instead
Hide Signatures
       Post #: 1911
RE: Central NEW YORK boaters - 5/9/2012 12:06 AM
gassertom
Score: 100
Status: offline
Craig,
Thanks for helping the technology impaired old folks with this!  Hopefully I'll get it figured out soon!
Cindy (and Tom)
Tom Driver
IMPBA #6425
Hide Signatures
       Post #: 1912
RE: Central NEW YORK boaters - 5/9/2012 2:00 PM
Billk44
Score: 100
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: advanced builder
Craig if you haven't put away that needle I used. Could you give me how many turns out My needle came in the mail today. If Bill did come we could put the 3rd channel back to work on my .45. No one uses-em here. Were you put down the control arm may be way off. Then I could use that needle on my .21 rigger. And we all could learn how a 3rd channel works. I will not be able to come early on Friday in Elmira to help setup.
Neil,
This is the needle I used on the Don Ferrette base (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCN51&P=ML). A few comments as this is being made overly complex. When trying to dial in the motor, set the needle manually, not with the servo. In other words, set it like any other manual needle. On a 3PM Tx I set the 3rd channel control to the DT3 switch on the pistol grip. You have to be able to make changes without looking down at the radio. The switch is momentary in both directions. Right should lean and left should richen. Make sure this is correct and double check the servo direction. The needle and base should be fine (not coarse) for 21/45 engines.
Bill
Hide Signatures
(in reply to advanced builder)
       Post #: 1913
RE: Central NEW YORK boaters - 5/9/2012 2:46 PM
Joe Petro
Score: 108
Last Login: 5/17/2013
Status: offline
I am going to try to get out to Stoney Pond this Saturday.
If anyone needs me to bring anything, send me an email...
Joe
-Zippkits-
People make this a great hobby!
Hide Signatures
       Post #: 1914
RE: Central NEW YORK boaters - 5/9/2012 2:47 PM
engineman351
Score: 100
Status: offline
Hydro Junkie, Thanks, I'll use a piece of blue foam if I think I need it to help keep the new risers squared up. All I'd like from the kit is the diecut inside risers at least to use as a pattern. On the plan the inside riser appears to taper and curve upward as it approaches the low speed step, adding a slight curve to the front of the ride pad. Anyway, I'll be digging into this over the weekend and give you an upadte next week. Roger
Hide Signatures
       Post #: 1915
RE: Central NEW YORK boaters - 5/9/2012 2:54 PM
advanced builder
Score: 105
Status: offline
OK I will try to setup differently than the last time. I had my servo going one way. I did have the DT3 switch working no limits were set. like open/close And CK my needle. I have another pipe from Stu Barr to test. I did like the Cooper for Noise. let me test this one. Let me play
Beware of the Holiday Special
you heard it here FIRST
. I may need to go into isolation for testing
Drive-line is IN I added a wooden wedge to the stuffing tube, no T-bar I need to set-in one more fiberglass cloth. Working on the radio box today.then test soon
International racer
Hide Signatures
(in reply to Billk44)
       Post #: 1916
engineman351
Score: 100
Status: offline
Craig, I found a nice piece of 5/8ths OD aluminum tube in my stock bin that I bought to repair another rigger project. It has a 1/16th wall, so I will need to bore/drill the ID out on a lathe. I actually had Curtis from Dan's do the boom set for the project rigger about a year ago. I'll see if he can do another set for me. This is what a guy will do to save spending another $30 on another piece of tubing with a thinner wall!!! Roger
Hide Signatures
       Post #: 1917
RE: Central NEW YORK boaters - 5/9/2012 4:36 PM
Blackout
Score: 100
Status: offline
Sounds like Saturday will be another good turnout!
Roger, are you going to bid on the Lynx molds? They are up for sale on IW's. You can sell the hulls through Dan's.
Hide Signatures
       Post #: 1918
RE: Central NEW YORK boaters - 5/9/2012 6:29 PM
engineman351
Score: 100
Status: offline
Doesn't DH already have a set that he uses??? I can't fix all the stuff I have... let alone try building hulls from scratch!! RC
Hide Signatures
       Post #: 1919
RE: Central NEW YORK boaters - 5/9/2012 10:04 PM
Joe Petro
Score: 108
Status: offline
We have the replacement aluminum boom tubes for the JAE Gas rigger in stock.
They are .625 OD .495 ID 6061 and 24 inches long.
Joe
-Zippkits-
Hide Signatures
       Post #: 1920
RE: Central NEW YORK boaters - 5/10/2012 6:06 AM
engineman351
Score: 100
Status: offline
Joe, I placed an order for the tubes on the Zipp site. Bring the tubes with you if you come on Saturday. Even if I can't make it you can leave them with Craig, and I will pick them up. If you can't make it just ship them. Thanks, Roger C.
Hide Signatures
(in reply to Joe Petro)
       Post #: 1921
RE: Central NEW YORK boaters - 5/10/2012 3:17 PM
advanced builder
Score: 105
Status: offline
I'm leaving the area,for a few. Striped Bass are hitting big
International racer
Hide Signatures
       Post #: 1922
RE: Central NEW YORK boaters - 5/10/2012 6:09 PM
Blackout
Score: 100
Status: offline
Are you gonna run boats on Saturday?
I'm going to take some pictures of us this Saturday for the June Roostertail. Thanks Luc! From the west side, I'm thinking of taking a shot of the drivers stand and pit area with two boats passing by at full speed.
I solid mounted my .12 rigger remote needle. It was flapping in the wind before, that may have been a problem, or not.... Worth a try anyways.
Hide Signatures
       Post #: 1923
RE: Central NEW YORK boaters - 5/10/2012 7:14 PM
engineman351
Score: 100
Status: offline
Craig, When we were looking at the needle hanging out the side of the JAE...I was thinking that spray off the sponson, or just the force of the 'wind', could be bending the tubing back and interrupting the fuel flow. I have left them 'floating' on a tunnel and not had any issues, but the needle was pretty well blocked by the cowl. No Tunnel Thursday for me tonight. Hope to see you all on Saturday. Roger
Hide Signatures
       Post #: 1924
RE: Central NEW YORK boaters - 5/10/2012 7:40 PM
Blackout
Score: 100
Status: offline
Yah, I won't be running either. I'm working on the gas mono cowl tonight. I should be running the gas mono this Saturday! The .12 rigger too!...
Roger, will spray enamel paint adhere to gel coat? Would I need a primer? I am trying to decide how best to blacken the windows on my gas mono cowl. I'm not looking for perfection.
When redoing the stuffing tube on my gas mono, I noticed the tube bent out of shape at the middle. It bent enough to hit the hull and put a 1/2" stress crack in the bottom gel coat! Not sure how that happened. I'll need to work harder to get a gradual bend maybe, but there was hardly one....
Hide Signatures
       Post #: 1925
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
