RE: Central NEW YORK boaters    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Central NEW YORK boaters
Page: <<   < prev  96 97 [98] 99 100 101 102 103 104 105   next >   >>
Login
RE: Central NEW YORK boaters - 8/27/2012 1:21 AM
advanced builder
Score: 105
Last Login: 6/16/2013
Status: offline
One good testing day. The QD engine inside my gas JAE,problem found the spacer on my piston ,broke apart. The piston wall has some damage that's all. Fixable. The Speedmaster skeg strut worked fine. no more right sway at high speeds.[>:] was the fastest I've gone all year. And my carb was only 7/8 open. Linkage arm problem. So Bob Looks like the gas JAE goes to Ottawa and the .45 JAE stays home. If I can fix the QD
The .21JAE has engine PROBLEMS. not fuel or needle. So Craig the 35+21 NR in going in. I gotta go pull the CMB and find out what's up- killing me.
Bill
your old/ {new to me} engine is going to Ottawa. And WIN.
Rick
the Vee hull would go great with that inboard .67 Picco or your new OPS. A good winter project. The hull is light enough.
Look over the winter and get a tunnel for the outboard. from IW for the .45 outboard.
_____________________________
Stoney Pond Model Boat Club, Canandaigua, NY
International racer
Hide Signatures
(in reply to advanced builder)
       Post #: 2426
RE: Central NEW YORK boaters - 8/27/2012 1:42 AM
Blackout
Score: 100
Last Login: 6/19/2013
Status: offline
Neil, Are you going to try the NR in your JAE 21? If you and Bob come over this week, let me know what day. Maybe I can take more time off work, maybe...
Rick, here is a picture that shows how I make a hole in the sponson foam to add slow cure epoxy. This is done after the tube is epoxied in with the sides also epoxied.
Craig Mapstone, IMPBA #20305S, Stony Pond Model Boat Club
2012 D1 20 Hydro Champion
Hide Signatures
       Post #: 2427
RE: Central NEW YORK boaters - 8/27/2012 1:47 AM
Blackout
Score: 100
Status: offline
quote:
ORIGINAL: advanced builder
Bill
Rick
Get Luc to switch you to LSG Gas Rigger.
Hide Signatures
       Post #: 2428
RE: Central NEW YORK boaters - 8/27/2012 5:40 AM
engineman351
Score: 100
Last Login: 6/18/2013
Status: offline
Thunderboat follow-up: It took a bit of work to get the cylinder of the Thunderboat engine. The piston was defintely scuffed (melted) and seized on the intake side but the ring was still free in the lands. It looks like the cylinder can be re-used with just some scotchbrite to remove the aluminum from cyl wall. However, I have installed a brand new Zenoah top end kit (one of the kits from Joe!!) While I cannot find any blockage in the water flow...it did get awfully hot. I'll have to go with Tom 'not seeing' the usual water spray on that last lap or two on Thursday. The top of the piston does not show any sign of detonation...so I do not think it was lean. The crankcase looks ok and had plenty of oil residue in it. I'll be running a drill thru the rudder and all the fittings to make sure there isn't a piece of goop or silicone blocking the water flow. Last, Joe's pipe is scorching the stringer. I need to clearance the stringer around the pipe at least 1/4th inch and try getting more air around the pipe by opening the front facing air intake and venting the cowl along the rear deck portion.
If I don't see the Stony Pond racing team before you leave...Have a great time in Ottawa. Bring back some 'wood'!!! Roger C
Hide Signatures
(in reply to Blackout)
       Post #: 2429
RE: Central NEW YORK boaters - 8/27/2012 10:59 AM
Blackout
Score: 100
Status: offline
Hi Roger,
Below is the cooling line I switched to on my k30. This is the same line Bob uses. It's slightly larger than the large blue nitro fuel line. My K30 runs cooler with it. I also made new water outlets that were larger. It's from McMasters.
5054K531 25 Ft. Metric High-temp Silicone Rubber Tubing, Soft, 4 Mm Id, 8 Mm Od, 2 Mm Wall, Black
Hide Signatures
(in reply to engineman351)
       Post #: 2430
RE: Central NEW YORK boaters - 8/27/2012 1:32 PM
advanced builder
Score: 105
Status: offline
Thanks Roger. were going to bring home a win. team wise. Bob had the Zip pipe coated ,less heat. I wonder if that will help .
Craig I will be their on Wen- Thur. and load my hulls ,time to test the .21 I hope.
International racer
Hide Signatures
       Post #: 2431
RE: Central NEW YORK boaters - 8/27/2012 3:10 PM
Joe Petro
Score: 108
Status: offline
Yes, God Speed Little Beaver!
And good luck to all of the Stony pond crew in Canada!
Joe
-Zippkits-
People make this a great hobby!
Hide Signatures
       Post #: 2432
RE: Central NEW YORK boaters - 8/27/2012 7:15 PM
engineman351
Score: 100
Status: offline
Craig...on your 'hole in the foam' picture...other than on the ends of the brass tube, where are you putting more slow set epoxy that is touching wood and not adding a lot of extra weight??
It would seem to me adding epxoy between the tube and the top or bottom would be a lot of extra weight?? Maybe you could explain?? Thanks, Roger
Hide Signatures
       Post #: 2433
RE: Central NEW YORK boaters - 8/27/2012 8:14 PM
Blackout
Score: 100
Status: offline
quote:
ORIGINAL: engineman351
The slow epoxy is gluing the tube to the foam. The epoxy will create a lock between the two wood sides. If you don't do this you can run into issues if too much epoxy is pushed off when inserting the tube. You can use a wood block for even more strength. I did that with my JAE 45 sponsons. A little extra weight, I'm not going to lose sleep over....
Hide Signatures
       Post #: 2434
RE: Central NEW YORK boaters - 8/27/2012 8:23 PM
Blackout
Score: 100
Status: offline
Neil, bring your EZ-UP this week and we can pack it in the RV or trailer ahead of time.
The weather looks fantastic for the Ottawa race!!
Hide Signatures
       Post #: 2435
RE: Central NEW YORK boaters - 8/28/2012 12:24 AM
gassertom
Score: 100
Status: offline
Craig,
Would it be ok if we use the pond Saturday or Monday - whichever day won't interfere with your families plans.
Good luck to you guys in Ottawa - wish we could be there.  Let us know how you make out.
T&C
Tom Driver
IMPBA #6425
Hide Signatures
       Post #: 2436
RE: Central NEW YORK boaters - 8/28/2012 1:14 AM
advanced builder
Score: 105
Status: offline
quote:
ORIGINAL: gassertom
Craig,
T&C
Race results ???
Tom
International racer
Hide Signatures
(in reply to gassertom)
       Post #: 2437
RE: Central NEW YORK boaters - 8/28/2012 1:22 AM
advanced builder
Score: 105
Status: offline
quote:
ORIGINAL: Joe Petro
Joe
Were going hungry and humble
Not cocky and pissed. we will miss your wisdom.
International racer
Hide Signatures
(in reply to Joe Petro)
       Post #: 2438
RE: Central NEW YORK boaters - 8/28/2012 1:37 AM
Blackout
Score: 100
Status: offline
quote:
ORIGINAL: gassertom
Craig,
T&C
Either day is fine. We'll be back Sunday evening.
Hide Signatures
       Post #: 2439
RE: Central NEW YORK boaters - 8/28/2012 1:39 AM
Blackout
Score: 100
Status: offline
quote:
ORIGINAL: gassertom
Craig,
T&C
Race results ???
Tom
Northern Nats
2012
SS GAS MONO: Gary Isles, Vince Amore, Butch Laporte
B MONO: Terry Keeley, Charles Dukes, Cindy Driver
NOVICE: Hope Morley, Logan Morley, Jackie Puliam
GAS MONO: Chris Rupley, Dennis Madlinski, Marc Lavac
B HYDRO: Mike Betke, Rob Betke, Terry Munn
GAS CAT: Antron Brown, Gus Dolsen, Terry Munn
D MONO: Charles Dukes, Kerry Norton, Ralph Barthel
LSG SPORT HYDRO: Dale Brobst, Chris Rupley, Terry Munn
D HYDRO: Rob Betke, Terry Keeley, Joe Wiebelhaus
OPEN MONO: Vince Amore, Martc Lavac, Antron Brown
SPORT 40: Mike Betke, Kerry Norton, Charles Dukes
CRACKERBOX: Marc Levac, Ron Mitchell, Bob Tanner
GAS RIGGER: Terry Munn, Butch Laporte, Marc Lavac
E/F HYDRO: Chris Krawczyk, Bill Smith, Terry Keeley
THUNDERBOAT: Ron Mitchell, Gus Dolsen, Bob Tanner
SCALE HYDRO: Robin Enneper, Roger Hallam, Steve Peterson
Congrats Cindy!!
Hide Signatures
       Post #: 2440
RE: Central NEW YORK boaters - 8/28/2012 2:43 AM
parshallboatworks
Score: 100
Status: offline
quote:
ORIGINAL: gassertom
Craig,
T&C
tom and cindy, let me know what day you will go to pond, i will probably go thursday,but want to leave pond open to those getting ready to go whoop some northerners!!lol... (we love our neighbors to the north,dont take any offence!!!)will hope to have old rigger ready to try out,and its not much fun alone....waiting on too much stuff for JAE..i am impaitent..lolthanks, Rick P.
ParshallWoodworks If you can dream it I can build it
Stony Pond Model Boat Club,Cdga.NY
Hide Signatures
       Post #: 2441
RE: Central NEW YORK boaters - 8/28/2012 2:47 AM
parshallboatworks
Score: 100
Status: offline
JOE, they are taking YOUR boats up to kick butt!!!!...thanks for the customer suppt. and club deals!!!...Rick P.
quote:
ORIGINAL: Joe Petro
Joe
Hide Signatures
       Post #: 2442
RE: Central NEW YORK boaters - 8/28/2012 3:00 AM
parshallboatworks
Score: 100
Status: offline
THANKS CRAIG... also i have collet on K&B,engine almost installed in older rigger i am trying to revise throttle linkage via bellcrank so starter belt use will be easier(dont know why they designed the throttle right in way over flywheel...) using the flex shaft from JAE and strut and probably the rudder.... have joe sending another hdw.pkg..... what is the best way to cut flex shaft???? asume its with a cutoff wheel... hope to have it ready in the next night or two... things have been kinda crazy as the last of my grandfathers passed away last night.(Sarahs g-pa was like my own cause mine died when i was 8 yrs old..) services are thursday but i hope to meet you guys at pond after.. what time you all planning on being there?? thanks again, RICK P.
quote:
ORIGINAL: Blackout
Hide Signatures
       Post #: 2443
RE: Central NEW YORK boaters - 8/28/2012 3:22 AM
parshallboatworks
Score: 100
Status: offline
One good testing day. The QD engine inside my gas JAE,problem found the spacer on my piston ,broke apart. The piston wall has some damage that's all. Fixable. The Speedmaster skeg strut worked fine. no more right sway at high speeds. was the fastest I've gone all year. And my carb was only 7/8 open. Linkage arm problem. So Bob Looks like the gas JAE goes to Ottawa and the .45 JAE stays home. If I can fix the QD
Bill
Rick
NEIL, i allready considered making it an inboard!!.. where can i find info about engine placement, etc, etc.etc....????? i still have the plans and i made mylar templates to build another,it had a shortened version for racing, theres a winter project... the other stuff is overnights and weekend projects.. too impatient to wait till winter,as i will sleep when i'm dead!!!!! LOL..i also seem to be stuck on the riggers and hydros... a 67 sized rigger would be cool to!! plan on moving to gas.. cheaper and i like the sound,smell and fuel availibility... AND THEY ARE FAST!!!
THANKS, Rick P.
Hide Signatures
       Post #: 2444
RE: Central NEW YORK boaters - 8/28/2012 11:35 AM
Blackout
Score: 100
Status: offline
quote:
ORIGINAL: rickyak55
Bill
Rick
THANKS, Rick P.
Gasoline is cheaper, the gas boats are not....
With that being said, you may want to consider a gas rigger over a .67 rigger. I think Zippkits makes a gas rigger.
Hide Signatures
(in reply to parshallboatworks)
       Post #: 2445
RE: Central NEW YORK boaters - 8/28/2012 12:58 PM
advanced builder
Score: 105
Status: offline
Now adding that .67 to a 45 short kit,WOW ,If she will float. Fuel may be a problem. with that setup, Not enough to Finnish a heat.
Craig ,Ill have my tent and table with me on Thursday. with boats to pack ,except for the .21 ,One of 2 runs with the new engine. I don't want to ruin the engine by going too lean.
International racer
Hide Signatures
       Post #: 2446
RE: Central NEW YORK boaters - 8/28/2012 2:30 PM
engineman351
Score: 100
Status: offline
Rick, If you are thinking of making a vee hull an inboard... the rule of thumb is to have the balance point (CG) at 30% of the hull length as measured from the transom forward. So, if the hull is 34" long, that would be 10.2 inches from the transom. Before measuring you should have the hardware/tank/radiobox/electronics in place and your pipe on the engine. Roger
Hide Signatures
       Post #: 2447
RE: Central NEW YORK boaters - 8/28/2012 3:24 PM
Billk44
Score: 100
Status: offline
Roger,
It sounds like Rick is considering converting a tunnel. If so the cats are generally set at 32% to 34% CG depending on the power. Personally, I would go with roughly 32% and add bow weight if necessary. The more power, the further forward the CG. This helps if you start out with a milder motor and then decide to step up.
Bill
Hide Signatures
       Post #: 2448
RE: Central NEW YORK boaters - 8/28/2012 4:54 PM
Blackout
Score: 100
Status: offline
quote:
ORIGINAL: Billk44
Roger,
Bill
Nope, Rick has a O/B mono from years ago! Looks cool running on the water, but hard to get the handling optimized....
Hide Signatures
(in reply to Billk44)
       Post #: 2449
RE: Central NEW YORK boaters - 8/28/2012 10:22 PM
parshallboatworks
Score: 100
Status: offline
quote:
ORIGINAL: Blackout
quote:
ORIGINAL: Billk44
Roger,
Bill
yup, ihave a scratch built mono from RCM Magazine plans with a 7.5 K&B outboard on it.. like to put the engine on a tunnel... probably a vintage HOT-SHOT... and convert the mono to inboard... the hull is a "Ski Vee 40 drawn by Fred Reese it is40" long and 12 1/2" wide, constructed of 1/8" balsa with 6 oz.cloth and resin... plans say 8lbs... i have i PICCO .67 and a brand new OPS.45...  kinda still interested in riggers and hydros.... like a big rigger for the .67.. and kinda like "old school stuff... yup i am wierd!!! what time yall going to pond thursday??? giong to have this old rigger i [picked up ready by then if i have to stay up 2 days straight!!!lol.......
Hide Signatures
       Post #: 2450
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
