eclipse 7 throttle stick
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> eclipse 7 throttle stick
Page: [1]
Login
eclipse 7 throttle stick - 7/23/2003 12:35:02 PM
_BOON_
Status: offline
I have just setup the Eclipse 7 idle up 2 setting, which on the Tx is ST2 switch setting.
100 75 45 75 100 settings 1 2 3 4 5.
Now it works ok but if I give the stick a full up or down (full end of the stick) the throttle goes to 0 if I let go it goes to 100.
I have tried end point adjustments, reducing the amount of full throttle on each end etc. But it still happens. Lucky I wasn't flying.
Is there something I have missed?
This doesn't happen with the other flight modes, although I haven't got a -9 0 9 setup on them.
regards
rich
       Post #: 1
eclipse 7 throttle stick - 7/23/2003 7:53:36 PM
TomM
Status: offline
It's happened to me and a few others. Quite scary, isn't it!!! Mike from hitec says it a "calibration"issue with the throttle stick and to send it in to be fixed. Probably just loosening a set-screw and moving the pot a degree or two?
In the meantime, most everyone has limited their throttle and pitch curves to 99%. There seems to be no problems running at this setting.
Tom
(in reply to _BOON_)
       Post #: 2
eclipse 7 throttle stick - 7/24/2003 12:57:56 PM
_BOON_
Status: offline
ok thanks Tom
I'll give that a try
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.218RCU5
