Trimming Out Twin Motors on an Aurora 9    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Trimming Out Twin Motors on an Aurora 9
Page: [1]
Login
Trimming Out Twin Motors on an Aurora 9 - 6/23/2010 5:57 AM
Whirligig
Score: 100
Last Login: 2/5/2012
Status: offline
Hi,
My Aurora 9 was very easy to setup for a Fabco Tigercat parkflyer with twin electric motors. But there's a 200 to 300 rpm difference between the two motors that I'm trying to trim out. This difference appears from low to high thottle. What I would like to do is trim out the difference by assigning a trim tab to adjust the speed differential. Is there a way to do this?
Whirligig
< Message edited by Whirligig -- 6/23/2010 7:37 AM >
Hide Signatures
       Post #: 1
RE: Trimming Out Twin Motors on an Aurora 9 - 6/24/2010 2:35 AM
A.T.
Score: 181
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: Whirligig    Hi,   My Aurora 9 was very easy to setup for a Fabco Tigercat parkflyer with twin electric motors. But there's a 200 to 300 rpm difference between the two motors that I'm trying to trim out. This difference appears from low to high thottle. What I would like to do is trim out the difference by assigning a trim tab to adjust the speed differential. Is there a way to do this?   Thanks,   Whirligig
Use two separate ESC.
Settings> [MDL Type] > Single Engine.
Settings > [Channel]  > Ch* (say5) > AUX1> Sel (switch) :RT.
[Model] > [P.Mixes] > 1. ACT > Ch3 > Ch5 > [Select]  Rate H: +100 > Rate L: +100 > switch G & T.App : ACT> end.
NB: Before Turning Model ON
Settings > [Model} > Monitor > (opens Monitor screen) and watch what happens when trims are adjusted.
RT provides a much wider trim adjustment and user will need to observe overall effect on ESC .
Tie model down and range check running & trimming both motors to ensure operation is correct over full range. -
(caution Ver 1.03>1.06 - throttle lock will not mix/work on auxCh.... Aurora Version V1.07 fixes this problem with new [ThroLock] button = Settings>Model> 2/2[ThroLock] Switch:NULL > assign switch as above] All Aurora can be updated using HPP-22 refer FAQ.
Some programmable ESC units may need throttle stick movement to be re-set.
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
< Message edited by A.T. -- 7/13/2010 1:55 PM >
_____________________________
R/C hobby consultant for various companies
Hide Signatures
(in reply to Whirligig)
       Post #: 2
RE: Trimming Out Twin Motors on an Aurora 9 - 6/24/2010 5:14 AM
Whirligig
Score: 100
Status: offline
Alan,
Thanks for the instructions. I will give this a try using the single engine mode with a program mix to, in my case, Ch 6.
I had my first flight with the Tigercat today using the just dual engine mode. The rpm difference did not exhibit any yaw problem that tI couldn't handle. However, using your method to get the motors perfect would help.
This radio is a lot of fun. I applied some aileron differential to the Tigercat to get rid of some adverse yaw and I ended up with some beautiful axial rolls.
Thanks again,
Whirligig
Hide Signatures
(in reply to A.T.)
       Post #: 3
RE: Trimming Out Twin Motors on an Aurora 9 - 6/25/2010 4:40 AM
Whirligig
Score: 100
Status: offline
quote:
ORIGINAL: A.T.
[Model] > [P.Mixes] > 1. ACT > Ch3 > Ch5 > [Select] > switch G  & T.App : ACT> end.
Many programmable units may need throttle stick movement to be re-set.
Regards
Alan T.
Alan,
I needed to revise the step in red from your instructions and that is to change the H: Rate and L: Rate to +100 while in the P.mixes. Without that, the rates to the program mixes are initially zero and in Monitor mode there is no response from Ch 6 until a rate value is put in. This really had me stumped until I figured it out. Here's the revised step:
Revised Step: [Model] > [P.Mixes] > 1. ACT > Ch3 > Ch5 > [Select] > Rate H: +100 > Rate L: +100 > switch G & T.App : ACT> end.
Whirligig
Hide Signatures
(in reply to A.T.)
       Post #: 4
RE: Trimming Out Twin Motors on an Aurora 9 - 6/25/2010 8:45 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: Whirligig    Alan,  I needed to revise the step in red from your instructions and that is to change the H: Rate and L: Rate to +100 while in the P.mixes. Without that, the rates to the program mixes are initially zero and in Monitor mode there is no response from Ch 6 until a rate value is put in. This really had me stumped until I figured it out. Here's the revised step:
Thanks,  Whirligig
You are correct, did that as an automatic reaction when mixing and overlooked the necessity for typing that action into above post - now corrected as linked on FAQ page for others....
Alan.
Hide Signatures
       Post #: 5
RE: Trimming Out Twin Motors on an Aurora 9 - 6/29/2010 10:09 AM
Whirligig
Score: 100
Status: offline
Alan,
I tried both methods for twins i.e. using A9's twin engine setup and your P.Mix instruction for mixing Ch 3 & 6. The latter worked best for throttle response and motor trimming but the Throttle Lock feature does not work on 2nd motor on Ch 6. The former has no motor trimming and there's a slight delay in the 2nd motor on Ch 6 from zero to low throttle. The delay is less than a second.
I have each method set up on its own model so I can try to solve the throttle delay with the twin engine setup and the Throttle Lock issue using the P.Mix setup. None of these issues I found detracted from the Tigercat's flight performance. Throttle response for hovering a twin engine foamie is kind of neat. The lack of Throttle Lock on Ch 6 is a safety issue.
Whirligig
Hide Signatures
(in reply to A.T.)
       Post #: 6
RE: Trimming Out Twin Motors on an Aurora 9 - 6/29/2010 12:17 PM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: Whirligig   Alan,   I tried both methods for twins i.e. using A9's twin engine setup and your P.Mix instruction for mixing Ch 3 & 6. The latter worked best for throttle response and motor trimming but the Throttle Lock feature does not work on 2nd motor on Ch 6. The former has no motor trimming and there's a slight delay in the 2nd motor on Ch 6 from zero to low throttle. The delay is less than a second.
I have each method set up on its own model so I can try to solve the throttle delay with the twin engine setup and the Throttle Lock issue using the P.Mix setup. None of these issues I found detracted from the Tigercat's flight performance. Throttle response for hovering a twin engine foamie is kind of neat. The lack of Throttle Lock on Ch 6 is a safety issue. Whirligig
Tks, will add request that, any channel 100% mixed to throttle also has lock applied to that channel,  to software update list .
Alan T.
Hide Signatures
       Post #: 7
RE: Trimming Out Twin Motors on an Aurora 9 - 5/3/2013 6:20 AM
leiffk
Score: 100
Last Login: 5/3/2013
Status: offline
I think the trimming can be accomplished, but I have one more desire that is to couple the motors to the rudder for taxing ( especially on water ) Any help is appreciated
Hide Signatures
(in reply to A.T.)
       Post #: 8
RE: Trimming Out Twin Motors on an Aurora 9 - 5/3/2013 6:45 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: leiffk  I think the trimming can be accomplished, but I have one more desire that is to couple the motors to the rudder for taxing
Similar to:
Aurora 9 - Airbrakes -Twin Rudder set up. posts 4503 & 4504 e.g. Stryker 27Q & Funjet mode 1&2 setup & Zip files
Alan T.
Hide Signatures
(in reply to leiffk)
       Post #: 9
RE: Trimming Out Twin Motors on an Aurora 9 - 5/6/2013 5:07 PM
Charley
Score: 100
Last Login: 5/17/2013
Status: offline
I tried the P-mix method outlined above, worked OK.. I'll have a look at the twin engine option.
CR
Charley
ccrobins@ktc.com
Hide Signatures
(in reply to A.T.)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.482RCU1
