!!THE BEST!! (alu) Clutch Spring life help.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
VX-18
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> !!THE BEST!! (alu) Clutch Spring life help.
    Page: [1]
    Login
    !!THE BEST!! (alu) Clutch Spring life help. - 6/24/2010 4:09 PM
    catbob007
    Score: 100
    Last Login: 11/24/2011
    Status: offline
    No pix for this one sorry,     I have taken the clutches for years and added or lessened the weight of them to meet my needs ,  increasing the weight makes for quicker take off's,     Lessening spring life.      And decreasing the weight of the clutch pads,    makes for higher idles without the wheels turning and less deceleration with engine engaged,               I like it for catching that first gear faster.     Makes for a little slower take off,    Buti increases spring and clutch life.     And usualy the eyes on the clutch for the flywheel pins break anywho  Long before the clutch is wore out.  You might want to make sure when putting the spring together, to close the open end of the clasp on the spring with a small needle nose plyers.    a magnifying lense works good to see it.  Making sure not to crimp it to tight it might break    I never have but it could happen when you least expect it .    By drilling holes in the clutch be careful it is fastened to something cause they love to spin,  if too much pressure is added to the drill.      A small tap with a center punch makes for a good starting point.     Please use safety goggles whenever using power tools of any size.     The smallest piece of aluminum in your eye can float around forever and be a pain in the ...eye.  I drilled 2 holes 2/3 less dameter of the flywheel holes better have an extera clutch when learning cause the centering of the holes is hard evenly spaced not to close to the end where their is no hole.   When Finished use a small file or fine sandpaper,  to clean all the burrs up so the spring can move freely. ::NOTE::when using a drill go about 1/4 speed aluminum is very soft too much pressure gets to much of a bite causing warpage,  and when the hole is allmost compeeted lessen your pressure and let it slowly compleete.  and for heavens sakes use something under neath like wood an old phone book.  Always think twice before you do something that could be dangerous.   Sharpen your common senses..... And Giver Full Throttle Dont Dottle!!! Later!!   www.catbob07.rcuniverse.com                                CONNECT YOUR SPRINGS BETTER SEE MY OTHER THREADS
    < Message edited by catbob07 -- 7/7/2010 4:28 AM >
    _____________________________
    Keep it full throttle don''t dottle.
    Hide Signatures
           Post #: 1
    RE: !!THE BEST!! (alu) Clutch Spring life help. - 7/5/2010 10:47 PM
    catbob007
    Score: 100
    Status: offline
     Now thats What Im talkin About.
    Hide Signatures
    (in reply to catbob007)
           Post #: 2
    Page:   [1]
    Page: [1]
    VX-18
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    1.016RCU1
